Discuss
Todd
 in
Dryer Repair
Gas Dryer runs but no heat. Checked coils, Igniter & flam sensor they are all good. When I turn the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Todd
  #1 (permalink)
Old 06-24-2008, 02:03 PM
Todd Spaeth Todd Spaeth is offline
Junior Member
Todd Spaeth is on a distinguished road
Default Todd
Model Number: LGR5636EQ3   Brand: Whirlpool   Age: 5 - 10 years
Gas Dryer runs but no heat. Checked coils, Igniter & flam sensor they are all good. When I turn the dryer on the igniter doesn't glow?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-26-2008, 06:37 AM
kayakcrzy kayakcrzy is offline
Senior Expert
APP Volunteer
kayakcrzy is on a distinguished road
Default
It could be the thermal fuse, that is located in the back of the dryer. Unplug the dryer, and take the back off, and you will see the thermal fuse, it is white in color, and it is a inch and a half long, and a half inch wide, and has 2 wires coming to it. If you want to do a quick check, you can take the two wires off of the thermal fuse, and put the two terminal ends together, and put some tape around them, so it does not hit metal, and then turn the dryer on. If it heats, replace the thermal fuse. if not replace the ignitor. DO NOT run the dryer with the thermal fuse jumped out. The thermal fuse is between you, and burning down the house. If you need me you can reach me at my web site at ApplianceEducator.com Tom
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
