The dryer will not shut off in Auto or More Dry mode. However, on Timed cycle mode it works just fine. I would appreciate any help/suggestions.
This model does not appear to have a moisture sensor, or any kind of electronic control, so if it's not stopping, I would say the timer is the culprit. Here's the part number: Part number: AP4043236
You have been a member since:: 2/25/2010(UTC) Posts: 1
I haven't been able to troubleshoot yet. I am going to try cleaning the vent and then look at replacing the timer. I will post an update with any new developments.
