Gone from bad to worse. I'll push the start button and the dryer will turn on then when I try putting a second load 1 hour later it won't start. If I try it again 1 day later it will start. Been ongoing for about a month. Now it won't even start. It will only make a clicking sound when pushing the start button.
Rank:: Advanced Member
Originally Posted by: markbm Gone from bad to worse. I'll push the start button and the dryer will turn on then when I try putting a second load 1 hour later it won't start. If I try it again 1 day later it will start. Been ongoing for about a month. Now it won't even start. It will only make a clicking sound when pushing the start button. Well, here the story. You need a new motor, because it was getting hot and cutting off, and now, you also need the thermal fuse in the back. It is the thin white part with 2 wires coming to it. Motor part # is 279827, and the thermal fuse part # is 3390719. Tom ApplianceEducator.com - Parts
