Discuss
Replacing 279816 thermal cutoff kit
 in
Dryer Repair
Hi! I am trying to replace the thermostat- The old thermostat had a tab which connected to one connector of
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Replacing 279816 thermal cutoff kit
  #1 (permalink)
Old 06-08-2008, 10:00 AM
warrengigi warrengigi is offline
Junior Member
warrengigi is on a distinguished road
Default Replacing 279816 thermal cutoff kit
Model Number: LER8648PW0   Brand: Whirlpool   Age: 1 - 5 years
Hi! I am trying to replace the thermostat- The old thermostat had a tab which connected to one connector of the element the other end was connected to the wiring harness. The new instructions say that I will use a jumper with a male/female connector to connect one end to the wiring harness and also to one connector of the heating element. But that leaves the other end disconnected??? I am so confused. Is there anywhere I can find a picture of it correctly installed? The diagram on the instruction sheet is really little to no help. Thanks so much!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-10-2008, 11:33 PM
macoca2005 macoca2005 is offline
Junior Member
macoca2005 is on a distinguished road
Default
Quote:
I am having the same problem i wished they would have given me the same part i had before... i did not want to pay the 70.00 it cost for a repair man to come out if you found out how to do this will you pls let me know thanks michelle in alabama
  #3 (permalink)
Old 08-11-2008, 01:05 AM
abadfish66's Avatar
abadfish66 abadfish66 is offline
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
The instructions say to connect one end to the thermostat and the other end to the element, I can't find where it says to connect it to the wire harness like you mentioned???
To be used on 29” and 27” electric dryers ONLY, this kit is found most commonly on those dryers using the 'short' element, #279838.
1. Replace the thermal fuse, located higher on the side of the element 'can', by removing its two wires and screw(s)
2. Remove the safety thermostat (lower device, near the element terminals).
3. After bending the tab (that holds the original safety thermostat) out of the way, use two screws to install the new thermostat, N3390291.
4. Attach one end of the jumper wire to thermostat and the other end to the element.
If the terminal connects to the thermostat by a 3/16” terminal, then one end of the jumper wire must be cut off. Crimp onto the jumper wire the male/female combination terminal. Attach this male female combination terminal to the thermostat. Remove the 3/16” terminal from the wire harness, and crimp the supplied 1/4” female terminal onto the wire. Attach that wire to the male/female combination terminal.
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!!
Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up.
  #4 (permalink)
Old 08-11-2008, 10:23 AM
Junior Member
Default
when i unhooked the other wires from the harness. looking at the back of it, from left it had a red wire, a orange wire and another red wire
ok the first red wire went to the thermostat, the second wire was orange and it also went to the thermostat, the third wire red was attached to the element itself on the top . so using a jump wire i was figuring that the first wire would go like normal......it was red to the thermostat.
the orange wire i thought needed to be crimped and placed on the thermostat with the jumpwire and cut placed together..... the other end of the jumpwire went to where the third red wire was and was to be put together, am i wrong? I dont know how to do that or what the other pieces to the package belong to there is a silver bracket and a gold bracket if you look at the picture. this is my delima as well i said this is all new to me and i dont know what the male/female things are is this what they are talking about in the silver and gold?
  #5 (permalink)
Old 08-11-2008, 10:33 AM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
The male/female part you are looking for should be the brass one that has a female end to hook to the thermostat, and the male end to hook the wire to it, so basically you should have 2 wires coming off one terminal of the thermostat and one wire coming off the other end of the thermostat for a total of 3 wires. Does this make sense?
__________________
  #6 (permalink)
Old 08-11-2008, 10:45 AM
Junior Member
Default
Quote:
no sorry, can you pls explain the red and orange wires that come from the wiring harness?
the first thermostat has three prongs... the first one had the red wire on it the second on had the orange wire on it and the third wire went to the heating element
ok on the second new thermostat it only had two prongs i know the first one will have the first red wire on it....... what do i put on the second one the orange and jumper wire crimped together? and the other part of the jumper wire to be crimped together with the other red wire..... i know now the male and female components the brass is the female and the silver is the male?
  #7 (permalink)
Old 08-11-2008, 11:04 AM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
First look at the brass connector it has a male and female side on it. It is also called a piggyback terminal, do you see that?
__________________
  #8 (permalink)
Old 08-11-2008, 11:05 AM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
Click here....> INSULATED PIGGYBACK TERMINAL- 16-14 GA., BLUE- PKG/9- .250 PIGGBACK MALE/FEMALE
__________________
  #9 (permalink)
Old 08-11-2008, 11:06 AM
Junior Member
Default
Yes, i see it.
  #10 (permalink)
Old 08-11-2008, 11:17 AM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
Cut off one end of the jumper wire, and crimp on the brass male/female terminal. now attach one end of the jumper to the heater and the other end to the thermostat. Now the wire that came from the wire harness, cut off the end and crimp on the silver teminal and attach that to the male/female terminal you just attached to the thermostat. now the left over wire will connect to the other side of the thermostat.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Where's the thermal fuse? deburrito Dryer Repair 10 08-21-2008 07:52 PM
Help with Replacing Thermal Cutoff Kit ReagaNoah Dryer Repair 4 08-16-2008 04:17 PM
thermal limiter savage1964 Dryer Repair 1 05-05-2008 07:34 PM
thermal fuse annie9 Dryer Repair 2 05-01-2008 04:22 PM
Thermal Cut Off Keeps Breaking wbuc Dryer Repair 1 02-29-2008 02:04 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
