Discuss
No Heat in Frigidaire dryer
 in
Dryer Repair
I'm dealing with a Frigidaire FDE436RES1 dryer that tumbles and runs through the timed cycles without a problem, but will
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » No Heat in Frigidaire dryer
  #1 (permalink)
Old 04-11-2010, 12:14 PM
Junior Member
mzakal is on a distinguished road
Default No Heat in Frigidaire dryer
Model Number: FDE436RES1   Brand: Frigidaire   Age: More than 10 years
I'm dealing with a Frigidaire FDE436RES1 dryer that tumbles and runs through the timed cycles without a problem, but will not heat on any setting. My wife reports that the top lid had been getting pretty hot during use lately, and it stopped heating altogether last week.
Here are the steps I have taken so far:
1. Tested wall outlet with multimeter on AC: 240V between the hots and 120V between each hot and the neutral.
2. Inspected terminal block where power cord enters dryer. All connections clean and secure.
2. Disassembled lint trap and removed a pretty big mass of lint that may have been blocking air flow. Cleaned lint trap, tube and outdoor vent. Ran dryer without vent tube. Still no heat.
3. Disconnected and tested following internal parts for continuity with multimeter set on Ohms XK1 setting:
a) Thermostat: needle moved to reading of zero
b) Thermal Limiter: also zero
c) Heating coil: zero. No breaks or weaknesses detected in the coil, though the metal pan and back panel near the top part of the coil appear scorched.
Please let me know what else I should be taking a look at in this dryer. It's from the mid 1990s, so I'm trying to go the DIY route for fear that calling a pro may cost more than the appliance is worth. Thanks in advance for your input.
Ads By Google
Related Models
Whirlpool FGP335EQ0
Whirlpool FGP335EW0
Whirlpool FGP335GN0
Whirlpool FGP335GN1
Whirlpool FGP335GQ0
Whirlpool FGP335GQ1
Whirlpool FGP335GW0
Whirlpool FGP335GW1
Whirlpool FGP335HN0
Whirlpool FGP335HQ0
Whirlpool FGP335HW0
Whirlpool FGP335VL0
Whirlpool FGP335VL1
Whirlpool FGP335VL2
Whirlpool FGP335VL3
Whirlpool FGP335VW0
Whirlpool FGP335VW1
Whirlpool FGP335VW2
Whirlpool FGP335VW3
Whirlpool FGP335YL0
Whirlpool FGP335YL1
Whirlpool FGP335YL2
Whirlpool FGP335YW0
Whirlpool FGP335YW1
Whirlpool FGP335YW2
Whirlpool FGP337GN0
Whirlpool FGP337GN1
Whirlpool FGP337GN5
Whirlpool FGP337GQ0
Whirlpool FGP337GQ1
Whirlpool FGP337GQ5
Whirlpool FGP337GW0
Whirlpool FGP337GW1
Whirlpool FGP337GW5
Whirlpool FGP337HN0
Whirlpool FGP337HQ0
Whirlpool FGP337HW0
Whirlpool FGP337KN0
Whirlpool FGP337KQ0
Whirlpool FGP337KW0
Whirlpool FGP337KW1 30" Gas Freestanding Standard Clean Range Electro
Whirlpool FGP345VL0
Whirlpool FGP345VL1
Whirlpool FGP345VL2
Whirlpool FGP345VW0
Whirlpool FGP345VW1
Whirlpool FGP345VW2
Whirlpool FGP345YL0
Whirlpool FGP345YW0
Whirlpool FGP355VL0
Whirlpool FGP355VL1
Whirlpool FGP355VL2
Whirlpool FGP355VL3
Whirlpool FGP355VW0
Whirlpool FGP355VW1
Whirlpool FGP355VW2
Whirlpool FGP355VW3
Whirlpool FGP355YL0
Whirlpool FGP355YW0
Whirlpool FGP357XL0
Whirlpool FGP357XW0
Whirlpool FGP357YL0
Whirlpool FGP357YL1
Whirlpool FGP357YL3
Whirlpool FGP357YW0
Whirlpool FGP357YW1
Whirlpool FGP357YW2
Whirlpool FGP357YW3
Frigidaire FGQ1442ES0 Frigidaire/dryer
Frigidaire FGQ332ES0 Frigidaire/gas Dryer
