Discuss
wirlpool dryer
 in
Dryer Repair
not sure of age, dryer does not heat is heating element difficult to replace or what other problems could cause
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » wirlpool dryer
  #1 (permalink)
Old 04-14-2010, 03:12 PM
Junior Member
reisenbrandt is on a distinguished road
Default wirlpool dryer
Model Number: ler4634jqo   Brand: Whirlpool   Age: Less than 1 year
not sure of age, dryer does not heat is heating element difficult to replace or what other problems could cause this
Related Models
Whirlpool LER4634JT0 ELECTRIC DRYER
Whirlpool LER4634JT1 RESIDENTIAL DRYER
Whirlpool LER4634JT2 29" ELECTRIC DRYER
Whirlpool LER4634JZ0 ELECTRIC DRYER
Whirlpool LER4634PQ0 29" ELECTRIC DRYER
Whirlpool LER4634PQ1 29" ELECTRIC DRYER
Whirlpool LER4634PT0 29" ELECTRIC DRYER
Whirlpool LER4634PT1 29" ELECTRIC DRYER
Whirlpool LER5434AW0 Residential Dryer
Whirlpool LER5600HQ0 ELECTRIC DRYER
Whirlpool LER5600HZ0 ELECTRIC DRYER
Whirlpool LER5600JQ0 ELECTRIC DRYER
Whirlpool LER5600JT0 ELECTRIC DRYER
Whirlpool LER5620KQ0 RESIDENTIAL DRYER
Whirlpool LER5620KQ1 ELECTRIC DRYER
Whirlpool LER5620KQ2 29"ELECTRIC DRYER
Whirlpool LER5624BN0 ELECTRIC DRYER
Whirlpool LER5624BN1 ELECTRIC DRYER
Whirlpool LER5624BN2 ELECTRIC DRYER
Whirlpool LER5624BW0 ELECTRIC DRYER
Whirlpool LER5624BW1 ELECTRIC DRYER
Whirlpool LER5624BW2 ELECTRIC DRYER
Whirlpool LER5624DQ0 DRYERS
Whirlpool LER5624DQ1 ELECTRIC DRYER
Whirlpool LER5624DW1 ELECTRIC DRYER
Whirlpool LER5624DZ0 DRYERS
Whirlpool LER5624DZ1 ELECTRIC DRYER
Whirlpool LER5634AN0 ELECTRIC DRYERS
Whirlpool LER5634AQ0 ELECTRIC DRYER
Whirlpool LER5634AQ1 ELECTRIC DRYER
Whirlpool LER5634AQ2 ELECTRIC DRYER
Whirlpool LER5634AW0 ELECTRIC DRYERS
Whirlpool LER5634DQ1 DRYER
Whirlpool LER5634EQ0 ELECTRIC DRYER
Whirlpool LER5634EZ0 ELECTRIC DRYER
Whirlpool LER5634LG0 RESIDENTIAL DRYER
Whirlpool LER5634LQ0 29" ELECTRIC DRYER
Whirlpool LER5634LT0 RESIDENTIAL DRYER
Whirlpool LER5634LW0 RESIDENTIAL DRYER
Whirlpool LER5635LQ0 29"ELECTRIC DRYER
Whirlpool LER5635LQ1 29"ELECTRIC DRYER
Whirlpool LER5636DW0 ELECTRIC DRYER
Whirlpool LER5636DW1 ELECTRIC DRYER
Whirlpool LER5636EQ0 ELECTRIC DRYER
Whirlpool LER5636EQ1 ELECTRIC DRYER
Whirlpool LER5636EQ2 ELECTRIC DRYER
Whirlpool LER5636EQ3 ELECTRIC DRYER
Whirlpool LER5636EZ0 ELECTRIC DRYER
Whirlpool LER5636EZ01 ELECTRIC DRYER
Whirlpool LER5636EZ1 DRYER
Whirlpool LER5636EZ2 ELECTRIC DRYER
Whirlpool LER5636EZ3 ELECTRIC DRYER
Whirlpool LER5636JQ0 ELECTRIC DRYER
Whirlpool LER5636JT0 ELECTRIC DRYER
Whirlpool LER5636KQ0 RESIDENTIAL DRYER
Whirlpool LER5636KQ1 RESIDENTIAL DRYER
Whirlpool LER5636KT0 RESIDENTIAL DRYER
Whirlpool LER5636KT1 RESIDENTIAL DRYER
Whirlpool LER5636LG0
Whirlpool LER5636LQ0
Whirlpool LER5636LQ1 29"ELECTRIC DRYER
Whirlpool LER5636LT0
Whirlpool LER5636LT1 29"ELECTRIC DRYER
Whirlpool LER5636LW0
Whirlpool LER5636PQ0 29"ELECTRIC DRYER
Whirlpool LER5636PQ1 29"ELECTRIC DRYER
