Discuss
Dryer WON't Heat
 in
Dryer Repair
My gas maytag dryer doesn't always heat. I replaced the ignitor worked a couple of times, then I replaced the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer WON't Heat
  #1 (permalink)
Old 03-06-2010, 01:45 PM
Junior Member
sposh is on a distinguished road
Unhappy Dryer WON't Heat
Model Number: DG212   Brand: Maytag   Age: More than 10 years
My gas maytag dryer doesn't always heat. I replaced the ignitor worked a couple of times, then I replaced the gas sensor worked a few times. Now when I turn it on it may or may not light. I don't know what else to replace. Does the high limit switch have anything to do with it lighting? Please can someone help?
thank you in advance for your help
Ads By Google
Related Models
Maytag DG212 Dryer - Gas
Maytag DG212D Dryer - Gas
Maytag DG21CA Dryer - Gas
Maytag DG21CM Dryer - Gas
Maytag DG21CS Dryer - Gas
Maytag DG21CT Dryer - Gas
Maytag DG22CA Dryer - Gas
Maytag DG22CS Dryer - Gas
Maytag DG22CT Dryer - Gas
Maytag DG23CD Dryer - Gas
Maytag DG24CA Dryer - Gas
Maytag DG24CM Dryer - Gas
Maytag DG24CS Dryer - Gas
Maytag DG24CT Dryer - Gas
Frigidaire DG250EXD1 Wwh(v1) / Gas Dryer
Frigidaire DG250EXD4 Wwh(v2) / Gas Dryer
Frigidaire DG250EXD5 Wwh(v3) / Gas Dryer
Frigidaire DG250EXF1 Wwh(v4) / Gas Dryer
Frigidaire DG250EXF4 Wwh(v5) / Gas Dryer
Frigidaire DG250EXF5 Wwh(v6) / Gas Dryer
Frigidaire DG250EXH1 Wwh(v7) / Gas Dryer
Frigidaire DG250EXH4 Wwh(v8) / Gas Dryer
Frigidaire DG250EXH5 Wwh(v9) / Gas Dryer
Frigidaire DG250EXV1 Wwh(v10) / Gas Dryer
Frigidaire DG250EXV4 Wwh(v11) / Gas Dryer
Frigidaire DG250EXV5 Wwh(v12) / Gas Dryer
Frigidaire DG250EXW1 Wwh(v13) / Gas Dryer
Frigidaire DG250EXW4 Wwh(v14) / Gas Dryer
Frigidaire DG250EXW5 Wwh(v15) / Gas Dryer
Frigidaire DG250JXD1 Wwh(v1) / Gas Dryer
Frigidaire DG250JXF1 Wwh(v2) / Gas Dryer
Frigidaire DG250JXH1 Wwh(v3) / Gas Dryer
Frigidaire DG250JXV1 Wwh(v4) / Gas Dryer
Frigidaire DG250JXW1 Wwh(v5) / Gas Dryer
Frigidaire DG250KXD1 Wwh(v3) / 27 " Gas Dryer
Frigidaire DG250KXD2 Wwh(v3) / 27 " Gas Dryer
Frigidaire DG250KXD3 Wwh(v3) / 27 " Gas Dryer
Frigidaire DG250KXD4 Wwh(v2) / 27 " Gas Dryer
Frigidaire DG250KXH1 Wwh(v2) / 27 " Gas Dryer
Frigidaire DG250KXH2 Wwh(v2) / 27 " Gas Dryer
Frigidaire DG250KXH3 Wwh(v2) / 27 " Gas Dryer
Frigidaire DG250KXW1 Wwh(v1) / 27 " Gas Dryer
Frigidaire DG250KXW2 Wwh(v1) / 27 " Gas Dryer
Frigidaire DG250KXW3 Wwh(v1) / 27 " Gas Dryer
Frigidaire DG250KXW4 Wwh(v1) / 27 " Gas Dryer
Maytag DG25CS Dryer - Gas
Maytag DG26CA Dryer - Gas
Maytag DG26CD Dryer - Gas
Maytag DG26CS Dryer - Gas
Maytag DG26CT Dryer - Gas
Frigidaire DG27A5WAFA Gib(v2) / 27 " Gas Dryer
Frigidaire DG27A5WAFB Gib(v2) / 27 " Gas Dryer
Frigidaire DG27A5WVFA Gib(v3) / 27 " Gas Dryer
Frigidaire DG27A5WVFX Gib(v3) / 27 " Gas Dryer
Frigidaire DG27A5WXFC Gib(v2) / 27 " Gas Dryer
Frigidaire DG27A5WXFD Gib(v2) / 27 " Gas Dryer
Frigidaire DG27A5WXFE Gib(v2) / 27 " Gas Dryer
Frigidaire DG27A5WXFF Gib(v2) / 27 " Gas Dryer
