Discuss
Kenmore Dryer runs but won't stop
 in
Dryer Repair
This electric dryer will run in automatic or the timed dry. The timer moves, but it does not turn off
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore Dryer runs but won't stop
  #1 (permalink)
Old 05-27-2008, 08:00 PM
Rick Day Rick Day is offline
Junior Member
Rick Day is on a distinguished road
Default Kenmore Dryer runs but won't stop
Model Number: 110.9628110   Brand: Kenmore   Age: 5 - 10 years
This electric dryer will run in automatic or the timed dry. The timer moves, but it does not turn off in either setting. I replaced the timer but it still does the same thing.
Rick Day
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-27-2008, 08:49 PM
SublimeMasterJW SublimeMasterJW is offline
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default Just a thought
Take a moment to check your model number and make sure it is posted correctly. I was looking for a small moisture sensing board mounted next to the timer on your model and your model number posted does not exist.
  #3 (permalink)
Old 05-31-2008, 08:52 PM
Junior Member
Default Model #
Sorry it took so long to get back to you - I had password problems.
The printed model # is 110.96281100 then there are type written numbers at the opposite edge of the label - 62811.
Is that the whole number?
Rick Day
  #4 (permalink)
Old 06-01-2008, 08:31 AM
Earl Dryer Earl Dryer is offline
Junior Member
Earl Dryer is on a distinguished road
Default Dryer won't stop
Sears shows a breakdown for 1109628110.
Are you sure that the dryer is heating? If so, test the resistor that is attached to timer it should read 2000-3000 ohms.
  #5 (permalink)
Old 06-01-2008, 12:37 PM
Junior Member
Default
The dryer definitely heats. I don't see a resistor attached to the timer. What does it look like?
  #6 (permalink)
Old 06-01-2008, 01:51 PM
Junior Member
Default
Go to Sears parts direct.com plugin your dryer model # and it will take you to a diagram it is part 27 (sears part #279872) they use to look like a small white (3/8 x 2)" ceramic rectangular block with a lead with female blade connector on each end. Have you tested the limit switches (Thermostats) to see if they are opening like they should. The temperature rating should be on it. Best way is electric skillet that you can set the temperature on. They should show continuity cold and open at rated temperature. (Place metal side down terminals up.) Don't get burned, happy hunting
  #7 (permalink)
Old 06-01-2008, 05:11 PM
Senior Expert
APP Volunteer
Default electric skillet method
Get a skillet hot to the temp you want and set the thermostat in it klixon side down. Be sure to flour it well on both sides. Get it good and brown and check it for continuity. Goes well with kapers and some plum jelly.
Wow setting them controls on a skillet is a great idea. When do we eat?
I have finally met a repairman I like!
  #8 (permalink)
Old 06-01-2008, 06:10 PM
Junior Member
Default
I found a resistor that looks like #27 in the diagram, but it is next to the start switch on the opposite side of the console. The resistance is over 1 Meg ohm (my meter just flashes above 1 M). Is this the same resistor?
I have replaced the thermostat several times. When it goes, the dryer takes a long time to dry - probably because they are open most of the time when they go?
  #9 (permalink)
Old 06-01-2008, 07:15 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Rick,
If we are talking about the same resistor then it's bad and has to be replaced.
The power resistor
Also I would make sure the exhaust line is not blocked. Disconnect the vent hose on the back of the dryer and run couple of loads without that hose.
- The part number for the power resistor is AP3094277
__________________
Professional appliance repair in Los Angeles, California.
  #10 (permalink)
Old 06-01-2008, 07:59 PM
Junior Member
Default
The hose is clear - cleaned it recently and can see thru it.
The resistor I have does not look like this one. It looks like a donut with an attaching flange on one end. The donut is about 1.5" in diameter with a 3/4" hole.
Is it possible that they no longer make them this shape and have replaced them with the rectangular ones?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frig runs non-stop and then coils freeze up smave46 Refrigerator & Freezer Repair 3 03-16-2008 06:09 AM
Kenmore Elite Dryer won't stop beeping gfox Dryer Repair 2 02-22-2008 11:32 PM
Kenmore dryer/no heat/doesn't stop Utili23 Dryer Repair 1 01-25-2008 04:32 PM
Dryer wont stop cycle automatically runs continously MrSchlimmer Dryer Repair 1 10-31-2007 04:43 AM
Kenmore runs but won't heat kbarr Dryer Repair 2 08-09-2007 05:26 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
