Discuss
Gas Dryer, stops before end of cycle
 in
Dryer Repair
My dryer will start just fine, but then for no reason it will just shut off, if you hit the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Gas Dryer, stops before end of cycle
  #1 (permalink)
Old 03-15-2010, 12:02 PM
Junior Member
Billyv is on a distinguished road
Default Gas Dryer, stops before end of cycle
Model Number: 110-70942990   Brand: Kenmore   Age: 5 - 10 years
My dryer will start just fine, but then for no reason it will just shut off, if you hit the start buttin again it starts right up, but lately it will only stay running for a few minutes before it shuts off. I replaced the timer when it first started doing it and it didn't help. Any ideas?
Ads By Google
Related Models
Kenmore 110.0  SEARS ELECTRIC EASE-O-MATIC SPRING
Kenmore 110.088732791  WASHER/DRYER LAUNDRY SYSTEM
Kenmore 110.1  SEARS ELECTRIC EASE-O-MATIC SPRING
Kenmore 110.10202000  COMPACT WASHER
Kenmore 110.10202001  WASHER
Kenmore 110.10502990  AUTOMATIC WASHER
Kenmore 110.10502991  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.10852990  AUTOMATIC WASHER
Kenmore 110.10852991  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.12202100  WASHER
Kenmore 110.12502100  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.12852100  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.13202200  WASHER
Kenmore 110.13212200  AUTOMATIC WASHER
Kenmore 110.14212200  AUTOMATIC WASHER
Kenmore 110.16101690  AUTOMATIC WASHER
Kenmore 110.16101691  AUTOMATIC WASHER
Kenmore 110.16202690  WASHER
Sears 110.16202691  AUTOMATIC WASHER
Kenmore 110.16502690  WASHER
Sears 110.16502691  AUTOMATIC WASHER
Sears 110.16502692  AUTOMATIC WASHER
Kenmore 110.16512690  WASHER
Kenmore 110.18202790  AUTOMATIC WASHER
Kenmore 110.18522790  AUTOMATIC WASHER
Kenmore 110.18522791  AUTOMATIC WASHER
Kenmore 110.18532790  AUTOMATIC WASHER
Kenmore 110.18542891  AUTOMATIC WASHER
Kenmore 110.18609890  AUTOMATIC WASHER
Kenmore 110.18702790  AUTOMATIC WASHER
Kenmore 110.18702791  AUTOMATIC WASHER
Kenmore 110.19101990  AUTOMATIC WASHER-GALAXY
Kenmore 110.19101991  AUTOMATIC WASHER-GALAXY
Kenmore 110.19101992  WASHER
Kenmore 110.19202200  AUTOMATIC WASHER-GALAXY
Kenmore 110.19422200  AUTOMATIC WASHER-GALAXY
Kenmore 110.20052991  WASHER
Kenmore 110.20052992  WASHER
Kenmore 110.20052993  AUTOMATIC WASHER
Kenmore 110.20056993  AUTOMATIC WASHER
Kenmore 110.20112000  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.2011200A  WASHER
Kenmore 110.20132000  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.20132001  WASHER
Kenmore 110.20172000  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.20172001  COMMERICAL AUTOMATIC WASHER
Kenmore 110.20272000  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.20272001  COMMERICAL AUTOMATIC WASHER
Kenmore 110.26051690  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.26058690  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.26071690  COMMERCIAL WASHER
Kenmore 110.26071691  COMMERCIAL WASHER
Kenmore 110.26622690  WASHER
Kenmore 110.26702690  AUTOMATIC WASHER
Kenmore 110.26712690  WASHER
Kenmore 110.26808690  WASHER
Kenmore 110.26809690  AUTOMATIC WASHER
Kenmore 110.26902690  AUTOMATIC WASHER
Kenmore 110.26952690  AUTOMATIC WASHER
Kenmore 110.27802690  AUTOMATIC WASHER
Kenmore 110.279119  BURNER ASSEMBLY 60 HZ
Kenmore 110.279121  BURNER ASSEMBLY 50 HZ
Kenmore 110.27982790  AUTOMATIC WASHER
Kenmore 110.2870090  AUTOMATIC WASHER
Kenmore 110.29012990  COMMERICAL AUTOMATIC WASHER
Kenmore 110.29032990  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.29072990  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.3360630  GEARCASE
Kenmore 110.3360631  GEARCASE ASSEMBLY
Kenmore 110.3363361  GEARCASE
Kenmore 110.3387617  BURNER ASSEMBLY
Kenmore 110.3397617  BURNER ASSEMBLY
Kenmore 110.3398423  GAS BURNER
Kenmore 110.3401771  LAUNDRY SUB ASSEMBLIES
Kenmore 110.3401772  BURNER ASSEMBLY
Kenmore 110.3401795  3401795 BURNER ASSEMBLY
Kenmore 110.3401796  GAS DRYER BURNER
Kenmore 110.3401797  GAS BURNER ASSEMBLY
Kenmore 110.3401798  GAS DRYER BURNER
Kenmore 110.3401799  GAS DRYER BURNER ASSEMBLY
Kenmore 110.3402243  BURNER ASSEMBLY
Kenmore 110.3402844  BURNER ASSEMBLY
Kenmore 110.3402851  BURNER ASSEMBLY
Kenmore 110.3402855  BURNER ASSEMBLY
Kenmore 110.3402856  BURNER ASSEMBLY
Kenmore 110.341566  BURNER ASSEMBLY
Kenmore 110.343114  BURNER ASSEMBLY
Kenmore 110.344612  BURNER ASSEMBLY
Kenmore 110.344613  BURNER ASSEMBLY
Kenmore 110.349621  BURNER ASSEMBLY 60 HZ
