| » Frigidare Crown series heater stays on |
Model Number: CER 3600 ASO Brand: Frigidaire Age: 1 - 5 years
THe heating eliment stays on unless th e unit is unplugged. I replaced the timer thinking that would help. It didn't.. What next?
Most likely the heating element is shorted to ground. Remove the wires from both terminals on the heating element and check for continuity between each of the terminals and ground. If the readings is other than ∞ - replace the heating element.
You can find the complete instructions in the Service Manual. - The part number for the heating element assembly is AP2107129 Gene.
__________________
Professional appliance repair in Los Angeles, California. Last edited by Gene : 06-17-2008 at 02:24 PM. Reason: additional instructions |
| Display Modes | |
| Frigidare Wall Oven wii not maintain constant temp. | pcdondero | Oven Repair (including Ranges and Cooktops) | 1 | 11-12-2007 08:48 PM |
| Frigidare washer won't spin | jordan1957 | Washer Repair | 8 | 11-05-2007 06:52 PM |
| Frigidare dryer with no heat | bit1001001 | Dryer Repair | 1 | 11-02-2007 03:34 PM |
| frigidaire crown series taking too long to dry | angryhousewife34 | Dryer Repair | 1 | 08-30-2007 01:45 AM |
| Frigidare Display dim, not bright, but functional | Hill_Cumorah | Oven Repair (including Ranges and Cooktops) | 1 | 08-04-2007 12:56 AM |
