I need help in removing the control panel, element changing instructions would be awesome
Ok, this model is coming up as a Whirlpool Duet sold under the Kenmore brand name by Sears See if this service manual does not fit your model. The console may be different but internally things should be the same. https://secured.whirlpoo...64beaa/$FILE/Duetdry.pdf
