Discuss
Dryer Banging
 in
Dryer Repair
Hi, I have a Frigidaire dryer model # FDE336RES2 that has been in storage for a couple of years. After reconnecting
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer Banging
  #1 (permalink)
Old 05-21-2008, 02:04 PM
skylarbeach skylarbeach is offline
Junior Member
skylarbeach is on a distinguished road
Default Dryer Banging
Model Number: FDE336RES2   Brand: Frigidaire   Age: 5 - 10 years
I have a Frigidaire dryer model # FDE336RES2 that has been in storage for a couple of years. After reconnecting everything seems to work fine with the exception of a continuous banging noise from the drum. When the dryer is off and I spin the drum by hand it appears to be in the same spot every turn of the drum.
Any ideas with detailed instructions would be appreciated.
Thanks,
Greg
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-21-2008, 02:43 PM
SublimeMasterJW SublimeMasterJW is offline
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default Inspect the dryer
No telling who or what has been living in that dryer while it has been sitting up. I would pop the toptop removal.jpg and remove the front. Get the tub out and inspect the front slides and the rear center bearing. I would remove any lint or dust from inside the dryer and make sure the idler is oiled. Lithium grease is a good thing for the rear bearing.
  #3 (permalink)
Old 05-21-2008, 03:48 PM
Junior Member
Default
Got the top and front off no problem. How do you get the belt that's around the tub off? Can't get the tub out with it on right? Also there is a metal plate behind the tub that 3 screws from inside the tub fasten to. The plate is wobbly, is that the way it should be or should it be solid?
Thanks much for your help,
Greg
  #4 (permalink)
Old 05-21-2008, 05:44 PM
Senior Expert
APP Volunteer
Default Metal plate should be tight.
You gotta take the idler loose using the access panel in back. Take a note how the idler goes. Once you get it removed grab the belt on top of the drum and yank the belt upwards about 2 inchs using it like a handle. The drum should come on out the front then.
  #5 (permalink)
Old 05-21-2008, 06:05 PM
Junior Member
Default
Got it figured out!
Tore everything apart, cleaned and put back together and dryer is working fine.
Thank you very much for your help,
Greg
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
banging,walking maytag performa cwilson Washer Repair 7 12-06-2007 11:30 AM
dryer drum banging noise a2home Dryer Repair 1 10-12-2007 03:14 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