Frigidaire FGQB2152FE0 Frigidaire/dryer
Frigidaire FGQB4000FS0 Frigidaire/dryer
Frigidaire FGQBB30DS0 Frigidaire/dryer
Frigidaire FGR211AS0 Dryer - Frigidaire
Frigidaire FGR211AS1 Dryer - Frigidaire
Frigidaire FGR211AS2 Frigidaire/gas Dryer
Frigidaire FGR211AS3 Frigidaire/gas Dryer
Frigidaire FGR211AS4 Frigidaire/dryer
Frigidaire FGR211MAS0 Frigidaire/dryer
Frigidaire FGR221AS0 Dryer - Frigidaire
Frigidaire FGR231AS0 Dryer - Frigidaire
Frigidaire FGR231AS1 Dryer - Frigidaire
Frigidaire FGR231AS2 Frigidaire/dryer
Frigidaire FGR231AS3 Frigidaire/gas Dryer
Frigidaire FGR231AS4 Frigidaire/dryer
Frigidaire FGR231CAS4 Frigidaire/dryer
Frigidaire FGR311FS0 Frigidaire/dryer
Frigidaire FGR331AS0 Dryer - Frigidaire
Frigidaire FGR331AS1 Dryer - Frigidaire
Frigidaire FGR331KAS1 Frigidaire/gas Dryer
Frigidaire FGR341AC0 Frigidaire/dryer
Frigidaire FGR341AC1 Frigidaire/dryer
Frigidaire FGR341AS0 Dryer - Frigidaire
Frigidaire FGR341AS1 Dryer - Frigidaire
Frigidaire FGR641FS0 Frigidaire/dryer
Frigidaire FGR6600ES0 Frigidaire/dryer
Frigidaire FGR6600FS0 Frigidaire/dryer
Frigidaire FGRB5700DS0 Frigidaire/dryer
Frigidaire FGRB6600ES0 Frigidaire/dryer
Frigidaire FGRB6600FS0 Frigidaire/dryer
Frigidaire FGRB7800DS0 Frigidaire/dryer
Whirlpool FGS325RQ0 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ1 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD0 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD1 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD3 30" Gas Freestanding Self Clean Range
Whirlpool FGS335EN0
Whirlpool FGS335EQ0
Whirlpool FGS335EW0
Whirlpool FGS337GN0
Whirlpool FGS337GN1
Whirlpool FGS337GN5
Whirlpool FGS337GQ0
Whirlpool FGS337GQ1
Whirlpool FGS337GQ5
Whirlpool FGS337GQ6
Whirlpool FGS337GQ7
Whirlpool FGS337GW0
  #2 (permalink)
Old 04-12-2010, 06:04 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for FRIGIDAIRE FDE436RES1 Frg(v1) / Electric Dryer | AppliancePartsPros.com
Here is a wiring diagram. I could not find one for an RES1 so the following is for a RES2. I checked it against the one included with the parts and they look the same, just a better copy.
You may want to check for the 240 at the terminal strip. You may have a bad power cord. Just be very, very careful as 240 is lethal!!!
Use a more sensitive meter scale, if your meter has one.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open), use a higher meter scale. If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it. Can also do other weird things depending on how it sagged/shorted.
Note: You also have a hi-limit thermostat.
Item 36 in Section 1 Thermal Limiter - would shut the motor off
Item 33 in Section 1 High Limit Thermostat
Item 15 in Section 4 Control Thermostat
If the heater and all thermostats OK, unplug the unit, set it to mid cycle timed dry, high heat and check the A to L1 timer contacts, should be 0 ohms.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire dryer no heat tshug Dryer Repair 7 01-23-2011 02:16 PM
Frigidaire Dryer that won't heat huha69 Dryer Repair 7 10-18-2010 09:21 AM
Frigidaire Dryer - No heat! jbeaucha Dryer Repair 1 08-30-2009 03:29 PM
Frigidaire dryer won't heat MotormanMarc Dryer Repair 1 06-29-2009 01:08 PM
frigidaire gas dryer has no heat chevyguy Dryer Repair 0 03-01-2008 10:06 PM
