Discuss
GE Profile Harmony Dryer - Intermittant Blower Motor?
 in
Dryer Repair
I had the same problem with our DPGT750EC1WW GE dryer - intermittent blower/heat issue. The heat shuts down when the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » GE Profile Harmony Dryer - Intermittant Blower Motor?
  #71 (permalink)
Old 03-01-2011, 07:29 AM
Junior Member
tzjmr0 is on a distinguished road
Default Bad Blower Motor
I had the same problem with our DPGT750EC1WW GE dryer - intermittent blower/heat issue. The heat shuts down when the blower stops, it's supposed to do that or it could cause a fire, so fixing the blower motor was the action needed. I followed the steps in this thread for removing the blower motor and replacing the transistor (labeled Q1 on the pc board) and it fixed the problem.
For those not accustomed to soldering discrete components: Use solder wick to remove the solder holding the bad transistor (just ask for it at Radio Shack) to the pc board on the motor. Keep in mind that excessive heat could harm the new transistor, so don't hold the solder gun on the leads for too long while soldering. Use just a bit of flux to help the solder flow or buy solder that has flux in it. Be careful not to "bridge" solder between the leads - you only need a small bit of solder on each lead. When finished, the solder should be bright and shiny - not dull and gray. Dull and gray means a "cold" solder joint and the transistor will either not work at all or will be intermittent. If it does look dull and gray, just touch the solder gun to it again and as soon as the solder goes liquid - remove the gun immediately.
NOTE: Static electricity KILLS transistors - so don't remove the transistor from it's static-proof bag until you're seated and ready to do the work. Make sure you ground yourself on something metal immediately before picking up the new transistor, you need to be static free or the transistor will be damaged. Try to touch the leads as little as possible. NEVER walk around a room with a transistor in your bare hand.
Replacing the transistor fixed my dryer and saved me a lot of money. Many thanks to those in this thread that found the solution and passed the information on!
  #72 (permalink)
Old 03-21-2011, 01:05 PM
Junior Member
kenjiwah is on a distinguished road
Default blower motor going out again
I replaced the transistor and my dryer worked fine for a few months and then the blower motor went back to being intermittent. Now the blower comes on for 2 minutes or so and then shuts off. Any ideas on what I should do? Should I just try and replace the transistor again or should I look into getting a new motor?
  #73 (permalink)
Old 03-21-2011, 07:25 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I would suggest a new motor and, if you will order it from APP then it comes with one year warranty.
Gene,
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #74 (permalink)
Old 04-01-2011, 08:02 PM
Junior Member
sointoit is on a distinguished road
Default blower motor intermittent
My dryer was doing the same thing. I took the blower motor apart and used some electrical contact cleaner and a lint free cloth and wiped out the encoder slot. So far this has taken care of my issue.
  #75 (permalink)
Old 04-08-2011, 03:56 PM
Junior Member
lampliter is on a distinguished road
Unhappy lampliter
I have a GE Harmony as well Model #DPGT750EC1PL and drying time started to increase until no heat at all. I replaced the blower motor and it worked fine for 1 minute than all power was lost. I checked the fuse in the inverter (nicely potted board btw.... ...) and it checked fine..... both outlet safety and high limit stats ohm out at about 0.5 ohm. I am guseeing the inverter but have no clue. I did noth after replacing the blower and all power lost the elements smelled like they were cooking pretty good. Can anyone please advise short of wasting another 230 on top of 130.
  #76 (permalink)
Old 04-08-2011, 05:47 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
What does it show on the display?
Did you check the power outlet?
Here are the breakdown diagrams and Replacement parts for General Electric DPGT750EC1PL Electric dryer | AppliancePartsPros.com
__________________
  #77 (permalink)
Old 04-12-2011, 08:28 AM
Junior Member
draces is on a distinguished road
Default
Thank you for this thread. My blower stopped working last week in my Dryer, I did some searching and came accross this thread. I ordered Part number KSA733CYTA from Mouser for just $0.06 and replaced the transistor in the motor. Everything works great now. Thank you again, this thread saved me from buying a new motor.
  #78 (permalink)
Old 05-11-2011, 06:21 PM
Junior Member
Default
It seams I am still having problems with my blower motor. A did about 3 loads of laundry before it stopped working again. I replaced the Transistor again. and it worked for about 2-3 more loads. I Then replaced it again, this time it only worked for like 10 minutes. Each time it fails the blower motor will not fire up until I replace the Transistor. I think I may need a new motor all together, but I am afraid there could be something else causing it to go bad. I don't want to spend 150 on a new motor only to have that one fail on my right away too.
  #79 (permalink)
Old 06-23-2011, 07:12 AM
Junior Member
jcherrell87 is on a distinguished road
Default
I am having the same problem. I replaced the transistor on the blower. Put it back together and now have no power on the display screen. I have reset my breakers and I am getting 240V to the outlet. Where are the fuses or switches that could possibly be causing this?
  #80 (permalink)
Old 06-23-2011, 03:40 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Check the safety thermostats (#310 & #620 on the diagram) for continuity.
Check the LCD board ribbon connection to the main control board.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Profile Harmony Dryer rphaunef Dryer Repair 29 01-18-2014 06:47 PM
Help with GE Profile Harmony dryer no heat or blower southern_boy1975 Dryer Repair 0 12-17-2009 11:14 AM
GE Profile Harmony Gas Dryer DPGT750GC mikadze Dryer Repair 1 10-16-2009 01:19 PM
GE Harmony Dryer Blower Removal temce Dryer Repair 1 07-01-2009 10:38 PM
GE Profile Harmony Dryer johnmou Oven Repair (including Ranges and Cooktops) 0 06-28-2009 02:09 PM
