Discuss
Replacing 279816 thermal cutoff kit
 in
Dryer Repair
Originally Posted by abadfish66 Cut off one end of the jumper wire, and crimp on the brass male/female terminal.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Replacing 279816 thermal cutoff kit
  #11 (permalink)
Old 08-11-2008, 11:24 AM
macoca2005 macoca2005 is offline
Junior Member
macoca2005 is on a distinguished road
Default
Quote:
Originally Posted by abadfish66 View Post
Cut off one end of the jumper wire, and crimp on the brass male/female terminal. now attach one end of the jumper to the heater and the other end to the thermostat. Now the wire that came from the wire harness, cut off the end and crimp on the silver teminal and attach that to the male/female terminal you just attached to the thermostat. now the left over wire will connect to the other side of the thermostat.
you mean the left over wire from the jumper right?
the one i am placeing in the silver terminal it already has a prong on it will it not fit without any cutting?
this makes sense now
here is a picture i found of the whole thing
Part Details - WHIRLPOOL Thermal cut-off for dryer heating element 309 degrees (includes high-limit thermostat), part number: 279816
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #12 (permalink)
Old 08-11-2008, 11:29 AM
Junior Member
Default
[quote=macoca2005;29744]you mean the left over wire from the jumper right?
never mind just tried it and it will not work i will have to cut it and do it right
  #13 (permalink)
abadfish66's Avatar
abadfish66 abadfish66 is offline
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
I don't know if that terminal will fit, if it does great, if not you have to cut and crimp on the silver terminal. What color wire came from the wire harness, red or orange?
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!!
Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up.
  #14 (permalink)
Old 08-11-2008, 11:40 AM
Junior Member
Default
the orange wire.......
ok i believe i have it now wished i could post a picuture of it when i got done for everyone else to see
on the old terminal fuse it had three connections one that comes from wiring harness which is red....... that is the first one, it stays the same so i am hooking it back up in the same spot on the new one
the second wire went to a orange wire on the wiring harness
ok this is where i cut and put it on the silver prong which is the female i then take the jumper wire and cut one end of it and put it on the male prong which is brass........ then i take the brass one and the silver one and attach them together........ the other jumper wire goes on the top of the heating element
the other red wire stays the same as well it goes on the bottom of the heating element
the jumper wire is making connections where it had three connections on the first fuse down to two connections but by using the male and female connectors which is the male brass and the female silver, by putting them together it makes the same thing that was on the first one.......
I hope i am saying this right cause this is what i am fixing to do
thanks for your help
if i am doing it wrong please contact me again lol
  #15 (permalink)
Old 08-11-2008, 11:56 AM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
Sounds ok, when you get done, you will have red jumper and orange wire on one side of the thermostat and the other red wire on the other side of the thermostat.
__________________
  #16 (permalink)
Old 08-16-2008, 04:13 PM
ubersky ubersky is offline
Junior Member
ubersky is on a distinguished road
Default Drove me nuts too
I don't understand why no one can give a visual guide for this. So after reading lots of explanations on how it's to be done, I did it, and took pictures. If anyone sees anything wrong with what I did, please let me know.
First off, I set out to replace all three thermostats in the back of my Whirlpool dryer. There is one on the Fan assembly, one near the bottom of the heating tube, and one near the top.
When I got the parts from searspartsdirect.com, I gave them the parts off of the parts list for my exact model. The lady didn't tell me that the replacement for one of them would include another one, and that it would look different.
3387134 is the Fan Thermo.. replaced no problem.
3399693 is the lower Thermostat
3977393 is the upper Thermal Cut off
What I got was a different part for the lower thermo (3977767, which is a smaller thermo) and a replacement kit part 279816 for the upper.
It contains what we all know and love, the upper TCO, and a wierd 3390291 for the lower that doesn't have the same J hook connector to the Heating Element.
After talking to a local appliance repair guy, he said it would be best to go with the kit, and do not use the 3977767 part as the 279816 is a newer release, and is paried with the upper TCO.
so.. I've collected pictures of the whole process as I did it. I hope this helps anyone else doing it, or more importantly, if someone sees something I did wrong, let me know.
These are thumbnails to the images on my image hoster. You can browse the album directly if you want to. Hope the image quality is decent enough to see. Comments above the pic.
Pic of back of dryer. Fan assembly on left, Heating element on right.
Close up of the Thermal Cut off
Close up of the Thermostat
Removing the Heating Element housing
And it's off!
Close up of the Thermo. Notice the Red and Orange wires from the Dryer on the left, and the connector to the Element.
Prying off the connector
Removing wires
Inspection of the bad thermo
Removing the Thermal Cut Off
Inspection of the bad TCO
Comparing old and new, just in case
Replaced TCO.... This is definitely the easy part.
Ok, This is the replacement part for the LOWER Thermostat that came by itself. This is part number 3977767. This is not to be used. See how it has the J connector on it? You'd think this would be the right part, but noooo.
Notice the 3977767 has a smaller bulb.
Comparison of the correct part that came in the 279816 kit, part 3390291. See it's missing the J connector.
But it has the correct sized bulb.
Instructions state to bend down the tab that the old one was held in by
A little tough, but you don't need to bend it that far.
Place the new Thermo in place
And fasten with supplied screws.
Pretty neat huh?
Ok, now inspect the wires. These are the red and orange ones removed from the thermo
This is what came with the kit. One jumper wire, two connectors, one brass, one grey.
Notice something important. The jumper wire has different sized connectors. You want to leave the larger one as it will connect to the heating element where the J connector used to. Cut off the smaller one.
Snip.. no going back now.
eeeek.
Strip it.
And place the brass funny looking connector on it. Crimping it seems to be a pain in the butt, as the wires don't seem to want to be contained by the little small prongs. The larger prongs on end are to grip the insulation. Make sure it's all nice and neat.
Ok, next cut off the connector from the orange wire connected to the Dryer. Again.. slight panic moment.
Strip it, put the grey connector on it, and crimp it in place. Easier, but make sure the crimp is tight so the wire doesn't pull out.
All done.
Ok, now shove the new orange with grey connector onto the extra flappy looking thing on the brass connector. They should look like they are having...well.. inappropriate contact.
then push the little lovebirds onto the thermostat.
Then push the other end of the red jumper wire onto the Heating Element.
Then connect the remaining red wire from the Dryer onto the Thermo.
Replace the Heating Element housing, and secure.
At this point I'd re-plug the dryer in and test it. Everything looked ok to me, but we are going to run a few loads to see, and hope it doesn't burn the house down.
Please let me know if you have any comments. I hope this doesn't make the post too huge to be useful.
Mike
  #17 (permalink)
Old 08-28-2008, 10:57 AM
Admin / APP Team Admin / APP Team is offline
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
Very nice guide, Mike. Thank you. I'm sure lots of people will find it helpful.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Where's the thermal fuse? deburrito Dryer Repair 10 08-21-2008 07:52 PM
Help with Replacing Thermal Cutoff Kit ReagaNoah Dryer Repair 4 08-16-2008 04:17 PM
thermal limiter savage1964 Dryer Repair 1 05-05-2008 07:34 PM
thermal fuse annie9 Dryer Repair 2 05-01-2008 04:22 PM
Thermal Cut Off Keeps Breaking wbuc Dryer Repair 1 02-29-2008 02:04 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
