robbinsgr1
#1 Posted : Friday, March 5, 2010 5:42:25 AM(UTC)
robbinsgr1
Discovered the lightbulb had broken, not burned out. replaced with Lowes 7w appliance bulb. All electronics light up and are adjustable on the control panel when plugged in. When door is closed, the light does not shut off and start button will not engage the dryer. Just get the triple beep sound.
Doesn't seem to be a circuit breaker, thinking its the door sensor switch. Any way I can prove this before purchasing a replacement piece?
#2 Posted : Saturday, March 6, 2010 12:53:40 AM(UTC)
Replacement parts for GEW9250 models | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208558722.pdf
Unplug the unit and check the switch with a meter.