Whirlpool LER5636PT0 29"ELECTRIC DRYER
Whirlpool LER5636PT1 29"ELECTRIC DRYER
Whirlpool LER5638AN1 ELECTRIC DRYER
Whirlpool LER5638AN2 ELECTRIC DRYER
Whirlpool LER5638AN3 ELECTRIC DRYER
Whirlpool LER5638AW0 Residential Dryer
Whirlpool LER5638AW1 ELECTRIC DRYER
Whirlpool LER5638AW2 ELECTRIC DRYER
Whirlpool LER5638AW3 ELECTRIC DRYER
Whirlpool LER5644AN1
Whirlpool LER5644AN2 ELECTRIC DRYER
Whirlpool LER5644AW0 Residential Dryer
Whirlpool LER5644AW1
Whirlpool LER5644AW2 ELECTRIC DRYER
Whirlpool LER5644EQ0 ELECTRIC DRYER
Whirlpool LER5644EQ1 ELECTRIC DRYER
Whirlpool LER5644EQ2 ELECTRIC DRYER
Whirlpool LER5644EZ0 ELECTRIC DRYER
Whirlpool LER5644EZ1 ELECTRIC DRYER
Whirlpool LER5644EZ2 ELECTRIC DRYER
Whirlpool LER5644JQ0 DRYER
Whirlpool LER5644JQ1 DRYER
Whirlpool LER5644JQ2 RESIDENTIAL DRYER
Whirlpool LER5644JQ3 29"ELECTRIC DRYER
Whirlpool LER5644JT0 DRYER
Whirlpool LER5644JT1 DRYER
Whirlpool LER5644JT2 RESIDENTIAL DRYER
Whirlpool LER5644JT3 29"ELECTRIC DRYER
Whirlpool LER5644PQ0 29"ELECTRIC DRYER
Whirlpool LER5644PQ1 29"ELECTRIC DRYER
Whirlpool LER5700KQ0 RESIDENTIAL DRYER
Whirlpool LER5700KQ1 RESIDENTIAL DRYER
Whirlpool LER5700KT0 RESIDENTIAL DRYER
Whirlpool LER5700KT1 RESIDENTIAL DRYER
Whirlpool LER5848EQ0 ELECTRIC DRYER
Whirlpool LER5848EQ1 ELECTRIC DRYER
Whirlpool LER5848EQ2 ELECTRIC DRYER
Whirlpool LER5848EQ3 DRYERS
Whirlpool LER5848EQ4 DRYERS
Whirlpool LER5848EQ5 ELECTRIC DRYER
Whirlpool LER6611LQ0 RESIDENTIAL DRYER
Whirlpool LER6611LQ1 29"ELECTRIC DRYER
Whirlpool LER6611PQ0 29" ELECTRIC DRYER
Whirlpool LER6620PQ0 29"ELECTRIC DRYER
Whirlpool LER6620PQ1 29"ELECTRIC DRYER
Whirlpool LER6620PT0 29"ELECTRIC DRYER
Whirlpool LER6620PT1 29"ELECTRIC DRYER
Whirlpool LER6621PQ0 29" ELECTRIC DRYER
Whirlpool LER6634BN0 ELECTRIC DRYER
Whirlpool LER6634BN1 ELECTRIC DRYER
Whirlpool LER6634BN2 ELECTRIC DRYER
Whirlpool LER6634BQ0 ELECTRIC DRYER
Whirlpool LER6634BQ1 ELECTRIC DRYER
Whirlpool LER6634BQ2 ELECTRIC DRYER
  #2 (permalink)
Old 04-16-2010, 12:31 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
You will need an electric testing meter, or at least a friend with one.
Check to see that 120 volts is getting to each side of the connection block. Then unplug the machine and test continuity of the cycling thermostat, high limit thermostat and thermal cutoff. Then check continuity of the heating element. When you find something without continuity that is your problem. If one thermostat is bad I strongly suggest you replace all three.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
I have a problem with wirlpool Ultimate Care 2 gas dryer jacek.w Dryer Repair 0 02-02-2010 03:16 PM
wirlpool calipso dryer no heat jerry peterson Dryer Repair 1 12-31-2009 04:50 PM
Wirlpool Dryer Running Extremly Hot John99 Dryer Repair 0 02-18-2008 01:02 PM
Wirlpool MJS Dishwasher Repair 1 01-17-2008 07:43 PM
wirlpool dryer roger Dryer Repair 1 12-12-2007 06:56 PM
