Discuss
Help with wiring on a Kenmore 70 series
 in
Dryer Repair
I have a Kenmore 70 series electric dryer that was not drying very good. Even setting it manually to 80
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Help with wiring on a Kenmore 70 series
  #1 (permalink)
Old 03-12-2010, 09:13 PM
Junior Member
kenmore70 is on a distinguished road
Question Help with wiring on a Kenmore 70 series
Model Number: 11062722101   Brand: Kenmore   Age: 5 - 10 years
I have a Kenmore 70 series electric dryer that was not drying very good. Even setting it manually to 80 minutes will leave a load of towels about 65% dry.
I took the cover off and replaced a bad thermal fuse which I am hoping will fix it but when going back to put the cover on I realized I was not sure how the ground wires were.
I am pretty certain the green with yellow stripe and thick all green wire attach to the external screw ground to the left of where the plate will be added back when putting the cover back on.
The problem is when reading my manual just to make sure I am doing it right it says the small green with yellow strip attaches to the middle silver screw and the thick all green goes to the external ground screw mentioned earlier.
I did take a picture of it before I took it off but my son unfortunately was playing with my phone and deleted it
Here is what I am working with, any help would be greatly appreciated. My outlet is 4 prong and from the manual it says g/y goes to the middle and the all green goes to the external but I am pretty sure it was not that way when I opened it.'
[IMG]http://i44.************************/9scff8.jpg[/IMG]
Related Models
Kenmore 11062722101 DRYER
Kenmore 11062722102 RESIDENTIAL DRYER
Kenmore 11062724100 ELECTRIC DRYER
Kenmore 11062724101 DRYER
Kenmore 11062802100 ELECTRIC DRYER
Kenmore 11062802101 ELECTRIC DRYER
Kenmore 11062802102 RESIDENTIAL DRYER
Kenmore 11062812100 DRYER
Kenmore 11062812101 ELECTRIC DRYER
Kenmore 11062822100 DRYER
Kenmore 11062822101 ELECTRIC DRYER
Kenmore 11062822102 RESIDENTIAL DRYER
Kenmore 11062824100 DRYER
Kenmore 11062824101 ELECTRIC DRYER
Kenmore 11062824102 RESIDENTIAL DRYER
Kenmore 11062832100 DRYER
Kenmore 11062832101 DRYER
Kenmore 11062842100 DRYER
Kenmore 11062852100 DRYER
Kenmore 11062852101 DRYER
Kenmore 11062854100 DRYER
Kenmore 11062854101 DRYER
Kenmore 11062872100 EELCTRIC DRYER
Kenmore 11062872101 ELECTRIC DRYER
Kenmore 11062872102 RESIDENTIAL DRYER
Kenmore 11062882100 DRYER
Kenmore 11062882101 DRYER
Kenmore 11062884100 DRYER
Kenmore 11062884101 DRYER
Kenmore 11062886100 DRYER
Kenmore 11062886101 DRYER
Kenmore 11062902100 ELECTRIC DRYER
Kenmore 11062904100 ELECTRIC DRYER
Kenmore 11062912100 DRYER
Kenmore 11062922100 ELECTRIC DRYER
Kenmore 11062924100 ELECTRIC DRYER
Kenmore 11062932100 DRYER
Kenmore 11062936100 DRYER
Kenmore 11062942100 DRYER
Kenmore 11062952100 DRYER
Kenmore 11062954100 DRYER
Kenmore 11062956100 DRYER
Kenmore 11062972100 DRYER
Kenmore 11062972101 ELECTRIC DRYER
Kenmore 11062972102 ELECTRIC DRYER
Kenmore 11062974100 DRYER
Kenmore 11062974101 ELECTRIC DRYER
Kenmore 11062974102 ELECTRIC DRYER
Kenmore 11062982100 DRYER
Kenmore 11062982101 ELECTRIC DRYER
Kenmore 11062982102 ELECTRIC DRYER
Kenmore 11062992100 DRYER
Kenmore 11062992101 ELECTRIC DRYER
Kenmore 11062992102 ELECTRIC DRYER
Kenmore 11062994100 DRYER
Kenmore 11062994101 ELECTRIC DRYER
Kenmore 11062994102 ELECTRIC DRYER
Kenmore 11062996100 DRYER
Kenmore 11062996101 ELECTRIC DRYER
Kenmore 11062996102 ELECTRIC DRYER
Kenmore 1106301100 KENMORE WRINGER WASHER
Kenmore 1106301101 KENMORE WRINGER WASHER
Kenmore 1106301200 KENMORE WRINGER WASHER
Kenmore 1106301201 KENMORE WRINGER WASHER
Kenmore 11063012100 ELECTRIC DRYER
Kenmore 11063012101 DRYER
Kenmore 11063012102 ELECTRIC DRYER
