Discuss
dryer blowing gfi outlet
 in
Dryer Repair
gas dryer blowing gfi outlet what could be the problem? fuse were is it
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer blowing gfi outlet
  #1 (permalink)
Old 06-10-2008, 03:00 PM
gggreg gggreg is offline
Junior Member
gggreg is on a distinguished road
Default dryer blowing gfi outlet
Model Number: lgn2000kq0   Brand: Whirlpool   Age: 1 - 5 years
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-11-2008, 03:51 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
GFI's (Ground Fault Interrupters) are designed to protect users from electrical shock by interrupting the power to the outlet when there is a difference (leakage) in the currents in the hot and neutral lines.
The UL requirement for GFI is that it trips when there is 5 mA of leakage current while the regular 15 amps circuit breaker will do it only if it's 15 amps.
Leakage in electric motor windings to ground is very common and as long as it is less than 5 mA, GFI does not sense it. With age and dirt it leaks more and more, and finally it's getting over the GFI limit while it is still safe with properly grounded regular outlet and dryer.
I would plug the dryer (using a three prong power cord) in a regular grounded outlet with 15 or 20 Ampere circuit breaker.
Here are the break down diagrams for the Whirlpool dryer Model LGN2000KQ0
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
New ice maker valve leaks at outlet chilen Refrigerator & Freezer Repair 0 04-14-2008 04:24 PM
replacing outlet valve for ice maker stanleyn Refrigerator & Freezer Repair 1 12-17-2007 08:02 PM
Dryer keeps blowing electric panel fuse birdman Dryer Repair 7 11-22-2007 07:10 PM
Doesn't start - dryer keeps blowing fuse novas Dryer Repair 0 11-08-2007 02:57 PM
New Dryer...New Outlet?? pattyman Dryer Repair 10 10-22-2007 05:19 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
