gacotton
#1 Posted : Wednesday, March 10, 2010 10:28:22 AM(UTC)
gacotton
I am replacing the front bearing AP4297334 since the slides AP2041815 AP631382 on one side are gone and the drum has eaten the bearing up. While I have the dryer disassembled, I figured the rear bearing needed checked also. the sleeve AP2621911 appears worn some, so I have decided to replace it. My question is, the o-ring AP2621539, is it a soft rubber like a standard automotive o-ring, or is it some other material. The only thing I can find that would resemble it is on the stem the sleeve slides over. And it is hard metal or plastic. I look at the bearing kit AP2619300 and the only thing I see that is white and resembles it is on the end of the stem.
#2 Posted : Wednesday, March 10, 2010 11:39:34 AM(UTC)
The new sleeve should be enough. I do not think you have to do anything with that o-ring at all.
Here are the breakdown diagrams and Replacement parts for General Electric DBVH512EF0WW Electric dryer | AppliancePartsPros.com
gacotton
#3 Posted : Wednesday, March 10, 2010 12:10:35 PM(UTC)
gacotton
Good, because they are out of the orings. should I put a little grease in the sleeve, or is this a greaseless system?
#4 Posted : Wednesday, March 10, 2010 3:24:14 PM(UTC)
I do not think it would hurt anything.
gacotton
#5 Posted : Thursday, March 11, 2010 5:00:40 AM(UTC)
gacotton
Ok, thank You for the information.
#6 Posted : Friday, March 12, 2010 3:18:38 PM(UTC)
How replace rear bearing in dryer (Dryer Repair)
by frank5 3/9/2013 6:17:43 AM(UTC)
Rear Bearing (Dryer Repair)
by Imagegenerator 7/14/2012 11:00:09 AM(UTC)
Can I replace ONLY the rear bearing assembly? (Washer Repair)
by jesseservin 1/24/2011 2:10:18 PM(UTC)
Rear Bearings Tourqe setting (Washer Repair)
by handy man maybe 12/20/2010 4:23:52 PM(UTC)
Whirlpool Rear bearing failure in les than 18 months (Washer Repair)
by krandyyy 10/2/2010 2:18:58 PM(UTC)
Rear bearing replacement - Frigidaire (Washer Repair)
by jhicks 2/21/2010 6:19:34 AM(UTC)
Installing Hotpoint Rear Bearing (Dryer Repair)
by Hopefulnow 2/13/2010 4:26:59 PM(UTC)
Frigidaire rear bearing replacement (Dryer Repair)
by Irontrader 2/5/2010 11:22:38 AM(UTC)
by Lawrence00 11/10/2009 10:11:47 AM(UTC)
front and rear bearingrace removal (Washer Repair)
by lylemuhl 10/13/2009 2:05:25 PM(UTC)
rear bearing (Dryer Repair)
by linus410 9/18/2009 10:37:08 AM(UTC)
Rear Bearing replacement (Dryer Repair)
by Randy Adams 9/11/2009 8:53:49 AM(UTC)
Kenmore Dryer Rear Bearing installation (Dryer Repair)
by kennyhat 4/4/2009 12:58:18 PM(UTC)
Rear bearing on Frigidaire (Washer Repair)
by Kenworth 8/19/2008 3:20:16 PM(UTC)
replacing rear bearing on ge dryer (Dryer Repair)
by ejwtlw-1 1/8/2008 3:47:13 PM(UTC)
