Discuss
Gas Dryer will not Tubmle. Burning Smell.
 in
Dryer Repair
I have a Whirlpool Gas dryer (model LGB6300LWO) that stopped tumbling and has a strong burning smell. Reading other threads
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Gas Dryer will not Tubmle. Burning Smell.
  #1 (permalink)
Old 05-26-2008, 08:18 PM
chemadis chemadis is offline
Junior Member
chemadis is on a distinguished road
Default Gas Dryer will not Tubmle. Burning Smell.
Model Number: LGB6300LWO   Brand: Whirlpool   Age: 1 - 5 years
I have a Whirlpool Gas dryer (model LGB6300LWO) that stopped tumbling and has a strong burning smell. Reading other threads it seems that the Belt could be the issue, but no one else reports the burning smell. I noticed the smell and found the dryer making the normal operating noise and was heating the clothes, but it was not tumbling. I tried running it on different settings and after turning it on/off about 10 times it started to tumble, but then stopped tumbling after I restarted it again. I am not sure if it would have restarted had it been the belt. Any assistance is greatly appreciated. The dryer is about 4 years old. Thank you!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-27-2008, 12:02 AM
Appliance repair in OC Appliance repair in OC is offline
Member
Appliance repair in OC is on a distinguished road
Default
Motor overheats and cools down
  #3 (permalink)
Old 05-27-2008, 07:22 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the problem is a bad motor. Also it is very possible there is a lot of lint built up inside which could get catch on fire and produce a smell.
- The part number for the motor is AP3094245
Here are the break down diagrams for the Whirlpool dryer Model LGB6300LW0
P.S. The belt in your dryer could be worn but it's not broken yet.
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
burning smell wastikan Washer Repair 1 02-06-2008 12:58 PM
burning smell wastikan Washer Repair 1 02-06-2008 12:49 PM
Burning smell in dryer/not spinning angeloskoubis@sbcglobal.n Dryer Repair 3 01-18-2008 04:12 PM
bosch nexxt dlx dryer (wtmc4500uc) causing 'burning' smell washer05 Dryer Repair 0 12-29-2007 11:39 AM
burning smell from inside? nanner5953 Dryer Repair 1 08-21-2007 03:00 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
