Discuss
Timer ?????
 in
Dryer Repair
Timer will tick in the off position and not advance, put the timer on run marks and dryer will run
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Timer ?????
  #1 (permalink)
Old 06-05-2008, 05:53 PM
debrunsky debrunsky is offline
Junior Member
debrunsky is on a distinguished road
Default Timer ?????
Model Number: 110.96284810   Brand: Kenmore   Age: More than 10 years
Timer will tick in the off position and not advance, put the timer on run marks and dryer will run until door is open or unit it shut off.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-05-2008, 07:44 PM
SublimeMasterJW SublimeMasterJW is offline
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default Try this before buying anythang
Near your timer is an electronic control moisture sensing boarda dryer moisture sensing board.jpg. Yank it out of its little socket and clean the corrosion off the copper. reinstall it. Next wipe the sensors off inside the back wall of the dryer. Get all the goop off of them if any. Plug the dryer back in and try a load.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
timer does not run scotthelland Dryer Repair 0 02-15-2008 02:13 PM
timer does not run scotthelland Dryer Repair 0 02-15-2008 02:11 PM
timer gone? aefabf Dryer Repair 1 02-14-2008 03:24 AM
GE timer eddiedanner Dryer Repair 0 02-01-2008 01:19 PM
Timer again??? 4dugnlee Washer Repair 8 08-17-2007 07:45 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
