Discuss
dryer buzzing
 in
Dryer Repair
dryer is making a buzzing sound and not starting went to restart load and would not start just began the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer buzzing
  #1 (permalink)
Old 04-11-2010, 11:58 AM
Junior Member
queen is on a distinguished road
Default dryer buzzing
Brand: Roper   Age: 5 - 10 years
dryer is making a buzzing sound and not starting went to restart load and would not start just began the buzzing sound 4440sq0 model # Roper
Ads By Google
  #2 (permalink)
Old 04-12-2010, 05:34 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Cannot find any info using the given model number, please check it
Model Number Locator
Here is a site with some basic trouble shooting help. Note that most Roper's are actually Whirlpool units.
http://www.applianceaid.com/dryers.html
Try turning the drum by hand. Should turn fairly easily. If not could be the drum is jammed for some reason. You may want to try this on a couple other dryers to get a feel for it.
If it is difficult to turn run your fingers around the back and front of the tub to machine seal. To see if something has jammed between the tub and frame (bra wires are famous for this). Be careful in case the object is something sharp.
If nothing is jammed in there you will have to open it up and find the cause.
If it rotates OK.
This may take 2 people
Open the door
Manually hold the door switch closed
Push the start button and manually rotate the drum in the correct direction.
Watch your knuckles in case it starts up.
If it does start up, odds are high that you need a new motor.
Could also be that the motor is jammed solid with lint and this is preventing the Start/Run centrifugal switch from resetting (the unit is trying to start with out the motor's start winding in circuit.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Dryer Buzzing Instead of Starting gumbo2000 Dryer Repair 7 05-07-2012 11:16 AM
Dryer buzzing jmarberg Dryer Repair 0 01-20-2010 09:35 AM
Amana dryer buzzing noizes Nick Parkin Dryer Repair 3 01-01-2010 12:28 PM
Buzzing from dryer jackdaniel Dryer Repair 0 04-07-2009 07:01 PM
Kenmore Dryer keeps buzzing after cycle tomjbor Dryer Repair 0 03-21-2009 07:44 PM
