| » Gas dryer no heat |
Model Number: ldg8424aae Brand: Maytag Age: More than 10 years
My gas dryer won't heat. Everything else works fine.Blah, Blah Blah. You've heard it before. We'll I jumped the gun and decided to just put a flame by the igniter bar to see if that got it going. Whoops. I touched the bar and zzzzzzz,
fried it. So i need a new bar for sure. Since then, i've tested everything--there is 110 to the igniter bar, and continuity everywhere else.... but i'm not getting it at the coils around the solenoid: however when i disconnect and connect them during the cycle or slide it on or off, i hear the solenoid engage as it "grabs on". it just clicks once and that's it. It is VERY hot though, so i think that's the problem, but, like i said i hear it working, so i'm not positive. |
This part probably blew out when you shorted the glowbara duct fuse.jpgIt is called a duct fuse for a reason. It mounts on the duct.
Wow, as of today, 77 views and only 1 brief reply. I was hoping for a bit more feedback. Anyway, i went my own direction and bought a new ignitor and two new coils. It turns out it was just the ignitor, it works fine with the old coils and the new ignitor. The old one must have been bad and i touched it and it reconnected then broke up. The fuse, as suggested is fine. Now I'll just vacuum up the inside, clean the vent be done.
Hope this helps someone else. |
You needed a new glowbar because you broke it. The old coils while they may work initially will fail if they get hot. Since the dryer relys on constant work from these coils I would suggest you go ahead and put them on there. Unless you just like messing with cantankerous dryers.
I had planned to replace the coils anyway, but I was reporting that it worked with just the ignitor changed. As I mentioned in the first post, the reason I had to diagnose the dryer in the first place was because it wasn't working---the ignitor was NOT working, I then physically broke it when I touched it and it re-established a connection.
| Display Modes | |
| Dryer will not heat during timed drying; will heat for short time while auto drying | mg13nj | Dryer Repair | 11 | 11-11-2008 04:50 PM |
| No Heat on Gas Dryer | benjaminM | Dryer Repair | 1 | 01-24-2008 01:51 PM |
| dryer won't heat | rmzj | Dryer Repair | 0 | 11-23-2007 01:31 PM |
| dryer will not heat? | radio963 | Dryer Repair | 1 | 11-09-2007 10:02 AM |
| Estate Dryer by Whirlpool/Dryer running but no heat | tsm11238 | Dryer Repair | 1 | 11-06-2007 11:47 AM |