Kenmore 11063014100 ELECTRIC DRYER
Kenmore 11063014101 DRYER
Kenmore 11063014102 ELECTRIC DRYER
Kenmore 11063022100 DRYER
Kenmore 11063022101 ELECTRIC DRYER
Kenmore 11063022102 ELECTRIC DRYER
Kenmore 1106302300 KENMORE WRINGER WASHER
Kenmore 1106302301 KENMORE WRINGER WASHER
Kenmore 11063024100 DRYER
Kenmore 11063024101 ELECTRIC DRYER
Kenmore 11063024102 ELECTRIC DRYER
Kenmore 1106302500 KENMORE WRINGER WASHER
Kenmore 1106302501 KENMORE WRINGER WASHER
Kenmore 1106302510 KENMORE WRINGER WASHER
Kenmore 1106302800 KENMORE WRINGER WASHER
Kenmore 1106302801 KENMORE WRINGER WASHER
Kenmore 1106302802 KENMORE WRINGER WASHER
Kenmore 1106302810 KENMORE WRINGER WASHERS
Kenmore 1106302811 KENMORE WRINGER WASHER
Kenmore 1106302820 KENMORE WRINGER WASHERS
Kenmore 1106303001 KENMORE SEMI-AUTOMATIC WASHER
Kenmore 1106303002 KENMORE AUTOMATIC WASHER
Kenmore 1106303003 KENMORE WASHER
Kenmore 11063032100 ELECTRIC DRYER
Kenmore 11063032101 ELECTRIC DRYER
Kenmore 11063032102 ELECTRIC DRYER
Kenmore 11063034100 ELECTRIC DRYER
Kenmore 11063034101 ELECTRIC DRYER
Kenmore 11063034102 ELECTRIC DRYER
Kenmore 11063036100 ELECTRIC DRYER
Kenmore 11063036101 ELECTRIC DRYER
Kenmore 11063036102 ELECTRIC DRYER
Kenmore 11063042100 ELECTRIC DRYER
Kenmore 11063042101 DRYER
Kenmore 11063042102 ELECTRIC DRYER
Kenmore 1106304400 KENMORE AUTOMATIC WASHER
Kenmore 1106304401 KENMORE AUTOMATIC WASHER
Kenmore 1106304402 KENMORE AUTOMATIC WASHER
Kenmore 1106304403 KENMORE AUTOMATIC WASHER
Kenmore 1106304450 KENMORE AUTOMATIC WASHER
Kenmore 1106304451 KENMORE AUTOMATIC WASHER
Kenmore 1106304452 KENMORE AUTOMATIC WASHER
Kenmore 1106304453 KENMORE AUTOMATIC WASHER
Kenmore 1106304500 KENMORE AUTOMATIC WASHER
Kenmore 1106304501 KENMORE AUTOMATIC WASHER
Kenmore 1106304502 KENMORE AUTOMATIC WASHER
Kenmore 1106304503 KENMORE AUTOMATIC WASHER
Kenmore 1106304550 KENMORE AUTOMATIC WASHER
Kenmore 1106304551 KENMORE AUTOMATIC WASHER
Kenmore 1106304552 KENMORE AUTOMATIC WASHER
Kenmore 1106304553 KENMORE AUTOMATIC WASHER
Kenmore 1106304600 KENMORE AUTOMATIC WASHER
Kenmore 1106304601 KENMORE AUTOMATIC WASHER
  #2 (permalink)
Old 03-13-2010, 02:10 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
I took a look at the install manual and it does say that the green/yellow should go to the external screw along with the green from the line cord for a 4 wire hookup.
You could confirm this by tracing the green/yellow back, if it attaches to the frame then the above is true.
Here is your wiring diagram.
http://www.servicematters.com/docs/w...%208528192.pdf
I took the cover off and replaced a bad thermal fuse which I am hoping will fix it.
I am assuming that you check it with a meter and that is how you know it was blown, also that it was the thermal fuse by the heater.
There are some things you should check before hooking it up again, this will reduce the odds of it blowing again.
Note: that sometimes they do just blow on their own but changing it without checking other things is a gamble.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it.
If the above is OK then you will also have to replace the hi-limit as it should have regulated the temperature so the fuse did not blow.
You still have to find out why it blew.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut).
Note: That if the fuse was blown and you still had some heat then this is a symptom that the element is grounded.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore 80 Series gvazquez Washer Repair 12 04-17-2010 04:30 PM
Kenmore Series 90 howiey@yahoo.com Washer Repair 1 10-23-2009 08:02 PM
Kenmore 70 series W/D, how old? resloan Washer Repair 2 07-28-2009 12:54 PM
Kenmore 70 series setnom Washer Repair 1 05-02-2009 03:47 PM
kenmore 80 series broken heart Washer Repair 1 02-23-2009 05:38 PM
