Discuss
no heat on whirlpool lgr4634eq3
 in
Dryer Repair
I have read several posts about this topic but before I order parts I thought I would try to confirm.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » no heat on whirlpool lgr4634eq3
  #1 (permalink)
Old 05-07-2010, 06:25 PM
Junior Member
JoeBuckeye is on a distinguished road
Default no heat on whirlpool lgr4634eq3
Model Number: LGR4634EQ3   Brand: Whirlpool   Age: 5 - 10 years
I have read several posts about this topic but before I order parts I thought I would try to confirm. The dryer has no heat at all but spins. I checked the air flow and there is no blockage. the timer moves on the high heat cycle but does not move on the automatic dry miser heat cycle. there is no glow when looking through the small hole in the front. I was thinking I need to replace the coils. Parts 13 and 14 on diagram. Can anyone confirm this? Thanks in advance.
Ads By Google
Related Models
Whirlpool LGR4634EQ3
Whirlpool LGR4634EW0
Whirlpool LGR4634EZ0
Whirlpool LGR4634EZ1
Whirlpool LGR4634EZ2
Whirlpool LGR4634EZ3
Whirlpool LGR4634JQ0
Whirlpool LGR4634JQ1
Whirlpool LGR4634JQ2
Whirlpool LGR4634JQ3 29" Gas Dryer
Whirlpool LGR4634JT0
Whirlpool LGR4634JT1
Whirlpool LGR4634JT2
Whirlpool LGR4634JT3 29" Gas Dryer
Whirlpool LGR4634JZ0
Whirlpool LGR4634JZ1
Whirlpool LGR4634PQ0 29" Gas Dryer
Whirlpool LGR4634PQ1 29" Gas Dryer
Whirlpool LGR4634PT0 29" Gas Dryer
Whirlpool LGR4634PT1 29" Gas Dryer
Whirlpool LGR5434AN0
Whirlpool LGR5434AW0
Whirlpool LGR5600HQ0
Whirlpool LGR5600HZ0
Whirlpool LGR5600JQ0
Whirlpool LGR5600JQ1
Whirlpool LGR5600JT0
Whirlpool LGR5600JT1
Whirlpool LGR5620KQ0
Whirlpool LGR5620KQ1
Whirlpool LGR5620KQ2 29"gas Dryer
Whirlpool LGR5624BN0
Whirlpool LGR5624BN1
Whirlpool LGR5624BN2
Whirlpool LGR5624BW0
Whirlpool LGR5624BW1
Whirlpool LGR5624BW2
Whirlpool LGR5624DQ0
Whirlpool LGR5624DQ1
Whirlpool LGR5624DW1
Whirlpool LGR5624DZ0
Whirlpool LGR5624DZ1
Whirlpool LGR5634AN0
Whirlpool LGR5634AQ0
Whirlpool LGR5634AQ1
Whirlpool LGR5634AQ2
Whirlpool LGR5634AW0
Whirlpool LGR5634DQ1
Whirlpool LGR5634EQ0
Whirlpool LGR5634EZ0
Whirlpool LGR5634LQ0
Whirlpool LGR5635LQ0 29"gas Dryer
Whirlpool LGR5635LQ1 29"gas Dryer
Whirlpool LGR5636DW0
Whirlpool LGR5636DW1
Whirlpool LGR5636EQ0
Whirlpool LGR5636EQ1
Whirlpool LGR5636EQ2
Whirlpool LGR5636EQ3
Whirlpool LGR5636EZ0
Whirlpool LGR5636EZ1
Whirlpool LGR5636EZ2
Whirlpool LGR5636EZ3
Whirlpool LGR5636JQ0
Whirlpool LGR5636JQ1
Whirlpool LGR5636JT0
Whirlpool LGR5636JT1
Whirlpool LGR5636KQ0
Whirlpool LGR5636KQ1
Whirlpool LGR5636KT0
Whirlpool LGR5636KT1
Whirlpool LGR5636LG0
Whirlpool LGR5636LQ0
Whirlpool LGR5636LQ1 29"gas Dryer
Whirlpool LGR5636LT0
Whirlpool LGR5636LT1 29"gas Dryer
Whirlpool LGR5636LW0
Whirlpool LGR5636PQ0 29"gas Dryer
Whirlpool LGR5636PQ1 29"gas Dryer
Whirlpool LGR5636PT0 29"gas Dryer
Whirlpool LGR5636PT1 29"gas Dryer
Whirlpool LGR5638AN0
Whirlpool LGR5638AN1
Whirlpool LGR5638AN2
Whirlpool LGR5638AN3
