Discuss
Dryer won't start
 in
Dryer Repair
My dryer was working fine. I went to push the button to start it and it just buzzes (the sound
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer won't start
  #1 (permalink)
Old 04-05-2010, 10:02 AM
Junior Member
VickiS is on a distinguished road
Default Dryer won't start
Model Number: FEX831CS0   Brand: Frigidaire   Age: 1 - 5 years
My dryer was working fine. I went to push the button to start it and it just buzzes (the sound which indicates the dryer cycle is complete) The dryer drum moves freely as I opened the door and turned it by ahnd and it doesn't appear to be a problem with the belt. I tried holding the button in with the door open and pushing the start button with the same results. What should I check next?
Thanks,
Vicki
Ads By Google
Related Models
Whirlpool FGP335EQ0
Whirlpool FGP335EW0
Whirlpool FGP335GN0
Whirlpool FGP335GN1
Whirlpool FGP335GQ0
Whirlpool FGP335GQ1
Whirlpool FGP335GW0
Whirlpool FGP335GW1
Whirlpool FGP335HN0
Whirlpool FGP335HQ0
Whirlpool FGP335HW0
Whirlpool FGP335VL0
Whirlpool FGP335VL1
Whirlpool FGP335VL2
Whirlpool FGP335VL3
Whirlpool FGP335VW0
Whirlpool FGP335VW1
Whirlpool FGP335VW2
Whirlpool FGP335VW3
Whirlpool FGP335YL0
Whirlpool FGP335YL1
Whirlpool FGP335YL2
Whirlpool FGP335YW0
Whirlpool FGP335YW1
Whirlpool FGP335YW2
Whirlpool FGP337GN0
Whirlpool FGP337GN1
Whirlpool FGP337GN5
Whirlpool FGP337GQ0
Whirlpool FGP337GQ1
Whirlpool FGP337GQ5
Whirlpool FGP337GW0
Whirlpool FGP337GW1
Whirlpool FGP337GW5
Whirlpool FGP337HN0
Whirlpool FGP337HQ0
Whirlpool FGP337HW0
Whirlpool FGP337KN0
Whirlpool FGP337KQ0
Whirlpool FGP337KW0
Whirlpool FGP337KW1 30" Gas Freestanding Standard Clean Range Electro
Whirlpool FGP345VL0
Whirlpool FGP345VL1
Whirlpool FGP345VL2
Whirlpool FGP345VW0
Whirlpool FGP345VW1
Whirlpool FGP345VW2
Whirlpool FGP345YL0
Whirlpool FGP345YW0
Whirlpool FGP355VL0
Whirlpool FGP355VL1
Whirlpool FGP355VL2
Whirlpool FGP355VL3
Whirlpool FGP355VW0
Whirlpool FGP355VW1
Whirlpool FGP355VW2
Whirlpool FGP355VW3
Whirlpool FGP355YL0
Whirlpool FGP355YW0
Whirlpool FGP357XL0
Whirlpool FGP357XW0
Whirlpool FGP357YL0
Whirlpool FGP357YL1
Whirlpool FGP357YL3
Whirlpool FGP357YW0
Whirlpool FGP357YW1
Whirlpool FGP357YW2
Whirlpool FGP357YW3
Frigidaire FGQ1442ES0 Frigidaire/dryer
Frigidaire FGQ332ES0 Frigidaire/gas Dryer
Frigidaire FGQB2152FE0 Frigidaire/dryer
Frigidaire FGQB4000FS0 Frigidaire/dryer
Frigidaire FGQBB30DS0 Frigidaire/dryer
Frigidaire FGR211AS0 Dryer - Frigidaire
Frigidaire FGR211AS1 Dryer - Frigidaire
Frigidaire FGR211AS2 Frigidaire/gas Dryer
Frigidaire FGR211AS3 Frigidaire/gas Dryer
Frigidaire FGR211AS4 Frigidaire/dryer
Frigidaire FGR211MAS0 Frigidaire/dryer
Frigidaire FGR221AS0 Dryer - Frigidaire
Frigidaire FGR231AS0 Dryer - Frigidaire
Frigidaire FGR231AS1 Dryer - Frigidaire
Frigidaire FGR231AS2 Frigidaire/dryer
Frigidaire FGR231AS3 Frigidaire/gas Dryer
Frigidaire FGR231AS4 Frigidaire/dryer
Frigidaire FGR231CAS4 Frigidaire/dryer
Frigidaire FGR311FS0 Frigidaire/dryer
Frigidaire FGR331AS0 Dryer - Frigidaire
Frigidaire FGR331AS1 Dryer - Frigidaire
Frigidaire FGR331KAS1 Frigidaire/gas Dryer
Frigidaire FGR341AC0 Frigidaire/dryer
Frigidaire FGR341AC1 Frigidaire/dryer
Frigidaire FGR341AS0 Dryer - Frigidaire
Frigidaire FGR341AS1 Dryer - Frigidaire
Frigidaire FGR641FS0 Frigidaire/dryer
Frigidaire FGR6600ES0 Frigidaire/dryer
Frigidaire FGR6600FS0 Frigidaire/dryer
Frigidaire FGRB5700DS0 Frigidaire/dryer
Frigidaire FGRB6600ES0 Frigidaire/dryer
Frigidaire FGRB6600FS0 Frigidaire/dryer
Frigidaire FGRB7800DS0 Frigidaire/dryer
Whirlpool FGS325RQ0 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ1 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD0 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD1 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD3 30" Gas Freestanding Self Clean Range
Whirlpool FGS335EN0
Whirlpool FGS335EQ0
Whirlpool FGS335EW0
Whirlpool FGS337GN0
Whirlpool FGS337GN1
Whirlpool FGS337GN5
Whirlpool FGS337GQ0
Whirlpool FGS337GQ1
Whirlpool FGS337GQ5
Whirlpool FGS337GQ6
Whirlpool FGS337GQ7
Whirlpool FGS337GW0
  #2 (permalink)
Old 04-05-2010, 12:37 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Vicki,
The first thing I would do is check the thermal limiter (#36 on the diagram) and the door switch (#26) for continuity.
The door switch made by Frigidaire is no longer available, but you can used the door switch made by GE as the replacement part because they are identical.
- The thermal limiter Part number: AP2108182
- The door switch Part number: AP2042725
Here are the breakdown diagrams and Replacement parts for FRIGIDAIRE FEX831CS0 Frigidaire/laundry Center | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 04-05-2010, 01:10 PM
Junior Member
Default
Quote:
Originally Posted by Gene View Post
Vicki,
Thanks Gene,
How do I test for continuity? What tool do I need? Also, it looks like the thermal limiter is behind the drum. Would this mean I would have to disassemble the dryer unit to get to it?
  #4 (permalink)
Old 04-05-2010, 02:46 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter - How To Check Continuity With Ohmmeter.
Yes, you do have to disassemble the dryer to access the thermal limiter. You have to remove the front and top panels and the drum.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
HOT POINT DRYER has power but start button doesn't start the dryer. HOT POINT Dryer Repair 2 08-01-2011 06:47 PM
whirlpol dryer won't start-just hums when I push the start button bdubois Dryer Repair 27 02-18-2010 07:36 PM
dryer start but stops when I release start button vchss360 Dryer Repair 7 10-20-2009 03:46 AM
Kenmore Dryer won't start unless PTS (push to start) button depressed and held trp Dryer Repair 1 06-07-2009 06:13 AM
dryer start button noise - dryer won't run brhodes58 Dryer Repair 6 03-14-2009 02:11 PM
