Discuss
Maytag SG1000 dead panel update
 in
Dryer Repair
In another thread you can see more information on this issue. I didn't get a response from my update inquiry
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag SG1000 dead panel update
  #1 (permalink)
Old 03-02-2010, 03:53 PM
Junior Member
jefinch is on a distinguished road
Default Maytag SG1000 dead panel update
Model Number: SG1000   Brand: Maytag   Age: More than 10 years
In another thread you can see more information on this issue. I didn't get a response from my update inquiry in that thread so decided to try starting a new one. The current status is that I installed a new circuit board as was the suggested first step from this forum. There was no change in conditions with the machine. When I plug in the dryer there is a faint hum that is perceptible and when the washer is plugged in it is functioning in the agitation cycle. There are no lights on the control touch pad and no response from any of the buttons on the pad. Should I try replacing the touch pad next or do these symptoms indicate something else? And since this was the same exact condition before the circuit board was replaced is the indication that my circuit board may still be OK and not need replacing?
Related Models
Maytag SG1000 STACKED LAUNDRY- GAS
Maytag SG1000T Stacked Laundry - Gas
Hardwick SG1616A49R RANGE- F/S STD GAS
Hardwick SG1616W49R RANGE- F/S STD GAS
Hardwick SG1616Y49R RANGE- F/S STD GAS
Amana SG19SL REF - SXS/I&W
Amana SG19SW REF - SXS/I&W
Amana SG22MBG REF - SXS/I&W
Amana SG22MBL REF - SXS/I&W
Amana SG22MBW REF - SXS/I&W
Amana SG521SBL REF - SXS/I&W
Amana SG521SBW REF - SXS/I&W
Amana SG521SW REF - SXS/I&W
Maytag SG7800 STACKED LAUNDRY- GAS
Hoover SG901---
Hoover SG903---
Hoover SG905---
Hoover SG907---
Hoover SG913---
Hoover SG915---
Hoover SG919---
Hoover SG921001
Hoover SG925
Hardwick SG9612W79RO RANGE- F/S STD GAS
Hardwick SG9617A429R RANGE- F/S STD GAS
Hardwick SG9617W429R RANGE- F/S STD GAS
Maytag SG9900 STACKED LAUNDRY- GAS
Thermador SGC304R
Thermador SGC304RB STEEL BURNER GAS COOKTOPS
Thermador SGC304RS STEEL BURNER GAS COOKTOPS
Roper SGC355XW0 Range (gas)*
Roper SGC355XW1 Range (gas)*
Roper SGC355XX2 Range (gas)*
Roper SGC355XX3 Range (gas)*
Thermador SGC365RB GAS COOKTOP
Thermador SGC365RS GAS COOKTOP
Thermador SGC365RW GAS COOKTOP
Thermador SGC456RB STEEL GAS COOKTOPS WITH FULL SERVICE GRATES
Thermador SGC456RB SN 9803
Thermador SGC456RS STEEL GAS COOKTOPS WITH FULL SERVICE GRATES
Thermador SGC456RS SN 9803
Thermador SGC456RW STEEL GAS COOKTOPS WITH FULL SERVICE GRATES
Thermador SGC456RW SN 9803
Thermador SGCS304RB STEEL BURNER GAS COOKTOPS
Thermador SGCS304RS STEEL BURNER GAS COOKTOPS
Thermador SGCS304RW STEEL BURNER GAS COOKTOPS
Thermador SGCS365RB GAS COOKTOP
Thermador SGCS365RS GAS COOKTOP
Thermador SGCS365RW GAS COOKTOP
Thermador SGCS456RB STEEL GAS COOKTOPS WITH FULL SERVICE GRATES
Thermador SGCS456RB SN 9803
Thermador SGCS456RS STEEL GAS COOKTOPS WITH FULL SERVICE GRATES
Thermador SGCS456RS SN 9803
Thermador SGCS456RW STEEL GAS COOKTOPS WITH FULL SERVICE GRATES
Thermador SGCS456RW SN 9803
Thermador SGCV36 COOKTOP
Thermador SGCV3601 COOKTOP
Thermador SGCV36G01 COOKTOP
