Discuss
dryer stops in the middle of a load
 in
Dryer Repair
My dryer seems to overheat during the cycle. I have checked the exhaust and it is all clear. Have actually
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer stops in the middle of a load
  #1 (permalink)
Old 06-11-2008, 07:54 PM
tmatkins tmatkins is offline
Junior Member
tmatkins is on a distinguished road
Default dryer stops in the middle of a load
Model Number: lgr5620kq1   Brand: Whirlpool   Age: 5 - 10 years
My dryer seems to overheat during the cycle. I have checked the exhaust and it is all clear. Have actually checked the temp coming out of the dryer at 200 F. What controls the actual temp of the machine (cycles)?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-11-2008, 08:28 PM
abbie abbie is offline
Senior Expert
APP Volunteer
abbie is on a distinguished road
Default
The operating thermostat control the temperature.It operates by turning the heater off and on while the dryer is tumbleing in the heat cycle.It sounds like the motor is overheating and shutting off.If you can get at the motor make sure it clean.Clear any lint build up around the motor.Once it is cleaned try the dryer.If it stops in the middle of the cycle the motor may need replacement.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer stops in middle of cycle JohnG Dryer Repair 4 04-26-2008 04:33 PM
Dryer stoppped in middle of cyc, will not restart. HELP DustinAZ Dryer Repair 4 03-05-2008 08:11 PM
When load is done, drum stops, but heat doesn't SCraven Dryer Repair 5 02-14-2008 01:50 PM
washer stops in the middle of wash cycle cnic4 Washer Repair 1 10-20-2007 04:21 AM
front load washer starts and stops immediately sunshine Washer Repair 0 10-01-2007 07:16 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
