Discuss
high limit thermostat
 in
Dryer Repair
What is the difference between the High Limit thermostat 250 that you get in the Kit AP3094244 and the Dryer
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » high limit thermostat
  #1 (permalink)
Old 04-20-2010, 08:03 PM
Junior Member
davewild is on a distinguished road
Default high limit thermostat
Model Number: LEC5000p0   Brand: Whirlpool   Age: 1 - 5 years
What is the difference between the High Limit thermostat 250 that you get in the Kit AP3094244 and the Dryer high limit thermostat AP3131941. I know they are physically different but can't find out where the High Limit thermostat 250 from the kit goes.
Related Models
Whirlpool LEC5000PQ0 29" ELECTRIC DRYER
Whirlpool LEC5000PQ1 29" ELECTRIC DRYER
Amana LEC50AW DRYER- ELE
Amana LEC60AW DRYER- ELE
Whirlpool LEC6646AN0 ELECTRIC DRYER
Whirlpool LEC6646AN1 ELECTRIC DRYER
Whirlpool LEC6646AN2 ELECTRIC DRYER
Whirlpool LEC6646AQ0 Residential Dryer
Whirlpool LEC6646AQ1 ELECTRIC DRYER
Whirlpool LEC6646AQ2 ELECTRIC DRYER
Whirlpool LEC6646AW0 Residential Dryer
Whirlpool LEC6646AW1 ELECTRIC DRYER
Whirlpool LEC6646AW2 ELECTRIC DRYER
Whirlpool LEC6646AZ1 ELECTRIC DRYER
Whirlpool LEC6646AZ2 ELECTRIC DRYER
Whirlpool LEC6646AZO ELECTRIC DRYER
Whirlpool LEC6848AN0 ELECTRIC DRYER
Whirlpool LEC6848AN1 ELECTRIC DRYER
Whirlpool LEC6848AN2 ELECTRIC DRYER
Whirlpool LEC6848AN3 ELECTRIC DRYER
Whirlpool LEC6848AQ0 Residential Dryer
Whirlpool LEC6848AQ1 ELECTRIC DRYER
Whirlpool LEC6848AQ2 ELECTRIC DRYER
Whirlpool LEC6848AQ3 ELECTRIC DRYER
Whirlpool LEC6848AW0 ELECTRIC DRYER
Whirlpool LEC6848AW1 TECH SHEET - DRYER - REVISION REL.
Whirlpool LEC6848AW2 ELECTRIC DRYER
Whirlpool LEC6848AW3 ELECTRIC DRYER
Whirlpool LEC6848AZ1 ELECTRIC DRYER
Whirlpool LEC6848AZ2 ELECTRIC DRYER
Whirlpool LEC6848AZ3 ELECTRIC DRYER
Whirlpool LEC6858AQ3 ELECTRIC DRYER
Whirlpool LEC7646DQ0 ELECTRIC DRYER
Whirlpool LEC7646DQ1 ELECTRIC DRYER
Whirlpool LEC7646DZ0 ELECTRIC DRYER
Whirlpool LEC7646DZ1 ELECTRIC DRYER
Whirlpool LEC7848DQ0 ELECTRIC DRYER
Whirlpool LEC7848DQ1 ELECTRIC DRYER
Whirlpool LEC7848DZ0 ELECTRIC DRYER
Whirlpool LEC7848DZ1 ELECTRIC DRYER
Whirlpool LEC7858AN0 ELECTRIC DRYER
Whirlpool LEC7858AN1 ELECTRIC DRYER
Whirlpool LEC7858AN2 ELECTRIC DRYER
Whirlpool LEC7858AQ0 ELECTRIC DRYER
Whirlpool LEC7858AQ1 ELECTRIC DRYER
Whirlpool LEC7858AQ2 ELECTRIC DRYER
Whirlpool LEC7858AW0 Residential Dryer
Whirlpool LEC7858AW1 ELECTRIC DRYER
Whirlpool LEC7858AW2 ELECTRIC DRYER
Whirlpool LEC7858AZ0 ELECTRIC DRYER
Whirlpool LEC7858AZ1 ELECTRIC DRYER
Whirlpool LEC7858AZ2 ELECTRIC DRYER
Amana LEC80AW DRYER- ELE
Whirlpool LEC8858DQ0 ELECTRIC DRYER
Whirlpool LEC8858DQ1 ELECTRIC DRYER
Whirlpool LEC8858DZ0 ELECTRIC DRYER
Whirlpool LEC8858DZ1 ELECTRIC DRYER
Whirlpool LEC8858EQ0 ELECTRIC DRYER
Whirlpool LEC8858EQ1 DRYERS
Whirlpool LEC8858EQ2 ELECTRIC DRYER
Whirlpool LEC8858EZ0 ELECTRIC DRYER
Whirlpool LEC8858EZ1 DRYERS
Whirlpool LEC8858EZ2 ELECTRIC DRYER
Whirlpool LEC9000PW0 29" ELECTRIC DRYER
Whirlpool LEC9000PW1 29" ELECTRIC DRYER
Amana LEC90AW DRYER- ELE
Frigidaire LECR23EFE0 Frigidaire/refrigerator
Frigidaire LECR23EFE1 REFRIGERATOR
Frigidaire LECR23EFE2 REFRIGERATOR
Frigidaire LECR23EFE3 REFRIGERATOR
Amana LED20AW DRYER- ELE
Amana LED250 WASHER-TOP LOADING
Amana LED250 DRYER- ELE
Amana LED302 DRYER- ELE
Amana LED302 WASHER-TOP LOADING
Amana LED32AW DRYER- ELE
Amana LED450 WASHER-TOP LOADING
Amana LED450 DRYER- ELE
Amana LED502 DRYER- ELE
Amana LED57AW DRYER- ELE
Amana LED65AW DRYER- ELE
Amana LED850 WASHER-TOP LOADING
Amana LED850 DRYER- ELE
Amana LED902 DRYER- ELE
Amana LED950 WASHER-TOP LOADING
Amana LED950 DRYER- ELE
Frigidaire LEDB400FEE0 Frigidaire/dishwasher
Frigidaire LEDB500FEE0 Frigidaire Elements/dishwasher
Whirlpool LEE9848BQ0 ELECTRIC DRYER
Whirlpool LEE9848BQ1 ELECTRIC DRYER
Whirlpool LEE9848BQ2 ELECTRIC DRYER
Whirlpool LEE9848BZ0 ELECTRIC DRYER
Whirlpool LEE9848BZ1 ELECTRIC DRYER
Whirlpool LEE9848BZ2 ELECTRIC DRYER
