| » Dryer Quit |
Model Number: PYE4500AYW Brand: Maytag Age: 5 - 10 years
During cycle, dryer quit working and will not turn back on. Making a ticking noise at the start/select knob. Has the timer and or the resistor gone bad and need replacing. Am I on the right track or could the problem be somewhere else? If I am on the correct path can one or the other parts be replaced or both?
Replacement parts for MAYTAG PYE4500AYW Dryer - Ele | AppliancePartsPros.com Unfortunately the included wiring diagram is for a gas unit. Following is a link to a PYET444AYW, it should be close to your unit. Would be best to use the one that should have come with it, it is often inside the control console. Wiring information (series 15 elec) replacement parts for MAYTAG PYET444AYW Dryer - Ele | AppliancePartsPros.com Making a ticking noise at the start/select knob. Has the timer and or the resistor gone bad and need replacing. Timer is possible. I doubt it is the resistor as the noise you hear is the probably the timer motor so the resistor is OK. Am I on the right track or could the problem be somewhere else? At the top of my list would be the thermal fuse on the heater assembly, see Item 5 in Section 5. Unplug the unit and check it with a meter, should be 0 ohms. Be sure to unplug one side of it when checking it. If it is blown you have to find out what caused it to go. Note: that sometimes they do just blow on their own but changing it without checking other things is a gamble. Check the heating coil. Unplug the unit and both wires to the coil. Check it with a meter, should be around 12 ohms. Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it. If the above is OK then you will also have to replace the hi-limit as it should have regulated the temperature so the fuse did not blow. You still have to find out why it blew. Check the seal (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot. Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow. Check/clean your vent system. Check/clean the blower wheel. If all OK you may want to replace the cycling thermostat as it's contacts may not be opening. If you do not own a meter, I would suggest you purchase a one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long. If it saves ordering one unnecessary part it has paid for itself and you end up owning a useful tool. Most places will not let you return electrical parts so if you order it, you own it. A couple things to watch when measuring ohms and continuity 1. Always remove power from the machine otherwise you could blow your meter. 2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path. 3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale's dynamic range. There is a good STICKY at the start of this forum about it's use.
__________________
| Display Modes | |
| Dryer quit running | kodak | Dryer Repair | 2 | 02-05-2010 07:52 PM |
| my dryer just quit working | nkohler | Dryer Repair | 1 | 11-11-2009 04:50 AM |
| Dryer just quit | Tranny1957 | Dryer Repair | 2 | 02-05-2009 09:33 AM |
| GE dryer quit running | jbgipson | Dryer Repair | 2 | 08-18-2008 04:34 AM |
| Dryer quit heating | sdavisokie | Dryer Repair | 1 | 05-23-2008 06:26 PM |
