Discuss
Thermal Fuse
 in
Dryer Repair
Can a thermal fuse blow just because it's old? I recently replaced the heat element and thermostat but did not
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Thermal Fuse
  #1 (permalink)
Old 03-07-2010, 06:08 PM
Junior Member
jy6748 is on a distinguished road
Default Thermal Fuse
Model Number: PYE3200AYW   Brand: Maytag   Age: 5 - 10 years
Can a thermal fuse blow just because it's old? I recently replaced the heat element and thermostat but did not replace the thermal fuse. After 30 days I now have a blown thermal fuse and at the same the new heat element coil wire is broken. The thermostat still tests okay per ohm meter. I used the "more dry" setting that I don't normally use when this occurred. Could the old thermal fuse have been too weak or old for the new heat element? I'm replacing the element & t-stat again along w/fuse this time but not sure if I have another problem?
Ads By Google
Related Models
Maytag PYE3200AYW Dryer - Ele
Maytag PYE3200AZW Dryer - Ele
International PYE3300AGW Dryer - Ele
International PYE3300AKW Dryer - Ele
Maytag PYE3300AYW Dryer - Ele
Maytag PYE3300AZW Dryer - Ele
Maytag PYE3360AYW Dryer - Ele
Maytag PYE4500AYQ Dryer - Ele
Maytag PYE4500AYW Dryer - Ele
Maytag PYE4500AZW Dryer - Ele
Maytag PYE4557AYW Dryer - Ele
Maytag PYE4558AYW Dryer - Ele
Maytag PYET244AYW Dryer - Ele
Maytag PYET244AZW Dryer - Ele
Maytag PYET344AYQ Dryer - Ele
Maytag PYET344AYW Dryer - Ele
Maytag PYET344AZW Dryer - Ele
Maytag PYET444AYQ Dryer - Ele
Maytag PYET444AYW Dryer - Ele
Maytag PYET444AZW Dryer - Ele
Maytag PYG1000AWW Dryer - Gas
Maytag PYG2000AWW Dryer - Gas
Maytag PYG2200AWW Dryer - Gas
International PYG2300AGW Dryer - Gas
Maytag PYG2300AWW Dryer - Gas
Maytag PYG3200AWW Dryer - Gas
Maytag PYG3250AWW Dryer - Gas
Maytag PYG3300AWW Dryer - Gas
Maytag PYG3360AWW Dryer - Gas
Maytag PYG4500AWQ Dryer - Gas
Maytag PYG4500AWW Dryer - Gas
Maytag PYG4557AWW Dryer - Gas
Maytag PYG4558AWW Dryer - Gas
International PYGS244AWW Dryer - Gas
Maytag PYGT244AWW Dryer - Gas
Maytag PYGT344AWW Dryer - Gas
Maytag PYGT444AWQ Dryer - Gas
Maytag PYGT444AWW Dryer - Gas
Amana QDO-695 Range - S/c S/i Ddraft Gas
Amana QDO-695D Range - S/c S/i Ddraft Gas
Amana QDO-695E Range - S/c S/i Ddraft Gas
Amana QDO-695F Range - S/c S/i Ddraft Gas
Amana QDO-695G Range - S/c S/i Ddraft Gas
Amana QDO-695H Range - S/c S/i Ddraft Gas
Amana QDU-838 Range - S/c S/i Ddraft Gas
Amana QDU-838A Range - S/c S/i Ddraft Gas
Amana QDU-838B Range - S/c S/i Ddraft Gas
Amana QDU-838C Range - S/c S/i Ddraft Gas
Amana QDU-838D Range - S/c S/i Ddraft Gas
Amana QDU-838G Range - S/c S/i Ddraft Gas
Amana QDU-858 Range - S/c S/i Ddraft Gas
Amana QDU-858A Range - S/c S/i Ddraft Gas
Amana QDU-858B Range - S/c S/i Ddraft Gas
Amana QDU-858C Range - S/c S/i Ddraft Gas
Amana QDU-858D Range - S/c S/i Ddraft Gas
Amana QDU-858E Range - S/c S/i Ddraft Gas
Amana QDU-858G Range - S/c S/i Ddraft Gas
Amana QDU-878 Range - S/c S/i Ddraft Gas
Amana QDU-878A Range - S/c S/i Ddraft Gas
Amana QDU-878B Range - S/c S/i Ddraft Gas
Amana QDU-966 Range - S/c S/i Ddraft Gas
Amana QDU-976 Range - S/c S/i Ddraft Gas
Amana QDU-976A Range - S/c S/i Ddraft Gas
Amana QKO-661 Range - S/c S/i Ddraft Gas
Amana QKO-661B Range - S/c S/i Ddraft Gas
Amana QKO-661C Range - S/c S/i Ddraft Gas
Amana QKO-661D Range - S/c S/i Ddraft Gas
Amana QKO-661E Range - S/c S/i Ddraft Gas
Amana QKO-751 Range - S/c S/i Ddraft Gas
Amana QKO-751A Range - S/c S/i Ddraft Gas
Amana QKU-647 Range - S/c S/i Ddraft Gas
Amana QKU-647A Range - S/c S/i Ddraft Gas
Amana QMC811 Walloven - Std Mwave Ele
Amana QMD-800 Mwave - Family Size (60 Hz)
Amana QMD-800A Mwave - Family Size (60 Hz)
Amana QMD-800B Mwave - Family Size (60 Hz)
