Discuss
blows fuses
 in
Dryer Repair
i'm on my third fuse, i've cleaned all the lint out of this dryer,evenn removed theblower cover. the venting is
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » blows fuses
  #1 (permalink)
Old 03-09-2010, 10:21 AM
Member
herman is on a distinguished road
Default blows fuses
Model Number: ler5634awo   Brand: Whirlpool   Age: Less than 1 year
i'm on my third fuse, i've cleaned all the lint out of this dryer,evenn removed theblower cover. the venting is very short, less then two feet. , I cleaned the blower fins. thjere really wasn't that much lint. It blows to the outside with good force. the first fuse lasted about three week the secound two abot two weeks. Any ideas would be appreaciated.
thankyou
dave
Ads By Google
Related Models
Whirlpool LER5634DQ1
Whirlpool LER5634EQ0
Whirlpool LER5634EZ0
Whirlpool LER5634LG0
Whirlpool LER5634LQ0 29" Electric Dryer
Whirlpool LER5634LT0
Whirlpool LER5634LW0
Whirlpool LER5635LQ0 29"electric Dryer
Whirlpool LER5635LQ1 29"electric Dryer
Whirlpool LER5636DW0
Whirlpool LER5636DW1
Whirlpool LER5636EQ0
Whirlpool LER5636EQ1
Whirlpool LER5636EQ2
Whirlpool LER5636EQ3
Whirlpool LER5636EZ0
Whirlpool LER5636EZ1
Whirlpool LER5636EZ2
Whirlpool LER5636EZ3
Whirlpool LER5636JQ0
Whirlpool LER5636JT0
Whirlpool LER5636KQ0
Whirlpool LER5636KQ1
Whirlpool LER5636KT0
Whirlpool LER5636KT1
Whirlpool LER5636LG0
Whirlpool LER5636LQ0
Whirlpool LER5636LQ1 29"electric Dryer
Whirlpool LER5636LT0
Whirlpool LER5636LT1 29"electric Dryer
Whirlpool LER5636LW0
Whirlpool LER5636PQ0 29"electric Dryer
Whirlpool LER5636PQ1 29"electric Dryer
Whirlpool LER5636PT0 29"electric Dryer
Whirlpool LER5636PT1 29"electric Dryer
Whirlpool LER5638AN0
Whirlpool LER5638AN1
Whirlpool LER5638AN2
Whirlpool LER5638AN3
Whirlpool LER5638AW0
Whirlpool LER5638AW1
Whirlpool LER5638AW2
Whirlpool LER5638AW3
Whirlpool LER5644AN0
Whirlpool LER5644AN1
Whirlpool LER5644AN2
Whirlpool LER5644AW0
Whirlpool LER5644AW1
Whirlpool LER5644AW2
Whirlpool LER5644EQ0
Whirlpool LER5644EQ1
Whirlpool LER5644EQ2
Whirlpool LER5644EZ0
Whirlpool LER5644EZ1
Whirlpool LER5644EZ2
Whirlpool LER5644JQ0
Whirlpool LER5644JQ1
Whirlpool LER5644JQ2
Whirlpool LER5644JQ3 29"electric Dryer
Whirlpool LER5644JT0
Whirlpool LER5644JT1
Whirlpool LER5644JT2
Whirlpool LER5644JT3 29"electric Dryer
Whirlpool LER5644PQ0 29"electric Dryer
Whirlpool LER5644PQ1 29"electric Dryer
Whirlpool LER5700KQ0
Whirlpool LER5700KQ1
Whirlpool LER5700KT0
Whirlpool LER5700KT1
Whirlpool LER5848EQ0
Whirlpool LER5848EQ1
Whirlpool LER5848EQ2
Whirlpool LER5848EQ3
Whirlpool LER5848EQ4
Whirlpool LER5848EQ5
Whirlpool LER6611LQ0
Whirlpool LER6611LQ1 29"electric Dryer
Whirlpool LER6611PQ0 29" Electric Dryer
Whirlpool LER6620PQ0 29"electric Dryer
Whirlpool LER6620PQ1 29"electric Dryer
Whirlpool LER6620PT0 29"electric Dryer
Whirlpool LER6620PT1 29"electric Dryer
Whirlpool LER6621PQ0 29" Electric Dryer
Whirlpool LER6634BN0
Whirlpool LER6634BN1
Whirlpool LER6634BN2
Whirlpool LER6634BQ0
Whirlpool LER6634BQ1
Whirlpool LER6634BQ2
Whirlpool LER6634BW0
Whirlpool LER6634BW1
Whirlpool LER6634BW2
Whirlpool LER6634DQ0
Whirlpool LER6634DQ1
Whirlpool LER6634DW0
Whirlpool LER6634DW1
Whirlpool LER6634DZ0
Whirlpool LER6634DZ1
Whirlpool LER6636PW0 29" Electric Dryer
Whirlpool LER6636PW1 29" Electric Dryer
Whirlpool LER6638DQ0
Whirlpool LER6638DQ1
Whirlpool LER6638DW0
Whirlpool LER6638DW1
Whirlpool LER6638DZ0
Whirlpool LER6638DZ1
Whirlpool LER6644DQ0
Whirlpool LER6644DQ1
Whirlpool LER6644DZ0
Whirlpool LER6644DZ1
Whirlpool LER6646BN0
Whirlpool LER6646BN1
Whirlpool LER6646BN2
Whirlpool LER6646BW0
Whirlpool LER6646BW1
Whirlpool LER6646BW2
Whirlpool LER6646DN1
Whirlpool LER6646DW1
Whirlpool LER6646PW0 29" Electric Dryer
Whirlpool LER6646PW1 29" Electric Dryer
  #2 (permalink)
Old 03-09-2010, 11:14 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Here is your wiring diagram
http://www.servicematters.com/docs/w...%203399125.pdf
Which fuse is blowing?
There are two in this unit.
One on the blower assembly and one on the heater.
__________________
  #3 (permalink)
Old 03-10-2010, 06:39 AM
Member
Default
the fuse on the blower
  #4 (permalink)
Old 03-10-2010, 07:56 AM
Senior Expert
APP Volunteer
Default
Since your problem is intermittent, it will probably be a pain to find.
Sounds like you have eliminated the vent and blower systems as a possible cause.
The first part I would replace is the operating thermostat, perhaps it is sticking closed every so often.
Another possibility is that the heating coil is sagging and touching the case every once in a while and then ope again once it cools down. The unit may then run at high heat and the thermostats do not control it. Check the inside of the heater case for signs of a short re: an arc mark. The problem with this possibility is that usually it blows the thermal fuse on the heater not the one on the blower.
Check your lint filter. Sometimes they can get coated with fabric softener residue and greatly reduce air flow. Again this is a long shot as you have checked the air flow outside and it is good.
These fuses are meant to blow due to temperature but will also blow due to high current. There is always a possibility that a motor winding is shorting every once in a while but this would also be a long shot.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
blows fuses herman Dryer Repair 1 03-09-2010 11:15 AM
microwave blows fuses kenjadog Microwave Repair 0 08-07-2009 07:38 AM
Blowing fuses YossiD Microwave Repair 1 11-13-2008 01:03 PM
Whirlpool microwave blows fuses jclawman Microwave Repair 5 01-27-2008 05:46 PM
Getting To Fuses DDY Microwave Repair 0 12-03-2007 10:34 AM
