Discuss
amana dryer won't heat
 in
Dryer Repair
My amana electric dryer won't heat up. I have tested the fuse, cutoff and element for continuity and all test
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » amana dryer won't heat
  #1 (permalink)
Old 04-11-2010, 06:57 PM
Junior Member
timjmix11 is on a distinguished road
Default amana dryer won't heat
Model Number: LEA60AW   Brand: Amana   Age: 5 - 10 years
My amana electric dryer won't heat up. I have tested the fuse, cutoff and element for continuity and all test good. Everything else works fine.
Ads By Google
Related Models
Amana LEA60AW Dryer - Ele
Amana LEA80AL Dryer - Ele
Amana LEA80AW Dryer - Ele
Amana LEA90AL Dryer - Ele
Amana LEA90AW Dryer - Ele
General Electric LEB116GR1AD Electric range
General Electric LEB116GR1WH Electric range
General Electric LEB116GT1AD Electric range
General Electric LEB116GT1WH Electric range
General Electric LEB116GT2AD Electric range
General Electric LEB116GT2WH Electric range
General Electric LEB131GR1AD Electric range
General Electric LEB131GR1WH Electric range
General Electric LEB131GT1AD Electric range
General Electric LEB131GT1WH Electric range
General Electric LEB131GT2AD Electric range
General Electric LEB131GT2WH Electric range
General Electric LEB131GY1AD Electric range
General Electric LEB131GY1WH Electric range
General Electric LEB131GY2AD Electric range
General Electric LEB131GY2WH Electric range
General Electric LEB133GS1WW Electric range
General Electric LEB316GR1AD Electric range
General Electric LEB316GR1WH Electric range
General Electric LEB316GT1AD Electric range
General Electric LEB316GT1WH Electric range
General Electric LEB316GT2AD Electric range
General Electric LEB316GT2WH Electric range
General Electric LEB316GT3AD Electric range
General Electric LEB316GT3WH Electric range
General Electric LEB316GT4AD Electric range
General Electric LEB316GT4WH Electric range
General Electric LEB316GT5AD Electric range
General Electric LEB316GT5WH Electric range
General Electric LEB326GR1AD Electric range
General Electric LEB326GR1WH Electric range
General Electric LEB326GT1AD Electric range
General Electric LEB326GT1WH Electric range
General Electric LEB326GT2AD Electric range
General Electric LEB326GT2WH Electric range
General Electric LEB326GT3AD Electric range
General Electric LEB326GT3WH Electric range
General Electric LEB326GT4AD Electric range
General Electric LEB326GT4WH Electric range
General Electric LEB326GT5AD Electric range
General Electric LEB326GT5WH Electric range
General Electric LEB327GS1WW Electric range
General Electric LEB327GT1WW Electric range
General Electric LEB327GT2WW Electric range
General Electric LEB327GT3WW Electric range
General Electric LEB327GT4WW Electric range
General Electric LEB327GT5WW Electric range
General Electric LEB356GS1BB Electric range
General Electric LEB356GT1BB Electric range
General Electric LEB356GT2BB Electric range
General Electric LEB356GT3BB Electric range
General Electric LEB356GT4BB Electric range
General Electric LEB356GY1BB Electric range
General Electric LEB356GY2BB Electric range
General Electric LEB356GY3BB Electric range
General Electric LEB356WT1WW Electric range
General Electric LEB356WT2WW Electric range
General Electric LEB356WT3WW Electric range
General Electric LEB356WT4WW Electric range
General Electric LEB356WY1WW Electric range
General Electric LEB356WY2WW Electric range
General Electric LEB356WY3WW Electric range
Whirlpool LEB6000KQ0
Whirlpool LEB6000KQ1
Whirlpool LEB6000KQ2 29"electric Dryer
Whirlpool LEB6000PQ0 29" Electric Dryer
Whirlpool LEB6000PQ1 29" Electric Dryer
Whirlpool LEB6200KQ0
Whirlpool LEB6200KQ1
Whirlpool LEB6200KQ2
Whirlpool LEB6200PQ0 29" Electric Dryer
Whirlpool LEB6200PQ1 29"electric Dryer
Whirlpool LEB6300LW0
Whirlpool LEB6300LW1 29"electric Dryer
Whirlpool LEB6300PW0 29"electric Dryer
Whirlpool LEB6300PW1 29"electric Dryer
Whirlpool LEB6400KQ0
Whirlpool LEB6400KQ1
Whirlpool LEB6400LW0
Whirlpool LEB6400LW1 29"electric Dryer
Amana LEC10AW Dryer - Ele
Admiral LEC1330AAB Surface Unit - Ele
Admiral LEC1330AAC Surface Unit - Ele
Admiral LEC1330AAW Surface Unit - Ele
Amana LEC20AW Dryer - Ele
Amana LEC30AW Dryer - Ele
Amana LEC32AW Dryer - Ele
Whirlpool LEC5000PQ0 29" Electric Dryer
Whirlpool LEC5000PQ1 29" Electric Dryer
Amana LEC50AW Dryer - Ele
Amana LEC60AW Dryer - Ele
Whirlpool LEC6646AN0
Whirlpool LEC6646AN1
Whirlpool LEC6646AN2
Whirlpool LEC6646AQ0
Whirlpool LEC6646AQ1
Whirlpool LEC6646AQ2
Whirlpool LEC6646AW0
Whirlpool LEC6646AW1
Whirlpool LEC6646AW2
Whirlpool LEC6646AZ0
Whirlpool LEC6646AZ1
Whirlpool LEC6646AZ2
Whirlpool LEC6848AN0
Whirlpool LEC6848AN1
Whirlpool LEC6848AN2
Whirlpool LEC6848AN3
Whirlpool LEC6848AQ0
Whirlpool LEC6848AQ1
Whirlpool LEC6848AQ2
Whirlpool LEC6848AQ3
Whirlpool LEC6848AW0
Whirlpool LEC6848AW1
Whirlpool LEC6848AW2
Whirlpool LEC6848AW3
  #2 (permalink)
Old 04-12-2010, 06:47 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for AMANA LEA60AW Dryer - Ele | AppliancePartsPros.com
And a manual
http://www.servicematters.com/maytag...S3200005R2.pdf
You also have the main control thermostat (cycling)
First try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the heating coil requires the full 240 volts.
If this does nothing.
Measure the voltage at the plug
L1 to L2 should be 240 volts
If OK
Unplug the unit and check the wires at the unit's terminal strip to ensure they are properly connected and none of them have burned off
If OK
Plug the unit in and check the voltage at the terminal strip. This is just in case you have a bad line cord. Be careful 240 volts is lethal.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
amana gas dryer no heat joshdogg05 Dryer Repair 3 03-04-2010 08:53 AM
Amana Gas Dryer not heat enough Jie Dryer Repair 1 03-04-2010 08:50 AM
Amana gas dryer no heat Coroner81 Dryer Repair 6 03-02-2010 08:52 AM
Amana electric dryer - no heat TimInOhio Dryer Repair 6 01-14-2010 06:48 PM
Amana Dryer - no heat jmarasco Dryer Repair 1 02-14-2009 01:06 PM
