| » Estate dryer doesn't dry on auto sense |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: tedl680an0 Brand: Estate Age: More than 10 years
Our electric dryer listed above drys fine on the timer but not on the auto sense mode. This just started happening. Is there a sensor for this or is the timer controller in charge of moisture content!
Thanx much!!! |
Some dryers have two sensing fingers mounted on the rear wall. As the clothes rub against these two fingers any dampness in them causes continuity between the 2. As long a wet is sensed then the dryer will plug right along. When the moisture is not sensed any longer then the timer motor is energised and the timer will move to the end of cycle and shut down. If your dryer has such a board, yank the board out and clean the contacts with a swab and alcohol.clothes dryer board.jpg
It is small and located near the timer and can be accessed by removing the rear panel on the control console. Cleaning the contacts will fix this problem a lot of the time. I had a problem looking up your model number. Last edited by SublimeMasterJW : 05-20-2008 at 11:20 AM. |
Thank you very nuch for the prompt reply to my question.I am going out of town for a month with no time to try it before but will as soon as we get back! Also is the sensor or board obtainable any more?
| Display Modes | |
| Estate Dryer Running but no Heat | TomCloud9 | Dryer Repair | 2 | 05-18-2008 03:20 PM |
| dryer timer auto cycles don't work | mikedudl | Dryer Repair | 0 | 04-29-2008 09:52 AM |
| Dryer will not heat during timed drying; will heat for short time while auto drying | mg13nj | Dryer Repair | 9 | 03-22-2008 11:40 AM |
| Estate Dryer by Whirlpool/Dryer running but no heat | tsm11238 | Dryer Repair | 1 | 11-06-2007 10:47 AM |
| Whirlpool Dryer Estate | 4018 | Dryer Repair | 1 | 10-23-2007 02:34 AM |
