Discuss
GE Profile Harmony Dryer - Intermittant Blower Motor?
 in
Dryer Repair
Originally Posted by APPNewbie Disassembly is work but not crazy. I would like to know if anybody has had the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » GE Profile Harmony Dryer - Intermittant Blower Motor?
  #51 (permalink)
Old 09-07-2010, 05:36 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by APPNewbie View Post
Disassembly is work but not crazy. I would like to know if anybody has had the problem that I mentioned earlier where I do not get heat or blower. Any help would be appreciated.
What is the complete model number of the dryer?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #52 (permalink)
Old 09-07-2010, 05:45 PM
Junior Member
APPNewbie is on a distinguished road
Default
Quote:
DPGT750EC2PL
  #53 (permalink)
Old 09-08-2010, 02:59 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
DPGT750EC2PL
Check the inverter as described in the attached instruction on the first page of this thread.
Here are the breakdown diagrams and Replacement parts for General Electric DPGT750EC2PL Electric dryer | AppliancePartsPros.com
__________________
  #54 (permalink)
Old 09-08-2010, 06:30 PM
Junior Member
Default
I will do this tomorrow and post results or a question if I run into a problem. Thank you very much for response.
  #55 (permalink)
Old 09-09-2010, 04:02 PM
Junior Member
jniggli is on a distinguished road
Default
If the blower motor stops... the heat will stop shortly after. If the blower motor doesn't run at all you will most likely feel no heat at all. Sounds to me like your problem is the same as everyone elses....bad blower motor caused by a bad transistor.
  #56 (permalink)
Old 09-10-2010, 07:37 AM
Junior Member
Default
You are most likely right. Today I am going to do the diagnostics that Gene recommended. It does make sense that the heat would stop after the blower motor stopped otherwise there may be a chance of a fire if the heater just kept on. Thank you for your very much for your input.
  #57 (permalink)
Old 09-10-2010, 01:29 PM
Junior Member
Default
Ok, all the voltages test correctly according to the voltages on the "Testing the Iverter" page except for the line voltage which read 125VAC. Is that too much for the unit? Do I have a problem with the RF Choke?
  #58 (permalink)
Old 09-10-2010, 06:25 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I do not think so because it should work within 10% range. Sounds like the blower motor is the culprit.
- The blower motor Part number: AP3791484
__________________
  #59 (permalink)
Old 09-11-2010, 02:02 PM
Junior Member
Default
Ok, I ordered the part and will post back when I install it next week. Thank you for your help.
  #60 (permalink)
Old 09-18-2010, 04:23 PM
Junior Member
Default
I installed the new motor on Thursday and the dryer has been working fine ever since.(We had a build up of laundry and we put the dryer through it's paces catching up.) Thanks everyone for responding even if you did not respond to my direct question. All of the input on this forum made a difference for me.
BTW, I think I read a thread on here that indicates that the motor can be rebuilt. Should I save the motor and rebuild it for the next time it goes out?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Profile Harmony Dryer rphaunef Dryer Repair 29 01-18-2014 06:47 PM
Help with GE Profile Harmony dryer no heat or blower southern_boy1975 Dryer Repair 0 12-17-2009 11:14 AM
GE Profile Harmony Gas Dryer DPGT750GC mikadze Dryer Repair 1 10-16-2009 01:19 PM
GE Harmony Dryer Blower Removal temce Dryer Repair 1 07-01-2009 10:38 PM
GE Profile Harmony Dryer johnmou Oven Repair (including Ranges and Cooktops) 0 06-28-2009 02:09 PM
