Discuss
Dryer runs but won't heat.
 in
Dryer Repair
I don't have the means to test which parts are not working. Which part (e.g., thermostat, heater sub-
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer runs but won't heat.
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 06-24-2008, 10:01 PM
John Drayton John Drayton is offline
Junior Member
John Drayton is on a distinguished road
Default Dryer runs but won't heat.
Model Number: LDE7500ACE   Brand: Maytag   Age: 1 - 5 years
I don't have the means to test which parts are not working. Which part (e.g., thermostat, heater sub-assembly) fails most frequently?
Many thanks
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-25-2008, 04:32 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Check your house ducting for a clog, clean if necessary.
Pull the heater out and check if is broken. Check the house breaker, if ok check the power wiring to the dryer for burnt wires.
Next, short the two thermal limiters mounted on the heater housing one at a time to see which one is bad that causes a lack of heat.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer runs but no heat ompong Dryer Repair 4 06-20-2008 06:48 PM
Dryer runs but want heat gidget Dryer Repair 0 02-02-2008 10:40 AM
Dryer runs but doesn't heat Junie15 Dryer Repair 4 09-23-2007 09:09 AM
Dryer runs but doesn't heat Jane Dryer Repair 6 08-07-2007 09:01 PM
Dryer runs no heat Wesley Dryer Repair 3 07-27-2007 11:23 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