Frigidaire DG27A7WVFA Gib(v1) / 27 " Gas Dryer
Frigidaire DG27A7WVFX Gib(v1) / 27 " Gas Dryer
Frigidaire DG27A7WXFB Gib(v1) / 27 " Gas Dryer
Frigidaire DG27A7WXFC Gib(v1) / 27 " Gas Dryer
Frigidaire DG27A7WXFD Gib(v1) / 27 " Gas Dryer
Frigidaire DG27A7WXFE Gib(v1) / 27 " Gas Dryer
Frigidaire DG27A8WAFA Gib(v1) / 27 " Gas Dryer
Frigidaire DG27A8WAFB Gib(v1) / 27 " Gas Dryer
Maytag DG27CA Dryer - Gas
Maytag DG27CD Dryer - Gas
Maytag DG27CS Dryer - Gas
Maytag DG27CT Dryer - Gas
Frigidaire DG27S6DTMA Gib(v1) / Gas Dryer
Frigidaire DG27S6DVFA Gib(v2) / 27 " Gas Dryer
Frigidaire DG27S6FTMA Gib(v3) / Gas Dryer
Frigidaire DG27S6WPMA Gib(v1) / Stackable Gas Dryers
Frigidaire DG27S6WPMB Gib(v2) / Stackable Gas Dryers
Frigidaire DG27S6WPMC Gib(v3) / Stackable Gas Dryers
Frigidaire DG27S6WTMA Gib(v4) / Gas Dryer
Frigidaire DG27S6WVFA Gib(v1) / 27 " Gas Dryer
Frigidaire DG27S6WVFB Gib(v1) / 27 " Gas Dryer
Frigidaire DG27S6WVFC Gib(v1) / 27 " Gas Dryer
Frigidaire DG27S6YTMA Gib(v2) / Gas Dryer
Frigidaire DG27S8WAGA Gib(v1) / 27 " Gas Dryer
Frigidaire DG27S8WAGB Gib(v1) / 27 " Gas Dryer
Frigidaire DG27T3WAFA Gib(v3) / 27 " Gas Dryer
Frigidaire DG27T3WAFB Gib(v3) / 27 " Gas Dryer
Frigidaire DG27T3WVFA Gib(v2) / 27 " Gas Dryer
Frigidaire DG27T3WVFX Gib(v2) / 27 " Gas Dryer
Frigidaire DG27T3WXFB Gib(v3) / 27 " Gas Dryer
Frigidaire DG27T3WXFC Gib(v3) / 27 " Gas Dryer
Frigidaire DG27T3WXFD Gib(v3) / 27 " Gas Dryer
Frigidaire DG27T3WXFE Gib(v3) / 27 " Gas Dryer
Frigidaire DG28A3WSFA Gib(v1) / Gas Dryer
Frigidaire DG28A5DTFB Gib(v10) / 28 " Dryer
Frigidaire DG28A5WTFA Gib(v1) / Gas Dryer
Frigidaire DG28A5WTFB Gib(v6) / 28 " Dryer
Frigidaire DG28A5YTFB Gib(v8) / 28 " Dryer
Frigidaire DG28A6WSFA Gib(v2) / Gas Dryer
Frigidaire DG28A7DTFB Gib(v4) / 28 " Dryer
Frigidaire DG28A7WTFA Gib(v2) / Gas Dryer
Frigidaire DG28A7WTFB Gib(v2) / 28 " Dryer
Frigidaire DG28T2WSFA Gib(v3) / Gas Dryer
Frigidaire DG28T3DTFB Gib(v14) / 28 " Dryer
Frigidaire DG28T3WTFA Gib(v3) / Gas Dryer
Frigidaire DG28T3WTFB Gib(v12) / 28 " Dryer
Maytag DG300 Dryer - Gas
Amana DG3020 Washer - Top Loading
Amana DG3021 Washer - Top Loading
Maytag DG303 Dryer - Gas
Maytag DG303D Dryer - Gas
Maytag DG306 Dryer - Gas
Maytag DG307 Dryer - Gas
Maytag DG308 Dryer - Gas
Maytag DG309 Dryer - Gas
Maytag DG30CA Dryer - Gas
Maytag DG30CM Dryer - Gas
Maytag DG30CMD Dryer - Gas
Maytag DG30CT Dryer - Gas
Maytag DG312 Dryer - Gas
Maytag DG312D Dryer - Gas
Maytag DG313 Dryer - Gas
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) jtdesignsca Dryer Repair 3 01-17-2013 12:06 PM
Clothes dryer runs, but doest not heat (Dryer no heat yzhong Dryer Repair 5 10-29-2009 04:54 PM
Dryer will not heat. It tumbles and cycles but it will not emit any heat. agentsmith0505 Dryer Repair 0 10-14-2009 09:44 AM
Gas Dryer tumbles but won't heat. Timer does not move when dryer is started. NEAL AMES Dryer Repair 1 01-02-2009 06:40 PM
Dryer will not heat during timed drying; will heat for short time while auto drying mg13nj Dryer Repair 11 11-11-2008 03:50 PM
