Discuss
No Heat when dryer turns on
 in
Dryer Repair
I'm a rookie when it comes to electrical repairs. However, i know that as soon as i call a repair
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » No Heat when dryer turns on
  #1 (permalink)
Old 04-20-2010, 07:43 PM
Junior Member
drmerrill is on a distinguished road
Default No Heat when dryer turns on
Model Number: LEB6400LW0   Brand: Whirlpool   Age: 5 - 10 years
I'm a rookie when it comes to electrical repairs. However, i know that as soon as i call a repair man to come out, it's going to cost $100 for them just to step in the door. Therefore, I have decided to take a crack at fixing my Whirlpool LEB6400LW0 Dryer myself. I went onto the website here and figured out how to open up the dryer and even which parts may need to be replaced. However, I do not own a volt ohm meter and thus cannot check all of the fuses, thermostats, etc to see which ones are bad and need replacing. So my thought process is to just repair all of the "common" parts that typically need replacing. This said, through the help of the website and this blog, i have identified that the Internal Bias Thermometer, Dryer Thermal Fuse, Heating Element, Fixed Thermostat, and the Termal Cut Off, seem to be the "usual suspects". All in, it would cost me roughly $100 to have all of these parts shipped to me, so i figure if I replace them all, A--I should be extending the life of the Dryer, and B--i'll make out ahead of what a repair man's bill will be. What are your thoughts about this way of thinking and would one of you experts perhaps share with me if my list of parts is complete, or too complete, or if something else should be added? Plain and simply, the dry turns on just fine, it just doesn't heat up. Thanks ahead of time for your advice.
Ads By Google
Related Models
Whirlpool LEB6400LW1 29"electric Dryer
Amana LEC10AW Dryer - Ele
Admiral LEC1330AAB Surface Unit - Ele
Admiral LEC1330AAC Surface Unit - Ele
Admiral LEC1330AAW Surface Unit - Ele
Amana LEC20AW Dryer - Ele
Amana LEC30AW Dryer - Ele
Amana LEC32AW Dryer - Ele
Whirlpool LEC5000PQ0 29" Electric Dryer
Whirlpool LEC5000PQ1 29" Electric Dryer
Amana LEC50AW Dryer - Ele
Amana LEC60AW Dryer - Ele
Whirlpool LEC6646AN0
Whirlpool LEC6646AN1
Whirlpool LEC6646AN2
Whirlpool LEC6646AQ0
Whirlpool LEC6646AQ1
Whirlpool LEC6646AQ2
Whirlpool LEC6646AW0
Whirlpool LEC6646AW1
Whirlpool LEC6646AW2
Whirlpool LEC6646AZ0
Whirlpool LEC6646AZ1
Whirlpool LEC6646AZ2
Whirlpool LEC6848AN0
Whirlpool LEC6848AN1
Whirlpool LEC6848AN2
Whirlpool LEC6848AN3
Whirlpool LEC6848AQ0
Whirlpool LEC6848AQ1
Whirlpool LEC6848AQ2
Whirlpool LEC6848AQ3
Whirlpool LEC6848AW0
Whirlpool LEC6848AW1
Whirlpool LEC6848AW2
Whirlpool LEC6848AW3
Whirlpool LEC6848AZ0
Whirlpool LEC6848AZ1
Whirlpool LEC6848AZ2
Whirlpool LEC6848AZ3
Whirlpool LEC7646DQ0
Whirlpool LEC7646DQ1
Whirlpool LEC7646DZ0
Whirlpool LEC7646DZ1
Whirlpool LEC7848DQ0
Whirlpool LEC7848DQ1
Whirlpool LEC7848DZ0
Whirlpool LEC7848DZ1
Whirlpool LEC7858AN0
Whirlpool LEC7858AN1
Whirlpool LEC7858AN2
Whirlpool LEC7858AQ0
Whirlpool LEC7858AQ1
Whirlpool LEC7858AQ2
Whirlpool LEC7858AW0
Whirlpool LEC7858AW1
Whirlpool LEC7858AW2
Whirlpool LEC7858AZ0
Whirlpool LEC7858AZ1
Whirlpool LEC7858AZ2
Amana LEC80AW Dryer - Ele
Whirlpool LEC8858DQ0
Whirlpool LEC8858DQ1
Whirlpool LEC8858DZ0
Whirlpool LEC8858DZ1
Whirlpool LEC8858EQ0
Whirlpool LEC8858EQ1
Whirlpool LEC8858EQ2
Whirlpool LEC8858EZ0
Whirlpool LEC8858EZ1
Whirlpool LEC8858EZ2
Whirlpool LEC9000PW0 29" Electric Dryer
Whirlpool LEC9000PW1 29" Electric Dryer
