Discuss
Hum near motor when 'Start' is pushed.
 in
Dryer Repair
Hello, I have an Estate ("A Whirlpool Company" - as written on the front). It's run fine for the last
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Hum near motor when 'Start' is pushed.
  #1 (permalink)
Old 07-01-2008, 10:30 AM
Junior Member
Mahnarch is on a distinguished road
Default Hum near motor when 'Start' is pushed.
Model Number: TEDS740JQ1   Brand: Estate   Age: 1 - 5 years
Hello,
It's run fine for the last few years until a couple of days ago.
Randomly, it would buzz in a manner similar to the 'load finished' alarm, only lower in volume - and we weren't even using it at the time.
Then, I went to use it. It just hums when I set the timer and hit start.
I pulled it away from the wall and unplugged it.
First thing I noticed was the 220v plug at the wall was green/burnt/corroded.
The wall plug is perfectly fine.
I installed a new plug kit from Lowe's.
Same thing.
I checked all the wiring - nothing burned up.
If I unplug the white thing that I've read about but, can't seem to remember the name of at the moment and it doesn't buzz - so I'm assuming it works.
If I lift the lid I can rotate the drum by hand but, if I stop the drum quickly the belt continues to spin for a split second - so the motor isn't seized.
I'm assuming a short in the motor but, I really, really, really don't want to have to dig into it because I'm not really sure how to get to it, easily - and I'm lazy.
Mostly, I'm lazy.
If I take off the lint/exhaust housing, will the motor be easily accessible if that's what it is?
Thanks in Advance!
Related Models
 TEDS740JQ1 DRYER
 TEDS740JQ2 29"ELECTRIC DRYER
 TEDS740PQ0 29"ELECTRIC DRYER
 TEDS740PQ1 29"ELECTRIC DRYER
 TEDS780JQ0 ELECTRIC DRYER
 TEDS840JQ0 DRYER
 TEDS840JQ1 ELECTRIC DRYER
 TEDS840JQ2 DRYER
 TEDS840JQ3 29"ELECTRIC DRYER
 TEDS840PQ0 29"ELECTRIC DRYER
 TEDS840PQ1 29"ELECTRIC DRYER
 TEDX340RW0 29" ELECTRIC DRYER
 TEDX340RW1 29" ELECTRIC DRYER
 TEDX340RW2 29" ELECTRIC DRYER
Whirlpool TEDX540RQ0 29" ELECTRIC DRYER
 TEDX540RQ1 29" ELECTRIC DRYER
 TEDX640EQ0 ELECTRIC DRYER
 TEDX640EQ1 DRYERS
 TEDX640EQ2 ELECTRIC DRYER
 TEDX640JQ0 ELECTRIC DRYER
 TEDX640JQ1 DRYER
 TEDX640JQ2 29"ELECTRIC DRYER
 TEDX640PQ0 29" ELECTRIC DRYER
 TEDX640PQ1 29"ELECTRIC DRYER
Frigidaire TEF240PHD1 Tap(v1) / Electric Range
Frigidaire TEF240PHW1 Tap(v2) / Electric Range
Tappan TEF240PHW2 Tappan/electric Range
Tappan TEF242BU1 Tappan/electric Range
Tappan TEF242BU2 Tappan/electric Range
Tappan TEF242BU3 Tappan/electric Range
Tappan TEF242BU4 ELECTRIC RANGE
Tappan TEF242BU5 ELECTRIC RANGE
Tappan TEF242BW1 Tappan/electric Range
Tappan TEF242BW2 Tappan/electric Range
Tappan TEF242BW3 Tappan/electric Range
Tappan TEF242BW4 ELECTRIC RANGE
Tappan TEF242BW5 ELECTRIC RANGE
Tappan TEF303AWA Tappan/range
Tappan TEF303AWB Tappan/electric Range
Tappan TEF303BWA Tappan/electric Range
Tappan TEF303BWB Tappan/electric Range
Tappan TEF303BWC Tappan/electric Range
Tappan TEF303BWD Tappan/electric Range
Tappan TEF303BWE Tappan/range
Tappan TEF303BWF RANGE
Tappan TEF303BWG RANGE
Tappan TEF317AUA Tappan/range
Tappan TEF317AUB Tappan/electric Range
Tappan TEF317AWA Tappan/range
Tappan TEF317AWB Tappan/electric Range
Tappan TEF317AWC Tappan/electric Range
Tappan TEF317BUA Tappan/electric Range
Tappan TEF317BUB Tappan/electric Range
Tappan TEF317BUC Tappan/electric Range