Frigidaire LEEB30S9FEA Frigidaire/wall Oven
Frigidaire LEEB30T9FEA Frigidaire/wall Oven
Frigidaire LEEC30S9FEA Frigidaire/cooktop
Frigidaire LEEC36S9FEA Frigidaire/cooktop
Frigidaire LEEFM389FEA Frigidaire/electric Range
Frigidaire LEEFM389FEB Frigidaire/electric Range
Frigidaire LEEFM389FEF ELECTRIC RANGE
Whirlpool LEG8858JZ0 ELECTRIC DRYER
Frigidaire LEGC30S9FEA Frigidaire/gas Cooktop
Frigidaire LEGC36S9FEA Frigidaire/gas Cooktop
Frigidaire LEGFM389FEA Frigidaire/gas Range
Frigidaire LEH1642DS0 Frigidaire/laundry Center
Whirlpool LEL7646EQ0 DRYER
Whirlpool LEL7646EQ1 DRYERS
Whirlpool LEL8858DQ0 ELECTRIC DRYER
Whirlpool LEL8858DZ0 ELECTRIC DRYER
Whirlpool LEL8858EQ0 DRYER
Whirlpool LEL8858EQ1 DRYERS
Whirlpool LEL8858EQ2 ELECTRIC DRYER
General Electric LEM045H01 Electric range
General Electric LEM045H02 Counter top microwave
General Electric LEM045H03 Counter top microwave
General Electric LEM045J01 Counter top microwave
  #2 (permalink)
Old 04-21-2010, 04:43 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Here is the parts breakdown. I could not find a P0 but did find a PQ0 which follows.
Replacement parts for WHIRLPOOL LEC5000PQ0 29" Electric Dryer | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/docs/w...%208528187.pdf
They are the same.
AP3094244 is the hi-limit and the thermal fuse (Item 6 in Section 3)
AP3131941 is just the hi-limit (Item 15 in Section 3)
They are on the heater assembly and kill/regulate power to the heater.
The other thermal fuse (Item 18 in Section 3) in the unit is on the blower assembly. It kills power yo the motor so the unit seems totally dead.
The reasoning behind including it with the thermal fuse is that the hi-limit should have regulated the temperature at 250 degrees but did not do this as the unit blew the fuse at approximately 310 degrees. Therefore the hi-limit did not open (contacts welded together) and so also needs replacing.
Note: That this is not always true, see below.
Unplug the unit and check the thermal fuse with a meter, should be 0 ohms.
Be sure to unplug one side of it when checking it.
If it is blown you have to find out what caused it to go.
Note: that sometimes they do just blow on their own but changing it without checking other things is a gamble. I beleive richappy (another regular poster on this forum) has done a study on thermostats and found a wide variation of actual trip point and what is specified.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it.
If the above is OK then you will also have to replace the hi-limit as it should have regulated the temperature so the fuse did not blow.
You still have to find out why it blew.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut).
__________________
  #3 (permalink)
Old 04-21-2010, 12:05 PM
Junior Member
Default
Thanks, I did find that the heating coil was touching the case. I fixed that now and now have replaced the cut off and themal fuse. Just one more queston. The hi-limit thermostat from the AP3094244 kit doesn't look like the AP3131941 in that there is an extension on the AP3094244 which connects to the heating coil in addition to two prongs for orange and red wire. The hi-limit thermostat from the AP3094244 kit doesn't have this extension, only two prongs so how do I connect it (replace AP3131941 with it)?
  #4 (permalink)
Old 04-22-2010, 05:31 AM
Senior Expert
APP Volunteer
Default
This should help
http://www.servicematters.com/docs/p...uct/279817.pdf
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
High limit reset sfmullens Oven Repair (including Ranges and Cooktops) 2 03-22-2010 04:59 PM
looking for heater high limit marko 123 Dishwasher Repair 3 02-28-2010 03:47 AM
high limit switch edee_em Oven Repair (including Ranges and Cooktops) 0 02-03-2010 01:20 PM
how do I test the high limit thermostat naudnice Oven Repair (including Ranges and Cooktops) 1 12-20-2008 10:45 AM
Limit Thermostat Doug J Dryer Repair 1 12-05-2008 07:36 PM
