| » whirlpool gas dryeR burner shuts off after a minute |
Model Number: LGR4634JQ2 Brand: Whirlpool Age: 5 - 10 years
The dryer burner runs for a minute or two then shuts off> the dryer stills runs just cold. does anyone know whats up?
Quote:
If it does not relight then the problem most likely is a bad gas valve coils. - The coil kit Part number: AP3094251 Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LGR4634JQ2 | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
I have taken off the back of the dryer and i have taken off and cleaned the lint trap thing. r there any other vents? I did run the dryer with it disconnected from the exhaust and it did the same thing. So it must be those coils right? thank you.
Exhaust and vent is the same thing. Sounds like a bad coils.
__________________
Thank you Gene, it is worth the $20 to give it a try. Do I need to take the drum out to replace the coils?
Again, thank you for letting me pick your brain - I will let you know how it goes - wish me luck! |
Some time the coils are accessible without removing the drum. Good luck.
__________________
Gene, I see your info hear about the part number but I don't see the schematic re: how to actually change the coils. A little help please?
Just want to make sure this is for a LGR4634JQ2. Also, my timer doesn't advance. Is this related to the same problem. thanks. |
Quote:
It is very likely that the new coils will solve the timer problem too. Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LGR4634JQ2 | AppliancePartsPros.com Gene.
__________________
Gene, Installed the new coils today and it did not fix the problem. Any other ideas? Is there a fuse or something for that part of the electrical that powers the coils? Just trying to exhaust all options before buying a new dryer tomorrow. Wife is pretty adamant that the clothesline is not acceptable!!!
Thanks |
| Display Modes | |
| starts, shuts off one minute | millerr | Washer Repair | 1 | 09-11-2009 03:56 PM |
| Whirlpool dryer-high pitch noise then shuts off | glb | Dryer Repair | 2 | 08-25-2009 08:28 AM |
| whirlpool gas dryer will run for about 5 min then it shuts off. | lawnlady | Dryer Repair | 0 | 03-25-2009 06:57 PM |
| Whirlpool dryer shuts off | missgreen | Dryer Repair | 1 | 11-12-2008 05:59 AM |
| Whirlpool dryer heat shuts off | Captain Carquest | Dryer Repair | 0 | 08-09-2007 11:37 AM |