Amana LEC90AW Dryer - Ele
Frigidaire LECR23EFE0 Frigidaire/refrigerator
Amana LED20AW Dryer - Ele
Amana LED250 Dryer - Ele
Amana LED302 Washer - Top Loading
Amana LED32AW Dryer - Ele
Amana LED450 Dryer - Ele
Amana LED502 Dryer - Ele
Amana LED57AW Dryer - Ele
Amana LED65AW Dryer - Ele
Amana LED850 Dryer - Ele
Amana LED902 Dryer - Ele
Amana LED950 Dryer - Ele
Frigidaire LEDB400FEE0 Frigidaire/dishwasher
Frigidaire LEDB500FEE0 Frigidaire Elements/dishwasher
Whirlpool LEE9848BQ0
Whirlpool LEE9848BQ1
Whirlpool LEE9848BQ2
Whirlpool LEE9848BZ0
Whirlpool LEE9848BZ1
Whirlpool LEE9848BZ2
Frigidaire LEEB30S9FEA Frigidaire/wall Oven
Frigidaire LEEB30T9FEA Frigidaire/wall Oven
Frigidaire LEEC30S9FEA Frigidaire/cooktop
Frigidaire LEEC36S9FEA Frigidaire/cooktop
Frigidaire LEEFM389FEA Frigidaire/electric Range
Frigidaire LEEFM389FEB Frigidaire/electric Range
Frigidaire LEGC30S9FEA Frigidaire/gas Cooktop
Frigidaire LEGC36S9FEA Frigidaire/gas Cooktop
Frigidaire LEGFM389FEA Frigidaire/gas Range
Frigidaire LEH1642DS0 Frigidaire/laundry Center
Whirlpool LEL7646EQ0
Whirlpool LEL7646EQ1
Whirlpool LEL8858DQ0
Whirlpool LEL8858DZ0
Whirlpool LEL8858EQ0
Whirlpool LEL8858EQ1
Whirlpool LEL8858EQ2
  #2 (permalink)
Old 04-21-2010, 04:20 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
I would suggest you purchase a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
__________________
  #3 (permalink)
Old 04-21-2010, 05:49 AM
Junior Member
Default
Thanks for the quick response. However, since time is not on my side for this repair (2 infants in house and thus need dryer fixed asap), and since I have no idea how to use a volt ohm meter, would you kindly respond whether or not the parts list that I have identified is complete? what are the most common parts that need to be replaced when a dryer does not heat up? Thanks.
  #4 (permalink)
Old 04-22-2010, 05:50 AM
Senior Expert
APP Volunteer
Default
Replacement parts for WHIRLPOOL LEB6400LW0 | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/docs/w...%203406661.pdf
Note: the following is just wild guessing without checking anything with meter.
First try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the heating coil requires the full 240 volts.
Next would be the heater. Unplug the unit, remove the heater and check it visually. If broken you should be able to see the break.
May also of sagged and is touching the case (grounded element).
If this is the case you will probably have to also replace the thermal fuse on the heater assembly as a grounded element often runs at full power and blows this fuse.
Next would be the thermal fuse on the heating element assembly.
Then the hi-limit and or the operating thermostat.
Then the timer.
Additional Info
If the thermal fuse is blown, you still have to find out why it blew.
Grounded element?
Note that the fuse comes with a hi-limit thermostat both must be replaced as the hi-limit should have regulated the temperature so that the fuse would not blow. The exception to this is if you have a grounded element.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut).
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer heats initially then heat turns off cortinakyle Dryer Repair 0 03-23-2010 10:12 AM
Frigidaire dryer turns but no heat MartinF Dryer Repair 3 01-20-2010 06:37 PM
Gas Dryer won't heat and turns back on bombersdryer Dryer Repair 0 11-21-2009 01:25 PM
dryer turns on but timer not turning and no heat ljv2008 Dryer Repair 8 05-13-2009 08:03 PM
Dryer doesn't heat while drum turns IMTSam Dryer Repair 0 12-03-2007 08:36 AM
