| » Dryer won't dry and timer doesn't shut off dryer |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Brand: Whirlpool Age: 1 - 5 years
My gas dryer wasn't drying clothes (no heat)....replaced thermal fuse and it appeared to fix the problem. Then realized two hours later that dryer was still running...timer not rotating and consequently not shutting off the dryer. I figured the clothes that had been drying for two hours would be extremely hot...not the case...clothes were dry but no heat in drum was evident????
It is very possible, that you blew the thermal fuse again. Make sure the vent is clear to the out side. Turn the dryer on, and go outside, and you should have good air flow outside. If that is good, and the thermal fuse is good, then, check the ignitor, and see if it comes on. Tom ApplianceEducator.com
| Display Modes | |
| Dryer will not shut off | sschroer | Dryer Repair | 3 | 06-09-2008 10:51 AM |
| Dryer won't shut down | debrunsky | Dryer Repair | 0 | 06-05-2008 03:40 PM |
| dryer shut itself off | dvillines | Dryer Repair | 1 | 04-16-2008 03:04 PM |
| coin op dryer timer starts but dryer doesn't turn on | Mike Craw | Dryer Repair | 4 | 01-10-2008 07:26 PM |
| Dryer won't shut off | Len Empie | Dryer Repair | 1 | 10-24-2007 03:27 PM |
