Discuss
Dryer won't dry and timer doesn't shut off dryer
 in
Dryer Repair
My gas dryer wasn't drying clothes (no heat)....replaced thermal fuse and it appeared to fix the problem. Then
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer won't dry and timer doesn't shut off dryer
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 06-25-2008, 09:43 AM
jbw11263 jbw11263 is offline
Junior Member
jbw11263 is on a distinguished road
Default Dryer won't dry and timer doesn't shut off dryer
Brand: Whirlpool   Age: 1 - 5 years
My gas dryer wasn't drying clothes (no heat)....replaced thermal fuse and it appeared to fix the problem. Then realized two hours later that dryer was still running...timer not rotating and consequently not shutting off the dryer. I figured the clothes that had been drying for two hours would be extremely hot...not the case...clothes were dry but no heat in drum was evident????
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-26-2008, 05:23 AM
kayakcrzy kayakcrzy is offline
Member
kayakcrzy is on a distinguished road
Default
It is very possible, that you blew the thermal fuse again. Make sure the vent is clear to the out side. Turn the dryer on, and go outside, and you should have good air flow outside. If that is good, and the thermal fuse is good, then, check the ignitor, and see if it comes on. Tom ApplianceEducator.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer will not shut off sschroer Dryer Repair 3 06-09-2008 10:51 AM
Dryer won't shut down debrunsky Dryer Repair 0 06-05-2008 03:40 PM
dryer shut itself off dvillines Dryer Repair 1 04-16-2008 03:04 PM
coin op dryer timer starts but dryer doesn't turn on Mike Craw Dryer Repair 4 01-10-2008 07:26 PM
Dryer won't shut off Len Empie Dryer Repair 1 10-24-2007 03:27 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