Thermador SGCV36G02 COOKTOP
Amana SGD22TL REF - SXS/I&W
Amana SGD22TW REF - SXS/I&W
Amana SGD26VL REF - SXS/I&W
Amana SGD26VW REF - SXS/I&W
Amana SGD521SBL REF - SXS/I&W
Amana SGD521SBW REF - SXS/I&W
Amana SGD521SW REF - SXS/I&W
Whirlpool SGDS800HQ0 GAS DRYER
Whirlpool SGDS800JQ0 GAS DRYER
Whirlpool SGDS800JQ1 GAS DRYER
Whirlpool SGDS800JQ2 GAS DRYER
Whirlpool SGDS800MQ0 29"GAS DRYER
Whirlpool SGDS800MQ1 29"GAS DRYER
Whirlpool SGDX600HQ0 DRYER
Whirlpool SGDX600JQ0 DRYER
Whirlpool SGDX600JQ1 DRYER
Whirlpool SGDX600JQ2 DRYER
Whirlpool SGDX600MQ0 29"GAS DRYER
Whirlpool SGDX600MQ1 29"GAS DRYER
Frigidaire SGER341AS0 Frigidaire/dryer
Frigidaire SGER341AS1 Frigidaire/electric Dryer
Frigidaire SGGR341AS0 Frigidaire/dryer
Frigidaire SGGR341AS1 Frigidaire/gas Dryer
Frigidaire SGGR341AS2 Frigidaire/gas Dryer
 SGM365 COOKTOP
Thermador SGN30B GAS COOKTOP
Thermador SGN30S GAS COOKTOP
Thermador SGN30W GAS COOKTOP
Thermador SGN36GB GAS COOKTOP
Thermador SGN36GS GAS COOKTOP
Thermador SGN36GW GAS COOKTOP
Thermador SGNCV36GB GAS COOKTOP
Thermador SGNCV36GS GAS COOKTOP
Thermador SGNCV36GW GAS COOKTOP
Roper SGP335XW0 Range (gas)*
Roper SGP335XW1 Range (gas)*
Roper SGP335XX2 Range (gas)*
White Westinghouse SGQ2152HS0 DRYER
White Westinghouse SGQ2152HS1 DRYER
White Westinghouse SGQ2170KS0 DRYER
 SGQ7000FS0 ELECTROLUX/DRYER
White Westinghouse SGR231CQ0 White Westinghouse/dryer
White Westinghouse SGR231CS0 White Westinghouse/dryer
White Westinghouse SGR231HQ0 DRYER
White Westinghouse SGR231HQ1 DRYER
White Westinghouse SGR231HS0 DRYER
White Westinghouse SGR231HS1 DRYER
White Westinghouse SGR341AQ0 Dryer - W.west
White Westinghouse SGR341AQ1 Dryer - West/grupo Gomo
White Westinghouse SGR341AQ2 White Westinghouse/gas Dryer
  #2 (permalink)
Old 07-16-2017, 08:03 AM
Junior Member
AntiPlannedObsolescence is on a distinguished road
Default
Quote:
Hi Jefinch,
I had the same exact situation with my Maytag SG1000.
I tried installing the least expensive part first, the touch pad, and Voila! Instant functionality! One touch does it!
So, for future reference, if it takes a prolonged pushing of the touchpad buttons to get it to work, it more than likely is the touchpad, not the more expensive circuit board.
Also, inspection of the ribbon cable from the old touchpad showed that one or two of the flat ‘wires’ appeared to have leached / bled out. Perhaps that’s what caused a gradual build-up of resistance leading to the eventual failure.
I'm posting this in hope it can help other folks.
  #3 (permalink)
Old 07-16-2017, 08:04 AM
Junior Member
Default
Quote:
Originally Posted by AntiPlannedObsolescence View Post
Hi Jefinch,
One more thing - that faint humming you mentioned is the transformer. It always does that whenever there's power to the machine; that's normal.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dead Panel on Maytag sg1000 jefinch Dryer Repair 10 07-16-2017 08:07 AM
Dead control panel caldwell.70 Dryer Repair 3 10-23-2009 06:01 AM
Control Panel is dead rileyd Oven Repair (including Ranges and Cooktops) 3 10-13-2009 05:10 PM
Maytag update Chriskall Dishwasher Repair 0 09-17-2009 01:08 PM
Maytag SG1000 (older unit) down! S.O.S. !!!! wavecowboy Dryer Repair 0 01-10-2009 06:17 PM
