Discuss
need complete instructions to replce rear drum support rollers
 in
Dryer Repair
i have the front panel off and top panel loose. how do i remove drum? the right rear drum support
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » need complete instructions to replce rear drum support rollers
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-17-2008, 08:50 PM
reddyfreddy reddyfreddy is offline
Junior Member
reddyfreddy is on a distinguished road
Default need complete instructions to replce rear drum support rollers
Model Number: 110.86376800   Brand: Kenmore   Age: More than 10 years
i have the front panel off and top panel loose. how do i remove drum? the right rear drum support roller is just flopping around on the shaft. should i replace the shaft also? if so, how do i remove shaft from panel? i don't see any clip or nut on shaft to contain roller to shaft. any pictures, part numbers would help.
thanks, fred
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-18-2008, 01:34 PM
SublimeMasterJW SublimeMasterJW is offline
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default Take the idler loos at the base and the drum will come right out the front
With the top popped and the front panel removed all you gotta do is take the belt and Idler loose. Then grab the belt at the top of the drum and use upward force. Ease the drum out the front and set it to the side. The wheels wil be easily accessible then. Little triangles made of plastic retain or hold the wheels onto the shaft of these dryers. The wheel closest to the motor always wears out first.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer drum support replacement instructions jerry reynolds Dryer Repair 0 01-23-2008 07:55 PM
dishwasher instructions to replace complete motor and pump assembly needed Nancy Ramsey Dishwasher Repair 0 10-25-2007 12:22 PM
reattach rear drum support pannel dmcglynn Dryer Repair 0 10-22-2007 10:20 AM
follow up to frigid rear drum question treefrog Washer Repair 0 08-19-2007 01:24 PM
how do I: remove rear drum bearing frigid front load? treefrog Washer Repair 0 08-19-2007 01:12 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
