Discuss
Still no heat after replacement parts
 in
Dryer Repair
Well, I replaced the thermal fuse, cycling thermostat, and hi-limit thermostat. The dryer gets warm, but still takes 2-3 cycles
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Still no heat after replacement parts
  #1 (permalink)
Old 03-17-2010, 12:30 AM
Junior Member
SKMP9 is on a distinguished road
Default Still no heat after replacement parts
Model Number: LGQ8000   Brand: Whirlpool   Age: 5 - 10 years
Well, I replaced the thermal fuse, cycling thermostat, and hi-limit thermostat. The dryer gets warm, but still takes 2-3 cycles to dry a load. Lint filter is clean, no build up in exhaust. Can anyone give me an idea for the next step ?
Ads By Google
Related Models
Whirlpool LGQ8000HQ0
Whirlpool LGQ8000HQ1
Whirlpool LGQ8000JQ1
Whirlpool LGQ8000JQ2
Whirlpool LGQ8000JQ3
Whirlpool LGQ8000JQ4 29"gas Dryer
Whirlpool LGQ8000JQ5 29"gas Dryer
Whirlpool LGQ8100KQ0
Whirlpool LGQ8100KQ1
Whirlpool LGQ8100KT0
Whirlpool LGQ8100KT1
Whirlpool LGQ8611LG0
Whirlpool LGQ8611LG1 27"gas Dryer
Whirlpool LGQ8611LW0
Whirlpool LGQ8611LW1 27"gas Dryer
Whirlpool LGQ8611PG0 27"gas Dryer
Whirlpool LGQ8611PG1 27"gas Dryer
Whirlpool LGQ8611PG2 27"gas Dryer
Whirlpool LGQ8611PG3 27"gas Dryer
Whirlpool LGQ8611PW0 27"gas Dryer
Whirlpool LGQ8611PW1 27"gas Dryer
Whirlpool LGQ8611PW2 27"gas Dryer
Whirlpool LGQ8611PW3 27"gas Dryer
Whirlpool LGQ8621PG0 27" Gas Dryer
Whirlpool LGQ8621PG1 27" Gas Dryer
Whirlpool LGQ8621PG2 27" Gas Dryer
Whirlpool LGQ8621PG3 27" Gas Dryer
Whirlpool LGQ8621PW0 27" Gas Dryer
Whirlpool LGQ8621PW1 27" Gas Dryer
Whirlpool LGQ8621PW2 27" Gas Dryer
Whirlpool LGQ8621PW3 27" Gas Dryer
Whirlpool LGQ8800JQ0
Whirlpool LGQ8800JQ1
Whirlpool LGQ8800JQ2
Whirlpool LGQ8800JT0
Whirlpool LGQ8800JT1
Whirlpool LGQ8800JT2
Whirlpool LGQ8857HQ0
Whirlpool LGQ8857HQ1
Whirlpool LGQ8857HZ0
Whirlpool LGQ8857HZ1
Whirlpool LGQ8857JQ0
Whirlpool LGQ8857JQ1
Whirlpool LGQ8857JQ2
Whirlpool LGQ8857JQ3
Whirlpool LGQ8857JT0
Whirlpool LGQ8857JT1
Whirlpool LGQ8857JT2
Whirlpool LGQ8857JT3
Whirlpool LGQ8858HQ0
Whirlpool LGQ8858HQ1
Whirlpool LGQ8858HZ0
Whirlpool LGQ8858HZ1
Whirlpool LGQ8858JQ0
Whirlpool LGQ8858JQ2
Whirlpool LGQ8858JQ3
Whirlpool LGQ8858JT0
Whirlpool LGQ8858JT2
Whirlpool LGQ8858JT3
Whirlpool LGQ8858JZ0
Whirlpool LGQ8858JZ2
Whirlpool LGQ9030PQ0 29"gas Dryer
Whirlpool LGQ9030PQ1 29"gas Dryer
Whirlpool LGQ9508KQ0
Whirlpool LGQ9508KQ1
Whirlpool LGQ9508LG0
Whirlpool LGQ9508LW0
Whirlpool LGQ9508LW1 29"gas Dryer
Whirlpool LGQ9508PG0 29"gas Dryer
Whirlpool LGQ9508PG1 29"gas Dryer
Whirlpool LGQ9508PW0 29"gas Dryer
Whirlpool LGQ9508PW1 29"gas Dryer
Whirlpool LGQ9557KQ0
