Discuss
GE dryer starts without turning start switch
 in
Dryer Repair
My GE dryer starts without turning the start switch. It automatically comes on when the timer is set. Could this
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » GE dryer starts without turning start switch
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-17-2008, 08:59 AM
ddeaton ddeaton is offline
Junior Member
ddeaton is on a distinguished road
Default GE dryer starts without turning start switch
Model Number: DHDSR48EF2WW   Brand: GE   Age: 1 - 5 years
My GE dryer starts without turning the start switch. It automatically comes on when the timer is set. Could this be a start switch or timer related issue? Other than this problem, dryer seems to be working fine. Any help would be appreciated. Thanks.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-17-2008, 10:08 AM
SublimeMasterJW SublimeMasterJW is offline
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default Points on start switch fried together
Most likey the start switch is bad. Remove one of the wires going to it and use precautions not to let it short against the cabinet. With a wire disconnected to this start switch, it should quit starting if that switch is the problem. I would replace the switch if that proves to be the case.
  #3 (permalink)
Old 05-17-2008, 12:39 PM
Junior Member
Default
Will do. Thanks.
  #4 (permalink)
Old 05-26-2008, 09:11 PM
fvalcho fvalcho is offline
Junior Member
fvalcho is on a distinguished road
Default defective start switch?
Quote:
I want to make sure I have the same problem. The ON OFF switch has no affect. As soon as the Main control know comes off of top center, the dryer starts. It works fine otherwise. Model Nr. DGSR483EEOWW. Can someone confirm this? when I get a chance, I'll take the top off and disconnect one of the wires to the ON/OFF switch. Thanks.
  #5 (permalink)
Old 05-27-2008, 11:41 AM
Senior Expert
APP Volunteer
Default Checking the start switch
To get the dryer going you must press start. If it does it all by it's lonesome and you suspect the contacts are fried on that switch then an easy way to find out is to remove one of the wires to the start switch. Make sure it won't short out. Plug the dryer back in and see if that stops the automatic starting of the dryer. If the contacts are fried you should replace the switch.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer not turning swtmama5 Dryer Repair 1 01-27-2008 06:06 PM
oven igniter starts gas until u release the start then it gas shuts off but not light bradk36 Oven Repair (including Ranges and Cooktops) 1 01-22-2008 04:16 PM
spin cycle starts slows starts grhodes Washer Repair 0 12-18-2007 02:50 AM
Starts to pump during wash then shuts down, starts, stops real quidk sirgalagit Dishwasher Repair 1 10-03-2007 08:23 PM
Wont start/start switch replaced awilliams197 Dryer Repair 1 09-18-2007 01:33 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