Whirlpool LGR5638AW0
Whirlpool LGR5638AW1
Whirlpool LGR5638AW2
Whirlpool LGR5638AW3
Whirlpool LGR5644AN0
Whirlpool LGR5644AN1
Whirlpool LGR5644AN2
Whirlpool LGR5644AW0
Whirlpool LGR5644AW1
Whirlpool LGR5644AW2
Whirlpool LGR5644EQ0
Whirlpool LGR5644EQ1
Whirlpool LGR5644EQ2
Whirlpool LGR5644EQ3
Whirlpool LGR5644EZ0
Whirlpool LGR5644EZ1
Whirlpool LGR5644EZ2
Whirlpool LGR5644EZ3
Whirlpool LGR5644JQ0
Whirlpool LGR5644JQ1
Whirlpool LGR5644JQ2
Whirlpool LGR5644JQ3 29" Gas Dryer
Whirlpool LGR5644JT0
Whirlpool LGR5644JT1
Whirlpool LGR5644JT2
Whirlpool LGR5644JT3 29" Gas Dryer
Whirlpool LGR5644PQ0 29" Gas Dryer
Whirlpool LGR5644PQ1 29" Gas Dryer
Whirlpool LGR5700KQ0
Whirlpool LGR5700KQ1
Whirlpool LGR5700KT0
Whirlpool LGR5700KT1
Whirlpool LGR5848EQ0
Whirlpool LGR5848EQ1
Whirlpool LGR5848EQ2
  #2 (permalink)
Old 05-08-2010, 04:42 AM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
Quote:
You do not need coils!!!! Unplug the dryer, and then take the back panel off the dryer, and in the middle close to the bottom you will see a white thin part, about an inch and a half long, by a half inch wide. It will have 2 wires coming to it, and be held in by one screw. Take the 2 wires off of it, and put the terminal ends together, and then put some tape around it, to keep them together, and to be sure you cover the terminals with tape well, because you do not want the termminals to hit metal. Then plug it in, and see if it works. If so, DO NOT RUN the dryer like that. That thermal fuse is a saftey. It is the only thing perventing the dryer from burning down the house. Tom ******************************************** - Parts
  #3 (permalink)
Old 05-08-2010, 03:32 PM
Junior Member
Default
Quote:
I'll give it a try.
  #4 (permalink)
Old 05-08-2010, 03:52 PM
Junior Member
Default
I tried it out and there is a glow for about 10 seconds and then it goes out. If i shut if off and try it again it glows again but only for a short time.
  #5 (permalink)
Old 05-08-2010, 04:12 PM
Senior Expert
APP Volunteer
Default
Replace the coils!!!!
  #6 (permalink)
Old 05-08-2010, 05:01 PM
Junior Member
Default
Thanks Tom!
  #7 (permalink)
Old 05-08-2010, 05:17 PM
Junior Member
Default
how embaressing... i forgot to turn the gas back on. Tried the doing what you said tom and it fired right up. I assume i just need to replace the fuse right?
  #8 (permalink)
Old 05-09-2010, 05:43 AM
Senior Expert
APP Volunteer
Default
That is correct!! Good Job!!!!! Tom ********************************************
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool gas dryer will not heat. brae Dryer Repair 5 05-17-2011 12:46 PM
Whirlpool Dryer - No heat Warren Dryer Repair 1 08-12-2009 12:10 PM
Whirlpool won't heat mts3 Dryer Repair 1 07-13-2009 07:02 PM
Whirlpool With No Heat KIERSTEADL Dryer Repair 1 04-03-2009 04:09 PM
Whirlpool AC/Heat pump - no heat martydoug@gmail.com Heating, Ventilation, and Air Conditioning (HVAC) 2 11-05-2008 12:25 PM