Whirlpool LGQ9557KQ1
Whirlpool LGQ9557KT0
Whirlpool LGQ9557KT1
Whirlpool LGQ9558KQ0
Whirlpool LGQ9558KQ1
Whirlpool LGQ9558KT0
Whirlpool LGQ9558KT1
Whirlpool LGQ9857LG0
Whirlpool LGQ9857LG1 29"gas Dryer
Whirlpool LGQ9857LW0
Whirlpool LGQ9857LW1 29"gas Dryer
Whirlpool LGQ9857PW0 29"gas Dryer
Whirlpool LGQ9858LG0
Whirlpool LGQ9858LG1 29"gas Dryer
Whirlpool LGQ9858LW0
Whirlpool LGQ9858LW1 29"gas Dryer
Whirlpool LGQ9858PG0 29"gas Dryer
Whirlpool LGQ9858PG1 29"gas Dryer
Whirlpool LGQ9858PW0 29"gas Dryer
Whirlpool LGQ9858PW1 29"gas Dryer
Whirlpool LGR2614BW0
Whirlpool LGR2614BW1
Whirlpool LGR2614BW2
Whirlpool LGR2614DW0
Whirlpool LGR2614DW1
Whirlpool LGR2614EW0
Frigidaire LGR331DS0 Frigidaire/dryer
Admiral LGR3330ADB Range - S/c F/s Gas
Admiral LGR3330ADW Range - S/c F/s Gas
Admiral LGR3330ADZ Range - S/c F/s Gas
Whirlpool LGR3422AN0
Whirlpool LGR3422AW0
Whirlpool LGR3424AW0
Whirlpool LGR3622BN0
Whirlpool LGR3622BW0
Whirlpool LGR3622DQ1
Whirlpool LGR3622DZ1
Whirlpool LGR3624BN2
Whirlpool LGR3624BW0
Whirlpool LGR3624BW1
Whirlpool LGR3624BW2
Whirlpool LGR3624DQ1
Whirlpool LGR3624EQ0
Whirlpool LGR3624EQ1
Whirlpool LGR3624EQ2
Whirlpool LGR3624JQ0
Whirlpool LGR3624JQ1
  #2 (permalink)
Old 03-18-2010, 05:47 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Pull out the lint screen and take out the two screws you find holding the lint chute to the top. Then take you back off again and take out the four screws holding the lint chute. Clean it out thoroughly, and clean out the blower and vent to the connection to the outside vent.
If this does not clear things up, your problem is likely in the gas burner system.
__________________
  #3 (permalink)
Old 03-20-2010, 06:50 AM
Junior Member
Default
sidfink43, thanks for the answer. That was one of the first things I did was clean the entire chute and system out. After replacing the thermostats and thermal fuse, I picked up the 2 coils that are on the gas valve for the burner. That did the trick ! Thanks again.
  #4 (permalink)
Old 03-20-2010, 09:02 AM
Senior Expert
APP Volunteer
Default
That's what it usually is. thanks for the update
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replacement parts schemata Pastormike Refrigerator & Freezer Repair 0 11-21-2009 12:16 PM
replacement parts for cooktop burl toler Oven Repair (including Ranges and Cooktops) 1 07-16-2009 06:51 PM
Replacement Parts for Thermador Cooktop davidcito989 Oven Repair (including Ranges and Cooktops) 0 01-23-2009 12:41 PM
Replacement parts fkris Dishwasher Repair 0 01-22-2009 10:16 AM
Replacement parts sawnjaw Oven Repair (including Ranges and Cooktops) 1 11-17-2007 03:50 PM
