| » need complete instructions to replce rear drum support rollers |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: 110.86376800 Brand: Kenmore Age: More than 10 years
i have the front panel off and top panel loose. how do i remove drum? the right rear drum support roller is just flopping around on the shaft. should i replace the shaft also? if so, how do i remove shaft from panel? i don't see any clip or nut on shaft to contain roller to shaft. any pictures, part numbers would help.
thanks, fred |
With the top popped and the front panel removed all you gotta do is take the belt and Idler loose. Then grab the belt at the top of the drum and use upward force. Ease the drum out the front and set it to the side. The wheels wil be easily accessible then. Little triangles made of plastic retain or hold the wheels onto the shaft of these dryers. The wheel closest to the motor always wears out first.
| Display Modes | |
| dryer drum support replacement instructions | jerry reynolds | Dryer Repair | 0 | 01-23-2008 07:55 PM |
| dishwasher instructions to replace complete motor and pump assembly needed | Nancy Ramsey | Dishwasher Repair | 0 | 10-25-2007 12:22 PM |
| reattach rear drum support pannel | dmcglynn | Dryer Repair | 0 | 10-22-2007 10:20 AM |
| follow up to frigid rear drum question | treefrog | Washer Repair | 0 | 08-19-2007 01:24 PM |
| how do I: remove rear drum bearing frigid front load? | treefrog | Washer Repair | 0 | 08-19-2007 01:12 PM |
