Discuss
Dryer heating and ignitor problems
 in
Dryer Repair
Hello, I have been using this forum as a guide for the last few weeks to troubleshoot various heating issues
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer heating and ignitor problems
  #1 (permalink)
Old 03-23-2010, 06:06 PM
Junior Member
clindell is on a distinguished road
Default Dryer heating and ignitor problems
Model Number: 11072932100   Brand: Kenmore   Age: 1 - 5 years
Hello,
I have been using this forum as a guide for the last few weeks to troubleshoot various heating issues I have encountered on my Kenmore gas dryer (Model: 11072932100, Serial: ML3708543). I'm not sure how old it is, it was here when we moved in. Here is a quick summary of what I have done so far.
Dryer stopped heating------>thermal fuse was open, lots of lint
Replaced fuse, removed lint-------> had heat for 4-5 loads and lost it
Checked thermal fuse again-------->had continuity
Checked thermistor-------->tested within specifications
Checked High Limit Thermostat -------> had continuity at room temp
Checked Flame Sensor ------->had continuity at room temp
Checked Heater Relay-------> open when dryer off, closed when dryer on(as expected)
Checked Coil Resistances------>Hold/Assist coil Resistance was outside spec tolerance
Replaced Both Coils -------> still no heat
Checked Igniter-------->Igniter cracked
Replaced Igniter(per enclosed instructions) ------> had heat for 2-3 loads and new Igniter Cracked
This is where I am stuck at. I would like to think that I received a faulty igniter, but I fear there is some other underlying cause here that would cause me to just be wasting my money on another igniter. I don't think it matters, but when I installed the new igniter, I had to use the old bracket, since the one included with the new one wasn't threaded properly. I'm running out of ideas and any help you guys could offer would be greatly appreciated.
Thank you,
clindell
Related Models
Kenmore 11072932100 GAS DRYER
Kenmore 11072936100 GAS DRYER
Kenmore 11072940100 AUTOMATIC WASHER
Kenmore 11072940110 AUTOMATIC WASHER
Kenmore 11072942100 DRYER
Kenmore 11072950100 AUTOMATIC WASHER
Kenmore 11072950110 AUTOMATIC WASHER
Kenmore 11072950120 AUTOMATIC WASHER
Kenmore 11072950200 AUTOMATIC WASHER
Kenmore 11072950210 AUTOMATIC WASHER
Kenmore 11072950220 AUTOMATIC WASHER
Kenmore 11072950400 AUTOMATIC WASHER
Kenmore 11072950410 AUTOMATIC WASHER
Kenmore 11072950420 AUTOMATIC WASHER
Kenmore 11072950600 AUTOMATIC WASHER
Kenmore 11072950610 AUTOMATIC WASHER
Kenmore 11072950620 AUTOMATIC WASHER
Kenmore 11072950800 AUTOMATIC WASHER
Kenmore 11072950810 AUTOMATIC WASHER
Kenmore 11072950820 AUTOMATIC WASHER
Kenmore 11072952100 DRYER
Kenmore 11072954100 DRYER
Kenmore 11072955100 AUTOMATIC WASHER
Kenmore 11072955110 AUTOMATIC WASHER
Kenmore 11072955120 AUTOMATIC WASHER
Kenmore 11072955130 ELECTRIC WASHER
Kenmore 11072955200 AUTOMATIC WASHER
Kenmore 11072955210 AUTOMATIC WASHER
Kenmore 11072955220 AUTOMATIC WASHER
Kenmore 11072955230 ELECTRIC WASHER
Kenmore 11072955400 AUTOMATIC WASHER
Kenmore 11072955410 AUTOMATIC WASHER
Kenmore 11072955420 AUTOMATIC WASHER
Kenmore 11072955430 ELECTRIC WASHER
Kenmore 11072955600 AUTOMATIC WASHER
Kenmore 11072955610 AUTOMATIC WASHER
Kenmore 11072955620 AUTOMATIC WASHER
Kenmore 11072955630 ELECTRIC WASHER
Kenmore 11072955800 AUTOMATIC WASHER
Kenmore 11072955810 AUTOMATIC WASHER
Kenmore 11072955820 AUTOMATIC WASHER