Kenmore 110.349797  BURNER ASSEMBLY 60 HZ
Kenmore 110.349798  BURNER ASSEMBLY
Kenmore 110.349799  BURNER ASSEMBLY 60 HZ
Kenmore 110.349832  BURNER ASSEMBLY 50 HZ
Kenmore 110.349833  BURNER ASSEMBLY
Kenmore 110.349834  BURNER ASSEMBLY 50 HZ
Kenmore 110.349835  BURNER ASSEMBLY 50 HZ
Kenmore 110.357176  GEARCASE ASM
Kenmore 110.358486  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358488  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358519  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358794  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.359054  GEAR CASE AND SUPER STRUCTURE
Kenmore 110.359055  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.362140  GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110.42182200  AUTOMATIC WASHER
Kenmore 110.42182201  AUTOMATIC WASHER
Kenmore 110.42722200  AUTOMATIC WASHER
Kenmore 110.42722201  AUTOMATIC WASHER
Kenmore 110.42822200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42822201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42824200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42824201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42826200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42826201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42832200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42832201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42834200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42834201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42836200  AUTOMATIC WASHER W/HORIZONTAL AXIS
  #2 (permalink)
Old 03-15-2010, 03:05 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Most likely the problem is a bad thermistor (#42 on the diagram). You can check it by measuring its resistance. The normal reading at 70°F ambient temperature suppose to be about 11.9 KOhms.
- The thermistor Part number: AP3919451
Here is the Tech sheet.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 03-15-2010, 05:50 PM
Junior Member
Default
Thanks I'll check it out, I should have added that the timer keeps running, but the drum stops and the flame stops.
  #4 (permalink)
Old 03-15-2010, 06:28 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by Billyv View Post
...I should have added that the timer keeps running, but the drum stops and the flame stops...
It does not make a big difference. Keep us posted.
__________________
  #5 (permalink)
Old 03-16-2010, 05:04 PM
Junior Member
Default
Ok I tested it and it was 13.5 Kohms. Is that ok ? One other detail I forgot is the moisture sensor drying had stopped working long before the other problem started, I never tried to fix it because we just decided to use the timer instead. I didn't think this would matter much but I figured I should throw it out there.
  #6 (permalink)
Old 03-16-2010, 07:00 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
...I tested it and it was 13.5 Kohms. Is that ok ?...
No, it's probably not.
The moister sensor diagnosis is described in the Tech sheet, posted in the previous reply.
__________________
  #7 (permalink)
Old 03-17-2010, 11:16 AM
Junior Member
Default
So should I replace the thermister? I opened up the kick panel on the bottom of the dryer and now it seems to be working a lot better, the dryer is clean I usually open it up and clean it twice a year, that tells me it is heat related, does that support the bad thermister diagnosis? I'm not too worried about the auto moisture, maybe once I get the dryer working again then I'll try to fix the auto dry.
  #8 (permalink)
Old 03-17-2010, 03:40 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
If it works fine without the kick panel but it does not with that panel in place, I would replace the thermistor.
__________________
  #9 (permalink)
Old 03-19-2010, 06:56 PM
Junior Member
Default
Thanks Gene I really appreciate the help.
  #10 (permalink)
Old 04-02-2010, 10:19 AM
Junior Member
Default
Hey Gene I just wanted to let you know you were right on with your diagnosis, I really appreciate your help you saved me a ton of money and the wife is happy too!! Thanks a bunch!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer stops mid cycle, restarts, then stops RayD Dryer Repair 4 06-07-2012 07:08 AM
Dryer stops mid-cycle ChadwickO Dryer Repair 1 10-25-2009 10:29 AM
Dryer stops mid cycle johnny dryer Dryer Repair 1 10-24-2009 04:26 PM
Dryer stops cycle before clothes are dry AmyC Dryer Repair 1 05-03-2009 06:01 PM
Dryer Stops Mid-cycle Leiter60 Dryer Repair 0 10-23-2007 05:01 AM
