wcla1118
#1 Posted : Monday, March 15, 2010 11:45:24 AM(UTC)
wcla1118
My Whirlpool Duet Dryer is not getting hot
I replaced the both the Thermal Fuse and the Thermistor, but no results
Should I replace the heater. If so how can I tell if it bad, so I don't have to spend the $50 to get a new one
Please help.....our clothes are all wet
#2 Posted : Monday, March 15, 2010 11:57:42 AM(UTC)
Your model number is missing a number of digits so I cannot find the correct tech sheet/wiring diagram.
First try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the heating coil requires the full 240 volts.
If this does nothing.
Measure the voltage at the plug
L1 to L2 should be 240 volts
If OK
Unplug the unit and check the wires at the unit's terminal strip to ensure they are properly connected and none of them have burned off
If OK
Plug the unit in and check the voltage at the terminal strip. This is just in case you have a bad line cord. Be careful 240 volts is lethal.
If OK
Unplug the unit and check the heating coil and thermostats etc. for continuity.
Heating coil, should be 10 ohms approximately.
Thermostats and thermal fuse all should be 0 ohms.
wcla1118
#3 Posted : Monday, March 15, 2010 12:27:42 PM(UTC)
wcla1118
The model is GEW9200 Whirlpool Duet Dryer
#4 Posted : Monday, March 15, 2010 12:50:28 PM(UTC)
Here is a tech sheet for a GEW9200LL1 which is the closest to GEW9200.
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208541833.pdf