Kenmore 11072955830 ELECTRIC WASHER
Kenmore 11072956100 DRYER
Kenmore 11072960100 AUTOMATIC WASHER
Kenmore 11072960110 AUTOMATIC WASHER
Kenmore 11072960200 AUTOMATIC WASHER
Kenmore 11072960210 AUTOMATIC WASHER
Kenmore 11072960400 AUTOMATIC WASHER
Kenmore 11072960410 AUTOMATIC WASHER
Kenmore 11072960600 AUTOMATIC WASHER
Kenmore 11072960610 AUTOMATIC WASHER
Kenmore 11072960800 AUTOMATIC WASHER
Kenmore 11072960810 AUTOMATIC WASHER
Kenmore 11072965100 AUTOMATIC WASHER
Kenmore 11072965110 AUTOMATIC WASHER
Kenmore 11072965130 ELECTRIC WASHER
Kenmore 11072965140 SEARS ELECTRIC WASHER
Kenmore 11072965200 AUTOMATIC WASHER
Kenmore 11072965210 AUTOMATIC WASHER
Kenmore 11072965230 ELECTRIC WASHER
Kenmore 11072965240 SEARS ELECTRIC WASHER
Kenmore 11072965400 AUTOMATIC WASHER
Kenmore 11072965410 AUTOMATIC WASHER
Kenmore 11072965430 ELECTRIC WASHER
Kenmore 11072965440 SEARS ELECTRIC WASHER
Kenmore 11072965600 AUTOMATIC WASHER
Kenmore 11072965610 AUTOMATIC WASHER
Kenmore 11072965630 ELECTRIC WASHER
Kenmore 11072965640 SEARS ELECTRIC WASHER
Kenmore 11072965800 AUTOMATIC WASHER
Kenmore 11072965810 AUTOMATIC WASHER
Kenmore 11072965830 ELECTRIC WASHER
Kenmore 11072965840 SEARS ELECTRIC WASHER
Kenmore 11072966100 AUTOMATIC WASHER
Kenmore 11072966110 AUTOMATIC WASHER
Kenmore 11072966200 AUTOMATIC WASHER
Kenmore 11072966210 AUTOMATIC WASHER
Kenmore 11072966400 AUTOMATIC WASHER
Kenmore 11072966410 AUTOMATIC WASHER
Kenmore 11072966600 AUTOMATIC WASHER
Kenmore 11072966610 AUTOMATIC WASHER
Kenmore 11072966800 AUTOMATIC WASHER
Kenmore 11072966810 AUTOMATIC WASHER
Kenmore 11072967100 AUTOMATIC WASHER
Kenmore 11072967110 AUTOMATIC WASHER
Kenmore 11072967120 SEARS AUTOMATIC WASHER
Kenmore 11072967200 AUTOMATIC WASHER
Kenmore 11072967210 AUTOMATIC WASHER
Kenmore 11072967220 SEARS AUTOMATIC WASHER
Kenmore 11072967400 AUTOMATIC WASHER
Kenmore 11072967410 AUTOMATIC WASHER
Kenmore 11072967420 SEARS AUTOMATIC WASHER
Kenmore 11072967600 AUTOMATIC WASHER
Kenmore 11072967610 AUTOMATIC WASHER
Kenmore 11072967620 SEARS AUTOMATIC WASHER
Kenmore 11072967800 AUTOMATIC WASHER
Kenmore 11072967810 AUTOMATIC WASHER
Kenmore 11072967820 SEARS AUTOMATIC WASHER
Kenmore 11072970100 AUTOMATIC WASHER
Kenmore 11072970110 AUTOMATIC WASHER
Kenmore 11072970200 AUTOMATIC WASHER
Kenmore 11072970210 AUTOMATIC WASHER
Kenmore 11072970400 AUTOMATIC WASHER
Kenmore 11072970410 AUTOMATIC WASHER
Kenmore 11072970600 AUTOMATIC WASHER
Kenmore 11072970610 AUTOMATIC WASHER
Kenmore 11072970800 AUTOMATIC WASHER
Kenmore 11072970810 AUTOMATIC WASHER
Kenmore 11072972101 GAS DRYER
Kenmore 11072972102 GAS DRYER
Kenmore 11072972103 GAS DRYER
Kenmore 11072974100 AUTOMATIC WASHER
Kenmore 11072974101 GAS DRYER
Kenmore 11072974102 GAS DRYER
Kenmore 11072974103 GAS DRYER
Kenmore 11072974110 AUTOMATIC WASHER
Kenmore 11072974120 AUTOMATIC WASHER
Kenmore 11072974200 AUTOMATIC WASHER
Kenmore 11072974210 AUTOMATIC WASHER
Kenmore 11072974220 AUTOMATIC WASHER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
heating problems allgrace55 Dryer Repair 0 01-28-2010 08:11 AM
Ignitor Problems Johnwilson123 Oven Repair (including Ranges and Cooktops) 2 09-16-2009 01:12 PM
New Ignitor - still have problems kamduke Oven Repair (including Ranges and Cooktops) 2 06-18-2009 02:06 PM
Thermador Cooktop Ignitor problems fifties Oven Repair (including Ranges and Cooktops) 0 03-02-2009 03:58 PM
dryer starting and heating problems jbcholding Dryer Repair 4 03-15-2008 09:56 PM
