Discuss
Dryer Fuse Blows Often
 in
Dryer Repair
I Have A 2006 Kenmore Electric Dryer Model # 66652. There Are Two 30 Amp Fuses In Fusebox. Dryer Spins Fine
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer Fuse Blows Often
  #1 (permalink)
Old 06-23-2008, 05:55 PM
AL RYF AL RYF is offline
Junior Member
AL RYF is on a distinguished road
Wink Dryer Fuse Blows Often
Model Number: 66652   Brand: Kenmore   Age: Less than 1 year
I Have A 2006 Kenmore Electric Dryer Model # 66652. There Are Two 30 Amp Fuses In Fusebox. Dryer Spins Fine But Timer And Heat Fuse Blows After A Few Minutes? Any Help Would Be Greatly Appreciated!! Thanks!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-24-2008, 03:57 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely there is an air flow restriction in the exhaust line and/or inside air ducts, causing overheating. Possible a problem with the blower wheel. For more accurate advise we need the complete model number of the dryer.
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Monitor fuse blows, door switches OK !? mgai7755 Microwave Repair 0 04-16-2008 02:28 PM
fuse blows every time arcojet Dryer Repair 2 03-25-2008 06:30 AM
dryer blows cold air won't advance through cycle sandra626 Dryer Repair 4 02-05-2008 11:49 AM
Blows Fuse on Startup pcfucci Microwave Repair 0 01-04-2008 08:16 PM
My dryer blows hot air but doesn't turn. staceyo Dryer Repair 1 07-26-2007 08:45 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
