Discuss
Stumped with Dryer
 in
Dryer Repair
This is perhaps a stupid question, but I knew NOTHING about appliance repair prior to visiting this site and after
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Stumped with Dryer
  #1 (permalink)
Old 06-07-2008, 02:12 PM
MikePinLV MikePinLV is offline
Junior Member
MikePinLV is on a distinguished road
Cool Stumped with Dryer
Model Number: LEQ9508LW0   Brand: Whirlpool   Age: 1 - 5 years
This is perhaps a stupid question, but I knew NOTHING about appliance repair prior to visiting this site and after 3 days of reading posts I feel like I can build a space shuttle. Well, at least I can tell someone ELSE how it should be done. However, I can't seem to fix my dryer.
Problem: No heat
I've followed the instructions here and performed the following:
1. Circuit breaker not tripped
2. 220 volts to the outlet
3. Terminal block not damaged
4. Disconnected Thermal fuse (#7 on schematic), ohmed, = 0
5. Disconnected Heating Element (#17 on schem), ohmed, = 0
6. Disc. thermal cut-off (#9 on schem), ohmed, = 0
7. Disc. internal Thermostat (#8 on schem), ohmed, = 0
8. Disc. fixed Thermostat (#15 on schem), ohmed, = 0
I've run the cycles (low, med, high heat) thinking perhaps the thermostat functions much like a vehicle thermostat and it was perhaps shutting down the heat. However, no heat materialized in any of the cycles.
Now, for the stupid question. Is it possible the element is non-functional yet still provides resistance at the above-referenced points?
Is there perhaps something else which I have not yet located on this forum but is referenced in another thread offering additional suggestions?
Your patience and response are much appreciated. MP
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-07-2008, 02:26 PM
SublimeMasterJW SublimeMasterJW is offline
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default The timer might be bad
The power to energize the heater also goes through the timer.
Follow the large wire from the heating element up to the timer.
disconnect the wire from the timer at that terminal and do a test. put a lead from your meter on that terminal, put your other lead on any other terminal. Got a reading? Try turning the knob slowly. Got a reading yet? If not then that means inside the timer the contacts are all burned up. Replace the timer.
  #3 (permalink)
Old 06-07-2008, 02:43 PM
Junior Member
Default
Thank you for your unexpected timely response. Any idea which color that wire would be? There are 8 terminal points (as you may know) on the back of the timer. There are 2 terminal points on the heating element and one goes directly to the thermostat (I think) and the other goes under the drum. The wiring harness running up the back of the machine and dumping out into the back of the control panel is nearly impossible to trace back. If the wire I was supposed to remove from the back of the timer happens to be red, I did that.
I removed the red wire and ohmed that terminal with the thermostat. No reading
I ohmed it with the element. No reading
Is this the right wire?
If so, bad timer?
Does a bad timer continue to advance through the cycles (mine does)?
If so, and you think mine has gone kaput, would a bad timer prevent heating?
Thanks again, MP
  #4 (permalink)
Old 06-08-2008, 03:01 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Mike,
In addition to all of the above I would recommend to check the temperature switch for continuity across the terminals "AH" & "AH1" and/or "1" & "4" (two red wires).
Post your findings.
__________________
Professional appliance repair in Los Angeles, California.
  #5 (permalink)
Old 06-08-2008, 04:33 PM
Junior Member
Default
Continuity across #'s 1&4 good.
Thanks again for following up.
Any other thoughts as to what it might be?
  #6 (permalink)
Old 06-08-2008, 04:58 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Remove the black and the red wires from the timer and check for continuity across the corresponded timer terminals while the timer is in "on" position.
Check for continuity across the red wire removed from the timer and the red wire removed from the heating element.
__________________
  #7 (permalink)
Old 06-08-2008, 05:12 PM
Junior Member
Default
Continuity checks out across red and black terminals on timer.
NO continuity when reading element and red lead on timer.
Note: There are 2 red wires coming from the heating element. I detached each and checked independently. No reading.
  #8 (permalink)
Old 06-08-2008, 05:45 PM
abbie abbie is online now
Senior Expert
APP Volunteer
abbie is on a distinguished road
Default
Mike Try running the dryer in the heat cycle,while it,s running hold the timer knob and move the knob up and down and then side to side for a few minutes,then stop the dryer and check inside for heat,if so then replace timer..
__________________
  #9 (permalink)
Old 06-08-2008, 06:14 PM
Junior Member
Default
No luck. Upon taking your suggestion I did the same with the "heat shield" knob and set it at various settings while wiggling the timer knob. No heat that way either.
  #10 (permalink)
Old 06-08-2008, 07:02 PM
Senior Expert
APP Volunteer
Default
Mike let,s try going down to the dryer,s drive motor.The dryer motor has a centrifugal switch,if this is not working properly there will be no heat.To check the switch you could try tapping the motor switch lightly with a screw drivers handle, then run and check for heat.Or you could check by removing the switch from motor,and remove blue motor lead.With an ohmmeter,check between terminals 4 and 5 and between terminals 2 and 3.continuity should be present in both test.Then depress the switch plunger and check for closed contacts between terminals 4 and the black motor lead terminal on the back of the switch.Check for open contacts between terminals 2 and 3 If the switch fails to meet any of the tests replace .
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
I'm stumped and refirg keeps running Longjack Refrigerator & Freezer Repair 10 04-28-2008 02:15 PM
Stumped - GE Fridge Water Filter Bypass Plug cockatielmax Refrigerator & Freezer Repair 1 01-03-2008 06:48 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
