Discuss
Kenmore electric dryer - no heat and does not shut off
 in
Dryer Repair
Hello! I've been reading thru the topics and need some troubleshooting help. My dryer is not heating and will not
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore electric dryer - no heat and does not shut off
  #1 (permalink)
Old 05-05-2010, 12:04 PM
Junior Member
Tumbleweed is on a distinguished road
Exclamation Kenmore electric dryer - no heat and does not shut off
Model Number: 110.64672400   Brand: Kenmore   Age: 5 - 10 years
Hello!
I've been reading thru the topics and need some troubleshooting help. My dryer is not heating and will not turn off. Here are the steps taken so far and observations based on what I've read so far.
1. Checked and reset fuses at main panel. (they were not tripped)
2. The timer advances when using "timed setting", but does not turn off
3. On all other settings, delicate, etc. the timer does not advance.
Thanks in advance for your time. Have a great day!
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 05-05-2010, 12:18 PM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
Primarily it sounds like a bad timer. You may have a secondary problem causing the heat not to work, but it'll be hard to tell until the timer is replaced.
  #3 (permalink)
Old 05-05-2010, 06:21 PM
Junior Member
Default
Quote:
Thank you! I will replace the timer, and post again if I still have problems.
  #4 (permalink)
Old 05-05-2010, 07:37 PM
Junior Member
eddified is on a distinguished road
Default
I had this problem on my kenmore electric dryer. I can't remember if the timed settings did advance, but I do remember that in general, the timer wasn't advancing, AND the heat wouldn't come on. Both problems happened at the same time. I took the back off the dryer and found out that the heating element was dead and needed to be replaced, so I replaced it-- and the timer started working properly again. I didn't have to replace the timer at all. My guess is the heat somehow triggers the timer to advance on the non-timed settings, or the electricity that goes through the heating element also triggers the timer to advance. Long story short, replace the heating element first (if you know it needs to be replaced), then check to see if the timer is working.
  #5 (permalink)
Old 05-05-2010, 08:03 PM
Junior Member
Default
Quote:
Thanks for the input. I will check the heating element for continuity first. Both problems happened at the same time, as you stated. I hope it's the heating element.
  #6 (permalink)
Old 05-05-2010, 08:11 PM
Junior Member
Default
When I pulled out my heating element, I could visually see the break in the heating wire. I could tell for certain that the continuity wasn't there. There was no need of a any kind of electrical instrument to check for it.
Good luck.
  #7 (permalink)
Old 05-06-2010, 10:08 AM
Junior Member
Default
Good luck.
Thank you, thank you! Pulled the heating element, and sure enough found a break in the frontside top coil. Replaced it, and now the timer is working as it should. Thanks again!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
No Heat On Kenmore Electric Dryer gmamon Dryer Repair 5 08-27-2009 09:37 PM
kenmore electric range oven wont shut off nrmrz Oven Repair (including Ranges and Cooktops) 0 07-23-2009 02:45 PM
Kenmore Electric Dryer heater won't shut off jmd_forest Dryer Repair 6 03-25-2009 08:22 AM
Kenmore Electric Dryer Intermittent Heat question bolingmike Dryer Repair 3 02-23-2009 06:28 PM
Kenmore Electric Dryer-No Heat jbarbers Dryer Repair 3 04-17-2008 08:53 AM