Amana QMD-800C Mwave - Family Size (60 Hz)
Amana QMD-800D Mwave - Family Size (60 Hz)
Amana QMD-800E Mwave - Family Size (60 Hz)
Amana QMD-800G Mwave - Family Size (60 Hz)
Amana QMD-810 Mwave - Family Size (60 Hz)
Amana QMD-810A Mwave - Family Size (60 Hz)
Amana QMD800 Walloven - Std Mwave Ele
Amana QMD800D Mwave - Family Size (60 Hz)
Amana QMD810 Walloven - Std Mwave Ele
Amana R-1 Range - S/c S/i Ddraft Gas
Amana R-1H Range - S/c S/i Ddraft Gas
Amana R-1J Mwave - Family Size (60 Hz)
Amana R-2 Range - S/c S/i Ddraft Gas
Amana R-3 Mwave - Family Size (60 Hz)
Amana R0-24-8 Mwave - Mounted Over Range/wo
Whirlpool R101
Whirlpool R1011
Whirlpool R1012
Whirlpool R1013
Whirlpool R1014
Whirlpool R121
Whirlpool R1211
Whirlpool R1212
Whirlpool R1213
Whirlpool R1231
Whirlpool R141A
Whirlpool R141A1
Whirlpool R141F0
Whirlpool R141G0
Amana R15 Misc / Accessory
Whirlpool R153
Amana R15A Misc / Accessory
Amana R15L Misc / Accessory
Amana R15LA Misc / Accessory
Whirlpool R183
Whirlpool R183A
Whirlpool R183A1
Whirlpool R183A2
Whirlpool R183A3
  #2 (permalink)
Old 03-08-2010, 03:35 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Here your parts incvludes the wiring diagram.
Replacement parts for MAYTAG PYE3200AYW Dryer - Ele | AppliancePartsPros.com
Unlikely
Why did you replace both?
Which thermostat?
If the heating element broke and touched the case, the coil can heat and is not controlled by the thermostats and this can blow the thermal fuse.
You will notice that the thermal fuse (Item 5 in Section 6) comes with a hi-limit thermostat. This is because if the main control thermostat's (Item 14 in Section 5) contacts weld together causing an overheat condition the hi-limit should have regulated the coil and prevented the fuse from blowing.
How did you test it? I usually heat the face up with my soldering gun just to be sure the contacts open.
I would doubt this.
Could be just a defective heating element.
I would check/clean both the vent system and the blower wheel and then run the unit disconnected from the vent to ensure you have good air flow.
Also check the seals in the unit. It actually pulls air over the heating element, through the drum so if you have a large air leak it will suck in cold air and cause the unit to run hot.
Check that the lint filter is not coated with fabric softener residue which can reduce air flow through the system.
I would replace the heating coil and the thermal fuse along with the hi-limit thermostat.
You could confirm that the heating element broke and blew the fuse by checking the inside of the heater for evidence of it shorting to ground re: an arc/weld mark.
__________________
  #3 (permalink)
Old 03-08-2010, 02:13 PM
Junior Member
Default
Unlikely
heat element - replaced because I thought it was old, worn out and not heating well enough and the t-stat because it came with heat element.
Which thermostat?
The one mounted right above the heat element, instructions said to replace to it when replacing the element.
The heat element wire didn't appear it touched anything, I just saw it was broken, I will check for weld marks to see if touched.
I didn't test it right, I just checked for continuity/resistance.
I would doubt this.
I will check the blower, vent is clean
I will do as you suggested and thank you very much for the reply. I answered in above in this color.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thermal Fuse sweetliberty Dishwasher Repair 6 10-01-2009 10:59 AM
Where is Thermal Fuse Please dpotts Dryer Repair 3 05-17-2009 05:09 PM
thermal fuse art1028 Dryer Repair 2 03-29-2009 11:36 AM
Thermal Fuse jcolenda Dishwasher Repair 2 10-02-2008 07:55 AM
thermal fuse annie9 Dryer Repair 2 05-01-2008 03:22 PM
