Discuss
electric dryer has no heat, but still runs in both permanent press and timed dry.
 in
Dryer Repair
Help! I can't dry my clothes, no heat! Where do I begin?
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » electric dryer has no heat, but still runs in both permanent press and timed dry.
  #1 (permalink)
Old 09-06-2007, 07:44 AM
chrisnross chrisnross is offline
Junior Member
chrisnross is on a distinguished road
Default electric dryer has no heat, but still runs in both permanent press and timed dry.
Brand: GE   Age: 5 - 10 years
  #2 (permalink)
Old 09-12-2007, 06:51 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Pull out the drum and check heating elements on back shroud, if broken replace.
If ok you will need a meter to check things.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer has no heat but runs Ron L. Dryer Repair 7 06-15-2009 12:12 PM
Dryer runs no heat glennb Dryer Repair 1 08-10-2007 11:24 AM
Dryer runs but doesn't heat Jane Dryer Repair 6 08-07-2007 10:01 PM
Automatic Permanent Press Cycle fails to shut off DECALGUY Dryer Repair 3 08-04-2007 08:28 PM
