| » Dryer does not heat, some cycles work |
Model Number: TEDX640PQ0 Brand: Whirlpool Age: 1 - 5 years
The timer on my dryer works on one of the cycles, but not the other three. My dryer runs but does not heat up. Any ideas?
Disconnect the dryer and remove the back panel. This dudea dryer element.jpg mounts on the right hand side. If it checks out good then examine the 2 limits that mount on the outside of the heater element. On is on the heater and another is above it. If the one above is blown then the dryer needs to be cleaned. Lint buildup will cause overheating and overheating will make these safetys blow.
these safety's look like this:high limit kit.jpg
my dryer isn't heated, one blue wire is loose, I cann't find where it connect to , the blue wire is close to ignitor kit, dryer's model no. is lgr2614bw2, whirlpool. please help me, i am desperate.
The flame sensorflame sensor.jpghas a white wire and a blue wire attached to it. Many times the blue wire will just fall right out of the flame sensor. From constantly shutting on and off all during the drying cycle. The terminal will melt.
Whatever that is should be pretty close to what you should get when you test good coils.
| Display Modes | |
| dryer timer auto cycles don't work | mikedudl | Dryer Repair | 0 | 04-29-2008 10:52 AM |
| erratic heat cycles | kw48116 | Heating, Ventilation, and Air Conditioning (HVAC) | 1 | 03-12-2008 05:13 PM |
| dryer runs,no heat,timer doesn't work | dcar48 | Dryer Repair | 2 | 02-04-2008 01:10 PM |
| Thumping noise, all cycles work | chewie | Washer Repair | 1 | 11-22-2007 11:20 PM |
| Delicate or Perma Press Cycles do not work | tallgirl | Washer Repair | 1 | 09-21-2007 03:33 AM |