Tappan TEF317BUD Tappan/electric Range
Tappan TEF317BWA Tappan/electric Range
Tappan TEF317BWB Tappan/electric Range
Tappan TEF317BWC Tappan/electric Range
Tappan TEF317BWD Tappan/electric Range
Tappan TEF317BWE Tappan/electric Range
Tappan TEF317BWF ELECTRIC RANGE
Tappan TEF317BWG ELECTRIC RANGE
Frigidaire TEF322BHDA
Frigidaire TEF322BHWA
Frigidaire TEF322SCDA Tap(v1) / Electric Range
Frigidaire TEF322SCDB Tap(v1) / Electric Range
Frigidaire TEF322SCDC Tap(v1) / Electric Range
Frigidaire TEF322SCWA Tap(v2) / Electric Range
Frigidaire TEF322SCWB Tap(v2) / Electric Range
Frigidaire TEF322SCWC Tap(v2) / Electric Range
Frigidaire TEF322WHSA
Frigidaire TEF324BCDA Tap(v1) / Electric Range
Frigidaire TEF324BCDB Tap(v3) / Electric Range
Frigidaire TEF324BCDC Tap(v3) / Electric Range
Frigidaire TEF324BCWA Tap(v2) / Electric Range
Frigidaire TEF324BCWB Tap(v4) / Electric Range
Frigidaire TEF324BCWC Tap(v4) / Electric Range
Frigidaire TEF324CCSA Tap(v0) / Electric Range
Frigidaire TEF324CCSB Tap(v5) / Electric Range
Tappan TEF326FBA Tappan/range
Tappan TEF326FBB ELECTRIC RANGE
Tappan TEF326FBC ELECTRIC RANGE
Tappan TEF326FSA Tappan/range
Tappan TEF326FSB ELECTRIC RANGE
Tappan TEF326FSC ELECTRIC RANGE
Tappan TEF326FSD ELECTRIC RANGE
Tappan TEF326FSE ELECTRIC RANGE
Tappan TEF350DSA Tappan/range
Tappan TEF350DWA Tappan/electric Range
Frigidaire TEF350SCDA Tap(v1) / Electric Range
Frigidaire TEF350SCDB Tap(v1) / Electric Range
Frigidaire TEF350SCDC Tap(v1) / Electric Range
Frigidaire TEF350SCDD Tap(v1) / Electric Range
Frigidaire TEF350SCDE Tap(v1) / Electric Range
Frigidaire TEF350SCWA Tap(v2) / Electric Range
Frigidaire TEF350SCWB Tap(v2) / Electric Range
Frigidaire TEF350SCWC Tap(v2) / Electric Range
Frigidaire TEF350SCWD Tap(v2) / Electric Range
Frigidaire TEF350SCWE Tap(v2) / Electric Range
Tappan TEF351DSB Tappan/range
Tappan TEF351DUA Tappan/electric Range
Tappan TEF351DUB Tappan/range
Tappan TEF351DWA Tappan/electric Range
Tappan TEF351DWB Tappan/range
Tappan TEF351EWA Tappan/range
Tappan TEF351EWB Tappan/range
Tappan TEF351EWC Tappan/electric Range
Tappan TEF351EWD ELECTRIC RANGE
Tappan TEF351EWE ELECTRIC RANGE
Tappan TEF351EWF ELECTRIC RANGE
Tappan TEF351EWG ELECTRIC RANGE
Tappan TEF351EWH ELECTRIC RANGE
Tappan TEF351EWJ TAPPAN/ELECTRIC RANGE
Frigidaire TEF352BHDA Tap(v1) / Electric Range
Frigidaire TEF352BHWA Tap(v2) / Electric Range
Frigidaire TEF352CHSA Tap(v3) / Electric Range
Tappan TEF352CHTA Tappan/electric Range
Frigidaire TEF352SCDA Tap(v1) / Electric Range
Frigidaire TEF352SCDB Tap(v1) / Electric Range
Frigidaire TEF352SCDC Tap(v1) / Electric Range
  #2 (permalink)
Old 07-02-2008, 02:44 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Mahnarch,
Do a simple test (you probably need someone to give you a hand).
Open the door, push and hold the door switch, push the start switch and manually move the drum.
Post the result.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer just hums when start button is pushed Jimbomania Dryer Repair 3 02-09-2010 10:30 AM
Dryer does not start when button pushed nikita Dryer Repair 3 07-14-2009 07:52 PM
Oven noisy when start button pushed pauls Oven Repair (including Ranges and Cooktops) 1 03-08-2009 10:09 AM
dryer struggles to start when button is pushed atomic33 Dryer Repair 1 03-14-2008 05:22 PM
Hum when start button is pushed LOST Dryer Repair 1 10-01-2007 03:59 PM
